Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Brake fluid question
Old Jun 15, 2004 | 09:43 AM
SunMax's Avatar
Guys,
Does the brake fuild circulate through the (brake) system like the power steering fluid does? I changed the PS fluid by using the turkey-burster way and wondering if I can do the same for the brake fluid.
Thanks!
Old Jun 15, 2004 | 09:47 AM
Jeff92se's Avatar
I'm needing a caw
You can replace just some of the brake fluid that way. But it should be flushed out. Taking the fluid out of the MS, just reduces the amount you have to flush.
Old Jun 15, 2004 | 01:07 PM
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Brake fluid does not circulate through the system as does power steering fluid...As jeff recommends, do the turkey baster trick in the master cylinder before bleeding to speed the process.
sctludwig
Sep 1, 2022 01:32 PM
BkGreen97
Apr 2, 2016 05:47 AM
dcardello
Sep 3, 2015 11:44 PM
crazyespn
Sep 3, 2015 01:30 PM
Johnny9595
Sep 3, 2015 05:18 AM
