What steps to take when switching to systheic oil?
i currently have 45k on my 00 se and was thinking about switching to mobil 1 systheic..i heard from some that when they switch they use 3 quarts systheic and 2 quarts regular....then on the next change they use all systheic...is this all i have to do to switch? and if i switch and use all 5 quarts systheic is that going to be ok?
There won't be harm in mixing at first if you want, but mobil's site says that you don't need to bother, and I think common knowledge these days says just throw the synthetic in. My 97 I switched from conventional to synthetic when I bought it by simply going straight from pennzoil or whatever it had to full syn. No leaks since doing that 6k miles ago.
If you want to play it safe, get some Amsoil Engine Flush. It's cheap and simple to do. If you don't, you may want to do normal change intervals on the synthetic 2 to 3 times to let it clean up the deposits left by dino oil. I've used the engine flush on cars that have been well maintained with change intervals of 3k and the flush removed quite a bit of sludge.
Originally Posted by Ammi
Are you saying you had leaks before you switched to synthetic?
No Need to Flush
As others have pointed out no need for a flush prior to changing to a synthetic .
It is difficult to recommend a first drain interval since your driving habits are not posted but because of the mineral residual oil I'd say run the syn to 75% of the planned OCI first time .
Originally Posted by SkoorbMax
No, I had none before either, but some people in the past have said that switching to a syn can produce oil leaks.
One thing instead of the engine flush is to replace your oil filter more frequently, since the sludge will be trapped in the filter.
Open your oil filler cap and look in the valve cover. If you see any black carbon deposits floating around, use the engine flush.
Originally Posted by ???
i'm surprised to hear that... what cars were they and what mileage were they at to come out with that much sludge from a flush?
James92SE
10-08-2015 04:57 PM
foodmanry
09-24-2015 12:02 PM
JoshG
51
09-21-2015 10:41 PM
RWCreative
09-21-2015 11:01 AM
