Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Does that seafoam really do anything?
Old Sep 4, 2004 | 06:05 PM
f550maranello2's Avatar
Yea i poured it into the brake hose line just smoked a lot out of the exhaust thats about it
Old Sep 4, 2004 | 06:44 PM
DAVE Sz's Avatar
Hooooooonda.....
If the smoke was white then no it didn't work.
Old Sep 4, 2004 | 06:56 PM
deezo's Avatar
It's not something you do once and run with it. You should make a practice of using it everytime you change your oil.
Old Sep 4, 2004 | 07:10 PM
goodhead's Avatar
yes it really does
Old Sep 4, 2004 | 09:24 PM
Keyser Skoze's Avatar
Whats this sea foam and what does it do exactly?
Old Sep 5, 2004 | 08:15 PM
i dunno i used it (mixed with half gas) and it really didnt do anything if anyone got some result from it please post!
Old Sep 5, 2004 | 08:42 PM
Torgus's Avatar
if you do it with every oil change it probably helps...
but i wonder if you shouldn't just let all that built up carbon say 8 years worth and stuff stay in the engine instead of trying to blow it all out.
Old Sep 5, 2004 | 08:55 PM
i think i would be ok to let all that crap blow out cuz thats what they do at all the shops if u request the carbon treatment thing
Old Sep 6, 2004 | 08:07 PM
philly96maxima's Avatar
Poured into brake hose line?
Old Sep 6, 2004 | 08:54 PM
BORQUA79's Avatar
nycmaximas member
I dont mean to rain on this thread but I heard that If you run your car alot and at high speeds, than you shouldnt have all that build-up... that usually gets blown out...Also you should be careful that If alot of carbon loosens up (using the seafoam) you might clog your injectors... Besides alot of additives usually isnt too good... If your doing it dont overdo it... Just my .02
Old Sep 6, 2004 | 09:13 PM
goodhead's Avatar
i was told seafoam is a pure petrolem, but all that white **** taht came out of my exhaust did make my engine seem to purrr a lil smoother
Old Sep 6, 2004 | 10:11 PM
DAVE Sz's Avatar
Hooooooonda.....
Like I said, the white ****, as you call it, is just the sea foam burning off. If the smoke was grey than you'd know it actually did something.
Old Sep 6, 2004 | 10:17 PM
Jeff92se's Avatar
I'm needing a caw
Can you explain in technical terms how seafoam would clog your injectors???
Old Sep 6, 2004 | 10:44 PM
I30tMikeD's Avatar
hmmm... wouldn't any carbon that was "loosend" up be after the injectors, not before?
Old Sep 6, 2004 | 10:47 PM
Jeff92se's Avatar
I'm needing a caw
Mike! Exactly. But he seems to know more than us.
Old Sep 7, 2004 | 06:41 AM
I30tMikeD's Avatar
I just wish someone who knows more than both of us could figure out what is wrong with my car
Old Sep 7, 2004 | 06:54 AM
mzmtg's Avatar
Minister of Silly Walks
Did you clean your throttle body?
Old Sep 7, 2004 | 08:11 AM
I30tMikeD's Avatar
Yes, And OMG!!!111!!!
Old Sep 7, 2004 | 09:01 AM
97I30touring's Avatar
Seafoam took my car from a 15.1 qtr mile to a whopping 13.0!!!!!! @ 123 mph!!!! funny? ok, no...but it blew out a lot of black smoke, made for a smoother idle, and zipper performance, no lie
Old Sep 7, 2004 | 09:08 AM
how much of that bottle did u use when u poured it in, oh by the way theres no way that it can clogg the injectors cuz i doesnt go through them
Old Sep 7, 2004 | 09:31 AM
Where do you get it?
Old Sep 7, 2004 | 09:46 AM
DAVE Sz's Avatar
Hooooooonda.....
If he poured the sea foam into the gas tank wouldn't that loosen some debris that could clog the fuel injectors?
Old Sep 7, 2004 | 09:51 AM
Jeff92se's Avatar
I'm needing a caw
Debris from where? Gas tank -> fuel line -> fuel filter -> injectors = not knowing what he's saying ie... spouting misinformation. Which seems to be the par for this section.
Old Sep 7, 2004 | 09:58 AM
piggpenn's Avatar
i'm sorry, but what exactly is seafoam?
Old Sep 7, 2004 | 11:08 AM
4DRSpeed's Avatar
Project Ruby......
It cleans the carbon out of your motor, can also be used in your oil and through the fuel to clean injectors.
I use this about every 9K maybe. Just ran some through the motor and fuel the other day. Was actually checking for an exhaust leak which I don't have thank god.
I did notice a little more lowend, but that's about it. SeaFoam doesn't really increase HP, increases the life of your motor.
Old Sep 7, 2004 | 11:22 AM
Imobejoas's Avatar
My buddy MrEous and I ran some sea foam through his car. He's got a small write-up and little snafu that happened right after because of it. I'll link 'em in here.
Old Sep 7, 2004 | 11:36 AM
MrEous's Avatar
^ Jeff™
Yep...my original post is here:
http://forums.maxima.org/showthread.php?t=327566
Basically...
Fast forward 2 hours...I drive up to the meet and feel my car stumbling, no cel. I park it and go about my business. Leave later that night and car is stumbling and cel light flashes then stays on. Check the codes and find 3:
0302 - EGR system malfunction
0702 - 3-way Catalytic converter
0412 - Upstream 02 sensor high voltage (right bank)
I think..."Umm...crap."
I reset the ecu just because I don't want to have to deal with it right then and car runs fine. Next morning it stumbles again but the only code I have now is the 0412. Reset it and it comes back.
Basically I was led to believe the o2 sensor got fouled up with carbon and that is why I received the cel codes. No problems since.
Old Sep 7, 2004 | 02:44 PM
BORQUA79's Avatar
nycmaximas member
Sorry about the mis info... But its great that someone corrected it... My Bad
But isnt it true that If alot of carbon loosens up at a time wouldnt it not be so good for the engine? Plus they say to put it in the fuel, oil and vaccum line but do you really need it everywhere?
Old Sep 7, 2004 | 04:51 PM
Jatan's Avatar
You don't NEED to use SeaFoam at all Just use it where ever you want out of those 3 places. If you want some of the carbon out then shoot it into the brake booster hose. If you want to get some of the sludge/gunk out of the engine then pour it into your oil. If you want to clean your fuel injectors then pour it into your gas tank.
Old Sep 7, 2004 | 04:52 PM
I30tMikeD's Avatar
I would just do half a can through the intake manifold and the other half in the gas tank, at least that is what I do.
Old Sep 8, 2004 | 12:32 PM
bearded's Avatar
So how exactly do you use seafoam to test for an exhaust leak?
When I used seafoam I noticed smoke emanating from the engine bay as it was pouring out of the exhaust tip. Does this mean I have an exhaust leak somewhere in my engine bay?
Old Sep 23, 2004 | 11:44 AM
car_boy_16's Avatar
Im guessing you use the seafoam to test for exhaust leaks due to the fact that seafoam smokes when it gets evaporated, so whereever there would be a leak in the exhaust, smoke would be comming out of there due to the seafoam. Simple.
I have some questions, I have the seafoam but I'm scared of doing it because it's my moms car and if I mess it up I dont want her beatin my asz down like a little biotch.
1. Ok now, I've taken my brake booster hose off and the idle skyrockets, is this ok, is this normal?
2. Do I pinch the brake booster hose while sucking the seafoam into the car via brake booster hose?
3. How much of the bottle should I use, can I use all of it?
3. What do you think about the Oxygen sensors getting all carboned up due to the seafoam? I really dont want to have to replace them, they can get expensive, especially the rear O2 sensor.
I would really appreciate it if someone can answer these questions for my sake and for the FAQ future reference.
Old Sep 23, 2004 | 03:12 PM
4DRSpeed's Avatar
Project Ruby......
When pulling the brake booster line, your car should get a very burbly sound, like it almost wants to die on you sound, but won't.
Pour 1/3 of the can into the brake booster line SLOWLY!!!!!!! I can't stress this enough, you will seize the motor if you pour it in fast. I suggest pouring it into a disposable cup then pour that way into the line. As you pour slowly you'll notice that it will start turning to mist.
As it is going into the line, the idle starts to rise. The engine gets louder. What I do when the idle starts to rise, I keep pouring for about another second and a half, then stop, and wait for the motor to burble again. Then I just keep repeating until the cup is empty.
Just take your time, and do it SLOWLY!!! You can kill the motor fast, if you pour it in too quickly.
220k+ A32
Sep 23, 2015 03:38 PM
MrEous
41
Dec 5, 2005 03:50 PM
E55AMG2
50
Dec 21, 2004 09:15 PM
MrGone
58
May 25, 2004 11:57 AM
