Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
"Avoid expensive premium gas..."
Old Oct 20, 2004 | 08:22 AM
Dolomite's Avatar
"because it sits in the tank longer because fewer people buy it."
(Don't shoot the messenger!)
Injector flaws impede drivers, stump experts
Rash of costly repairs has some experts suspecting tainted gas
www.jsonline.com/news/gen/oct04/268069.asp
Mechanics, while not all in agreement, suggest a number of ways to help protect your vehicle from clogged fuel injectors:
Never fill up when tankers are resupplying a service station. This stirs up whatever may be at the bottom of the storage tanks.
Keep gas tank as full as possible on a regular basis. Air in the tank contains moisture than can get into gasoline and cause problems.
Keep gas tank full or near-full when temperatures drop below freezing.
Avoid expensive premium gas because it sits in the tank longer because fewer people buy it.
Every 3,000 miles or so add a fuel injector cleaner/conditioner to tank when it is three-quarters full, then fill it all the way up.
Auto shop mechanics and dealership service managers are scratching their heads over a mysterious spike in the number of cars - of various makes and ages - they are seeing with clogged or failing fuel injectors in recent weeks, sticking their owners with $200 to $900 in repair bills.
"This is definitely out of the ordinary," said Charlie Sampson, a service consultant at Wilde Honda in Waukesha. "We had at least 25 in just three days."
Other Honda dealerships, as well as General Motors Corp. and DaimlerChrysler AG service shops, around the Milwaukee area report similar swells.
Some blame the change in weather - or the newly supplied seasonal gas. Others suggest possible contamination at one of the regional distribution terminals. One oil analyst suggests it could be the heavier crude now being used as a result of Hurricane Ivan knocking out access to lighter supplies from the Gulf Coast.
"We need to track down this product that's causing the problem," said Berni Mattsson, administrator of the agency's Division of Environmental and Regulatory Services.
The Department of Commerce regularly tests petroleum at distribution terminals around the region that supply Wisconsin's roughly 3,300 retailers. It would be unlikely that a terminal would be the source of the trouble, Mattsson said, as typically less than 1% of the incoming product doesn't meet specifications. Unsatisfactory supplies are usually caught before they leave the terminal, she said.
The department also tests service station tanks and pumps once every one to two years.
The Wisconsin Petroleum Council, an agency representing oil producers that supply the state, is also investigating the issue, said Erin Roth, executive director.
Roth said he's talking to all the suppliers to see if something went wrong Sept. 15 when they changed to the winter fuel blend, as is required by the U.S. Environmental Protection Agency.
"We're looking at 'Did somebody put too much of an additive in somewhere or are the service station tanks dirty?' " he said.
Roth was reminded of an incident in 2001 when Milwaukee received a supply of fuel with a rust inhibitor 100 times the allowable strength.
"People's cars were stopping on the highway," he said. "I'm not saying that this is what it is. We don't know if it has anything to do with the fuel."
Meanwhile, dealership mechanics and independent garage owners speculate about what might be triggering the surge.
"It's a manufacturers' problem," said Dan Karagianis, manager of Tarkus Complete Automotive Service, 5616 W. Burleigh St. in Milwaukee. Karagianis said he is seeing more fouled fuel injectors in GM vehicles than any others.
"Our manufacturers are telling us it's the fuel," said Al Weimar, service director at Braeger Chevrolet on S. 27th St. in Milwaukee.
Ray Kurian Jr., co-owner of Ray's OK Service Inc., 4100 N. Loomis Road, Greenfield, is convinced it is the fuel. Reformulated gasoline, mandated in six area counties in 1995, has taken a toll on cars over time, he said.
"We have seen a significant increase in failed fuel injectors and failed fuel pumps . . . for no apparent reason at all," Kurian said. "I've been doing this for 32 years now. Since we changed to reformulated gas, the number of fuel injection failures has quadrupled."
Some manufacturers - GM, BMW, Honda and Toyota - are so dissatisfied with the fuel supply nationwide they have teamed up with major oil companies, in an unprecedented move, to devise a new class of gasoline called Top Tier Detergent Gasoline that exceeds EPA detergent requirements. Top Tier is not yet available in Wisconsin.
Honda, which is investigating the fuel injector issue in the Milwaukee area, said low-quality fuel certainly causes problems in the long run.
"We've witnessed over time a degradation in the quality of gasoline," Honda spokesman Andy Boyd said. "We're really trying to address that."
Fuel injectors are meant to last well beyond 100,000 miles, Boyd said.
Old Oct 20, 2004 | 08:32 AM
NmexMAX's Avatar
dot dot dot ...
It's like wine, gets better with age. . .
This is interesting though.
I'll still continue to use it.
Old Oct 20, 2004 | 08:40 AM
MaximaPolak's Avatar
Your wrong about that people don't buy premium......Everyone around where I live, except a few people, buys premium.
Old Oct 20, 2004 | 08:41 AM
Mizeree_X's Avatar
Getting back to his roots
If you use a high-traffic gas station you probably have nothing to worry about.....if you use some obscure mom and pop shop well off the beaten path then yeah, maybe the premium will sit in the tank too long. That article won't dissuade me from buying 93 octane anytime soon (though soaring prices might )
Old Oct 20, 2004 | 09:09 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i have heard the new shell gasoline is being blamed on a higher number of failing fuel pumps in nissan/infiniti vehicles. i personally have not heard of any other brand being blamed besides them, at least in the nissan realm.
Old Oct 20, 2004 | 09:19 AM
I30tMikeD's Avatar
With the amount of 93 I buy from my local Mobil station they have to fill it up every week
Old Oct 20, 2004 | 09:27 AM
Blackwind's Avatar
"WAAAYYY down in the jungle deep! a signafied monkey stepped on a loins feet!!"
Rudy Ray Moore aka "Dolomite"
Old Oct 20, 2004 | 09:37 AM
Jeff92se's Avatar
I'm needing a caw
IMHO, more cars than ever before require the use of Premium. If anything it's the low octane stuff that doesn't sell.
Old Oct 20, 2004 | 10:03 AM
passEMonTHErite's Avatar
All these gas companies are putting all these additives and detergents in their gas. Kind of makes me nervous. The only detergent I use is the fuel injector cleaner after oil changes.
I mean is it possible to just get plain old gas anymore?
Old Oct 20, 2004 | 10:15 AM
Mizeree_X's Avatar
I'd trust detergents gasoline companies put in their gas over 95% of the stuff you buy in a bottle and dump in your gas tank.
Old Oct 20, 2004 | 10:23 AM
MrGone's Avatar
meh, I'm not too worried about it.
Old Oct 20, 2004 | 07:45 PM
DAVE Sz's Avatar
Hooooooonda.....
That's funny, the pumps I usually use more people buy premium than others.
Old Oct 21, 2004 | 09:58 PM
lophix's Avatar
I would have ignored this post a couple of weeks back except that within the past 3 days, we've seen at least 5 maximas come down with injector problems. Even though I'm pretty sure it's not coincidence, I still find it interesting. So, hm...
Old Oct 22, 2004 | 05:50 AM
SkoorbMax's Avatar
One gas station I have visited had little counters on who bought what. Most bought 87. A good number bought 93, and very few bought 89. Anyway "Avoid expensive premium gas because it sits in the tank longer because fewer people buy it." Is retarded. yes it sits in the tank longer, but does that mean it's sitting there long enough to become stale? Simply saying it sits in the tank longer is incomporably idiotic. Anyway, I'm not directing at the OP. Like he said, he's just the messenger
I would too. That's why chevron's techron is probably one of the "safest" injector cleaners, because it's for the most part just a concentrate of what chevron already puts in their gasoline.
Old Oct 22, 2004 | 08:03 AM
nick's Avatar
i've noticed much better -performance with new Shell gas (premium) @ $2.20 a gallon
Idle is smooth , no hesitation at 3000 rpms , car pulls strong.
I was using Mobil for over 2 years and one day i have noticed the tanker resupplying the gas station with no name/no brand gas - there was no signs of Mobil on it at all.
It might make no difference but here in Gurnee Mobil permium goes for $2.35 and Shell v-power sells for $2.20
Nick.
Old Oct 22, 2004 | 08:12 PM
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Nick.
Me too...I keep very detailed records on my car and I noticed that since I started using the new V-power gasoline and I have experienced a definite increase in fuel economy. I drive fairly conservatively, use AMSOIL Series 2000 0w-30, and I'm consistently getting 28/29 mpg. Engine runs exteremely smooth. Shell premium currently $2.09 in San Antonio.
Old Oct 23, 2004 | 04:44 PM
jtibb's Avatar
we all know what happens if u don,t
Old Oct 23, 2004 | 05:47 PM
WildmanAL's Avatar
It definitly depends on where you live. There are so many nice cars around where I live that require premium gas. Cars in the ghetto never buy premium gas.
Old Oct 24, 2004 | 01:50 PM
SR20DEN's Avatar
VQ Wizard
Has anyone else heard of the problems caused by Shell Gasoline with their new V power? Word on the street is that some Infiniti, Acura, etc. dealerships are having to replace entire fuel systems on vehicles that have used this fuel. It apparently is to blame for quick deterioration of fuel systems on these vehicles and in many cases Shell has picked up the bill for vehicle repairs. Upon hearing this news I decided to use this fuel more often to see if there is any merit to this claim. But my guess is that many of these issues are isolated to certain mixing stations and perhaps the batches were mixed too strongly with detergents. Also keep in mind that Shell advertises Five times the required amount of detergents in their V power gasoline.
As for abd gasoline, it really does depend on the traffic at the fuel station. Most of the stations in my area are high traffic and I consistantly see very clean fuel tanks in the vehicles around here.
Old Oct 28, 2004 | 06:47 PM
Torkaholic's Avatar
Maybe in Mexico. But here, no, there's no such thing as just "plain" gas any more. Federal emissions regs dictate that gasolines of all grades contain certain minimum amounts of detergents. These are necessary to keep the finely balanced emissions systems operating properly. Other new things include, for example, oxygenates in some fuels in some locations. These do what you might expect -- help the fuel burn more completely. And there are other things too. Gasoline has become an extremely complex witches brew of different ingredients.
Old Oct 28, 2004 | 06:57 PM
Torkaholic's Avatar
Oh yeah, one other thing -- what grade of fuel do recent Maximas call for? I drive a G35 sedan, which of course, has a version of the VQ35DE very similar to the one in the current Max. G35 sedans, with the 260hp/260ft-lb (mine's an 04) version of the VQ allow the use of regular, but recommend the use of premium for "improved performance." G35 Couple, which have a more Z-like version of the VQ (298/260 for man trans and 280/270 for autos, 2005 specs) requires the use of premium. If I had a coupe, I sure wouldn't pass up the premium on the chance that the regular was a tad fresher. My sedan is noticeably stronger and doesn't ping at all with premium. I'm staying with that, thanks.
Old Oct 29, 2004 | 08:09 AM
NismoMax80's Avatar
SuPeRmOd
Well, I fill up on Wednesday b/c Texaco has $.06 off premium. I sure others also ues it that day. I know at least near me, Premium is the most used, or those luxury and performance owners are stupid. (Lexus, BMW, Mercs, ect. everywhere. station is across from Hershey Med. Center)
Premium is recommended for Maximas. Gas has sat in the tankers coming over and the gas company when they add the Needed detergents.
Why would you want "plain old gas"?
Old Oct 29, 2004 | 09:52 AM
carnal_c30's Avatar
Former Sponsor
yes I heard of this problem, it was a batch of gasoline shipped into the south, I think one of the refineries in Lousiana or somewhere in the south made a batch that was causing ALOT of problems a few months ago
Where I live premium gets pumped plenty, even at 2.69/gallon
I just wish we had good quality gasoline like other industrialized countries, there seems to always be a bad batch here, a bad batch there... I dont care about 50 times the requirement of detergents, to me that could be liable for some of the problems, how bout make some top notch gas, with just enough detergents to do the job
Old Oct 29, 2004 | 11:14 AM
Mizeree_X's Avatar
I'm sure it can be arranged if you want to pay $4.00+ per gallon.
Old Nov 4, 2004 | 09:36 PM
GimmeTorq's Avatar
Hopefully this new standard will help... http://www.toptiergas.com/
Notice Shell gas is not there yet.
Old Nov 4, 2004 | 10:08 PM
carnal_c30's Avatar
Former Sponsor
cool
and about $4/gallon... yea thats kinda true but I mean like Saudi Arabia where gas is like 10 cents a gallon
4.99 willl get me 106 octane
Old Nov 5, 2004 | 07:28 PM
GimmeTorq's Avatar
Is this the issue with Shell gasoline you guys have been talking about? That's messed up!! I think I'm gonna avoid Shell...
http://www.theautochannel.com/news/2...08/199111.html
Old Nov 9, 2004 | 10:30 AM
DonVince's Avatar
I work for the Health Department and inspect gas stations. The mom and pop stations are a concern because some have not upgraded the tanks to EPA standards. Another concern are the stations that have a couple of inches of water sitting on the bottom of the tank. The main concern are the trucks that transport the gasoline. These tankers are not capeable of being washed out due to the posibility of water contamination. And more often than not the truck will transport premium today and regular tomorow in the same compartment. And you know those compartments are rarely empty before they are refilled.
"Never fill up when tankers are resupplying a service station. This stirs up whatever may be at the bottom of the storage tanks."
This is something to live by... It takes almost 24 hours for tank that has just been filled to settle....
Vince
Old Nov 24, 2004 | 01:27 AM
FanaticMadMax's Avatar
Very interesting discussion. I always use Premium. especially where my city, a lot of people regularly use Premium since there's a lot of late models out here that requires it. But those iwth a beater car, i'm sure they use regular (87) or Plus (89)
Old Dec 2, 2004 | 12:10 AM
l3ftonm3's Avatar
yah you have jersey gas prices. I love that first station off the GW bridge heading upstate on the Palisades PKY where I can get 93 for 2.17 and its full service. Then I travel 5 miles up the road and see dumb people buying the same octance gas for 2.69 a gallon since they are still in ny. I hate state boundaries
Old Dec 2, 2004 | 01:10 PM
97MAX_FORME's Avatar
I'll stick with the Mobil/Exxon premium.... WOW it dropped to a whole $2.15 this week!!!
I notice how great it runs with 93 rather then like Haffners 93 or better yet the 87
Old Dec 2, 2004 | 06:59 PM
sagamax's Avatar
Give me a Bud Light Holmes
not this again
Old Dec 15, 2004 | 03:26 PM
fred's Avatar
hate to flog a dead horse but premium will not go bad from sitting! no gas goes bad from sitting! and if your so worried about it, get your own oil company (joke)
Old Dec 15, 2004 | 03:40 PM
Ant96GLE's Avatar
Can you read or are you just blind?
TOP TIER Detergent Gasoline Retailers
Gasoline retailers must meet the high TOP TIER standards with all grades of gasoline to be approved by the automakers as providing TOP TIER Detergent Gasoline.
In addition, all gasoline outlets carrying the brand of the approved retailer must meet the TOP TIER standards.
Additional gasoline retailers are added to the TOP TIER list as they meet the standards. The retailers known to be on the TOP TIER list are shown below.
TOP TIER Gasoline Retailers:
QuikTrip
Chevron
Conoco
Phillips
76
Shell
Entec Stations
Old Dec 15, 2004 | 04:22 PM
S00NR1's Avatar
OU > *
I am pretty sure that when he posted that link, Shell had yet to be named a top tier gasoline. I checked it when he gave that link, and Shell was not on the list.
Old Dec 15, 2004 | 05:09 PM
Ant96GLE's Avatar
Either way I'd still never use Shell
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
Redfox
Sep 28, 2015 10:41 AM
REDinLV
Sep 28, 2015 12:31 AM
Noela
Sep 26, 2015 08:22 AM
