Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
What do u guys recomend for transmission oil?
Old Oct 20, 2004 | 11:22 AM
S15 SR20DET's Avatar
sup guys,
iam changing my tranny oil and i didnt know which kind i should go with, my car is a 98, 5sp with 146000 mile on it so what do u guys think?
thanks.
Old Oct 20, 2004 | 11:33 AM
haysdb's Avatar
How to change manual transmission fluid? Which fluid: GL-4 or GL-5? Best gear oil?
With Amsoil Series 2000 no longer available, it looks like Redline MT-90 is the recommended gear oil.
Old Oct 20, 2004 | 12:25 PM
RichSpidizzy's Avatar
looks like Amsoil Series 2000 has been replaced with Amsoil SAE 80W-90 Synthetic Gear Lube
seems to meet the same requirements: http://www.amsoil.com/products/agl.htm
Old Oct 20, 2004 | 01:25 PM
Virus's Avatar
Why did they stop making it?
Old Oct 20, 2004 | 01:45 PM
CCS2k1Max's Avatar
It's still in the Amsoil on line catalog
Old Oct 20, 2004 | 11:05 PM
haysdb's Avatar
...most recent edition of the AMSOIL newsletter explains that Severe Gear will replace the Series 2000, and that the Series 2000 oil would be sold until the existing stock is exhausted.
The new product, Severe Gear, is GL-5 rated, not GL-2 thru GL-5, and so is not recommended.
AMSOIL AGT is still available, which is apparently what many orgers use. It's an 80W-90 GL-4 gear oil. It's only available in gallons, so two gallons will be needed.
Another option is ALU, which is "Marine lower unit gear lube" but it's an 80W-90 GL-4 rated lube that can also be used in automotive applications specifying a GL-4 oil.
I'm not sure why AGR and AGL wouldn't work also. Both are rated "GL-2 through GL-5".
Sheesh, I just want some gear oil. It shouldn't be this complicated.
Old Oct 21, 2004 | 10:02 AM
who says AGL wouldn't work? that's what amsoil recommends...
Old Oct 21, 2004 | 04:23 PM
SKYRockerr's Avatar
I have 26K Miles on my maxima, whats a good mileage to change transmission fluid? Or i should just wait till 50K and get another tranny? lol
Old Oct 21, 2004 | 06:17 PM
haysdb's Avatar
...both AGR and AGL are/were rated GL-2 thru GL-5. Previously they could have been used in your transaxle. AGR...is being replaced by FGR (newly introduced "long-life" 75w-90) and FGR is a GL-5 oil (not recommended for your application). AGL has been reformulated effective 1 Oct and has changed to a straight GL-5.
The only products AMSOIL now offers for our 5-speed transmissions is AGT, available in gallons only, and ALU, "Marine lower unit" lube.
I could have this wrong though, so corrections are appreciated.
Old Oct 21, 2004 | 07:17 PM
where did you pull that quote from?.... that's lousy news
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Everything you state is correct :-)
Old Oct 21, 2004 | 07:26 PM
AMSOIL has changed their line of gear oils effective 1 Oct. While remaining stocks of the previous formulations will be sold, the Series 2000 Gear oil will be replaced with a new formulation called "Severe Gear"...that product is GL-5 rated. The previous AGR (75w-90) has been replaced with a new "Long Life" line of lubes, and that too is GL-5 rated. AGL (80w-90) has also been reformulated and it too is now a GL-5 oil. To the best of my knowledge, AGT and ALU are the only GL-4 rated oils remaining.
Old Oct 26, 2004 | 12:08 AM
haysdb's Avatar
It would seem, from reading the product info on AMSOIL's web site (www.amsoil.com), that AGT and ALU are the same product. ALU is available only in 8 oz. tubes and quarts, AGT is available only in 1 gallon bottles, 5 gallon pails, and 55 gallon drums. In various places on the web site, they refer to AGT/ALU.
If this is true, then a gallon of AGT plus a quart of ALU would be the cheapest way to go.
talkinghorse, can you confirm whether AGT and ALU are the exact same thing?
Old Oct 26, 2004 | 08:46 AM
Love_00_Max's Avatar
S15 SR20DET: If I were you, I will wait till the end of the year for DexronIII(H) to come out. The licenses for the major ATF producers expires for the GM DexronIII(G) spec that you see OTC today and the ATF meeting this new spec will greatly reduce shear, oxidation, reduce shudder etc, etc.
It is expected to be be carried by many shops early next year.
Old Oct 26, 2004 | 08:07 PM
I've consulted with AMSOIL tech services on this very issue before, and they advised that the only difference in the two products is that the ALU contains additional amounts of water emulsifiers to protect marine lower stern units in the event water were to be injested. They also confirmed that ALU can in fact be used in GL-4 and MT-1 automotive applications, and the product is labeled as such. So yes, the least expensive way to go is with a gallon of AGT and a quart of ALU.
maxinout93
Oct 27, 2015 01:29 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
4 door GT-R
Aug 22, 2015 07:50 AM
maxipower
Aug 21, 2015 11:10 AM
maxinout93
Aug 20, 2015 02:17 AM
