Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Fuel Power, Fuel Power, Fuel Power
Old Jan 13, 2005 | 09:42 PM
Free
I am somewaht new here, but have been a member over at BITOG for awhile and I keep seeing so many threads about SeaFoam, Lucas, techron, ect
Instead of answering alll these I thought to just start a new thread. Fuel Power and Lube Control are the best thing you could do for your engine. These 2 products are like no other on the market. Unlike other products mentioned these will remove carbon and keep it from returning. Using the above mentioned products may give you a false sense that something is really happening and if you use too much of those products they could be harmful. Ad FP to every tank and prevent carbon and improve emissions.
I got turned on to these products by Dyson Analysis and the guys at BITOG and I must say there is nothing like them.
Old Jan 13, 2005 | 10:24 PM
Jeff92se's Avatar
I'm needing a caw
Try to present some credible data. Kinda sounds like an ad
Old Jan 13, 2005 | 11:10 PM
S00NR1's Avatar
OU > *
Ya Jeff, this is the third thread where Free has advertised for Fuel Power/Lube Control. Sounds like someone who is only interested in selling product to me.
Old Jan 14, 2005 | 05:22 AM
mzmtg's Avatar
Minister of Silly Walks
Well, I took care of that little problem...
Old Jan 14, 2005 | 06:43 AM
Torkaholic's Avatar
Data? Recommend you go here: http://theoildrop.server101.com/ubb/...?ubb=forum;f=3 and do some comparisons of results. You really can't call all this info scientific data since there are too many "testers" and uncontrolled variables, but you can definitely see the trends.
In my wife's vehicle, insoluble contamination dropped from 0.5% to 0.3% from one interval to the next (almost same mileage and conditions). The first run had no Lubecontrol, the second did. Conclusive, no; strongly suggestive, sure. On my G35's first UOA, with LC, my insols were only 0.2%. Alas, I have no data for that vehicle without LC, but compared to other vehicles, and especially with a very young VQ35, this is an outstanding result.
Are either of these products magic potions? I don't think so, but I am gaining confidence that they are worthwhile additives.
No, I don't sell either, and I have no stake in the outfit that produces LC and FP.
Old Jan 16, 2005 | 11:38 AM
johnny2kgle's Avatar
These two products, lube control and fuel power, are worthwhile. I don't sell the stuff but I find them helpful. I am able to run 89 octane with the FP since it increases the potential energy of the fuel. The lube control is a great product to help Amsoil from thickening on an extended drain interval as well as lower the iron and lead that the VQ engine seem to throw off.
Older Amsoil formulations had the ability to absorb fuel dilution. It does not anymore since the natural solvency of gasoline was removed by the EPA mandates.
If this is not enough proof for the doubters, get a expert to interpret your next UOA.
http://www.blackstone-labs.com/dyson_analysis.html
Old Jan 16, 2005 | 06:08 PM
mzmtg's Avatar
Octane rating has nothing to do with "potential energy."
Do you even know what potential energy is?
Old Jan 17, 2005 | 05:54 AM
mzmtg's Avatar
Here's a quick refresher on potential energy for those of you that have forgotten high school physics class:
http://www.glenbrook.k12.il.us/gbssc...rgy/u5l1b.html
Here's a quick refresher on what octane ratings mean:
http://auto.howstuffworks.com/question90.htm
Old Jan 17, 2005 | 10:47 AM
As a matter of fact, I do. Fuel Power helps the gasoline burn more throughly with less blow by and is in a sense an octane booster. I have run 4 oz of FP with 89 octane and had no knocking or loss in fuel economy.
Old Jan 17, 2005 | 04:27 PM
kcryan's Avatar
hmmmmm no knocking mabye thats because you have a knock sensor?
Old Jan 17, 2005 | 06:01 PM
Torkaholic's Avatar
I don't think either FP or LC are magic potions, but I too have seen performance enhancement from them, in moderate degrees. In particular, in my previous car, a V-6 Camry, I had developed a strong, noticeable, and unpleasant ping on moderate to hard acceleration, even when using 93 octane fuel. With no changes to the car, climate, or conditions, other than adding FP, I noticed an almost complete elimination of this low-level version of knocking. The improvement started immediately upon the addition of FP, and gradually increased over about two tanks of fuel to a great end state.
And yes, the 1MZ-FE V-6 has knock sensors too. . .
By all means, don't use this stuff if you don't want to. I decided to give it a try, and I do like it.
Old Jan 17, 2005 | 06:32 PM
Well it knocked when I was running 93 octane with bad coilpacks and a ECM that needed reprogramming. The car will knock even with a sensor if you put 87 octane in it.
That is fine if you think this stuff is snake oil. The reason that premium is required is to eliminate knock which is partly due to deposits in the combustion chamber that cause preignition. Fuel Power solves that problem by raising the octane and burning the fuel more completely.
Old Jan 18, 2005 | 06:37 PM
caremd99's Avatar
I have been using FP for the last 6 months and I have noticed a difference. On the few occasions I had to use 87 octane it pinged much less than before. With the proper octane it helps make this vehicle that much sweeter to drive.
Old Jan 19, 2005 | 08:21 AM
Jeff92se's Avatar
I'm needing a caw
Is this stuff just an octane booster? Nothing new or innovative. In fact Seafoam also has some the same ingredients that up octane.
Old Jan 19, 2005 | 09:03 AM
Torkaholic's Avatar
I'm not really sure of what it contains. I does not appear to be primarily an octane booster, though it may have a moderate influence in that direction. I suspect it is mostly a cleaner, and that it mitigates pre-ignition by reducing deposits that may aggravate irregular burning of the mixture. My primary basis for this conclusion is that the positive effect (major ping reduction) I noted in my V-6 Camry (previous car) came on gradually over about two tanks of fuel. The product is also represented to have an upper cylinder lubricant property. I could accept this, as the product is obviously very oily and persistently so. If you get it on your hands, you've really got to wash them to remove the residue.
On a less serious note, FP does have a very pleasant odor (at least to me). Personally, I'm not inclined toward huffing, but if I was, this is the stuff I'd huff. Seriously though, I'd love to see a lab analysis to get a better idea of what's really in FP.
Old Jan 19, 2005 | 09:21 AM
mzmtg's Avatar
The manufacturer should be able to provide a MSDS.
Old Jan 19, 2005 | 01:43 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Pinging = detonation NOT preignition. If you had preignition from a hot spot such as a carbon deposit, your piston would be destroyed quickly.
An increase in octane would reduce the tendency of detonation, but have little affect on preignition.
Cleaners powerful enough to remove carbon deposits reduce the chance of detonation by restoring the optimal/lower compression the engine was designed to operate at. The deposits increased compression causing a tendency to detonate.
Old Jan 19, 2005 | 01:46 PM
IceY2K1's Avatar
BTW, just use the proper octane Chevron fuel and detonation causing carbon deposits wont be problem and you'll never require these "harsh" cleanings to restore the optimal compression ratio.
Old Jan 19, 2005 | 01:48 PM
Jeff92se's Avatar
I'm needing a caw
fuel power msds: http://www.fppf.com/msds/msds_FuelP.pdf
Almost 100% Glycol ether I don't personally know about this
Old Jan 19, 2005 | 01:56 PM
IceY2K1's Avatar
Strong fruity smelling solvent per GOOGLE search.
I don't think it's much of a octane increaser.
Old Jan 19, 2005 | 02:20 PM
CCS2k1Max's Avatar
Well, MSDSs are notable for giving the bare minimum or just giving misleading component information. "Glycol ether" isn't complete, especially since they don't provide a Chemical Abstract System registry number. This website says it's a family of ethers http://dangerousproducts.learnwithza...ouncil-135.htm
Old Jan 19, 2005 | 02:24 PM
Jeff92se's Avatar
I'm needing a caw
True BUT:
1) The Glycol Ether content was <= 97%. So what else could be in there.
2) MSDS sheets are only required to show the hazardous portions of the product. But this one should stage all of it's components as required by some states. ie.. New Jersey. But looks like this one is a bit outdated.
It's basicly a solvent. Not much going on here.
Originally Posted by CCS2k1Max
Well, MSDSs are notable for not giving the bare minimum or just giving misleading component information. "Glycol ether" isn't complete, especially since they don't provide a Chemical Abstract System registry number. This website says it's a family of ethers http://dangerousproducts.learnwithza...ouncil-135.htm
Old Jan 19, 2005 | 02:44 PM
CCS2k1Max's Avatar
True BUT:
Glycol ether is a family of ethers. There is no CASRN for just glycol ether. What they have is 95%+ of one of the glycol ethers, which one, they won't tell.
BTW, The MSDS has to include all the portions of the product above 1% (0.1% if carcinogenic) provided that at least one of the components is hazardous (I have seen some MSDSs w/ 90% water listed).
Old Jan 19, 2005 | 02:47 PM
Jeff92se's Avatar
I'm needing a caw
So it's made up of a family of Glycol Ethers. Are they all basicly solvents?
Old Jan 19, 2005 | 02:53 PM
CCS2k1Max's Avatar
My guess is that it's made up of one the glycol ethers (that's how I think they pull off the >95% component, but who knows, maybe they are really ballsy and it's a cocktail of glycol ethers plus other components at just below 1%).
Old Jan 19, 2005 | 03:21 PM
Torkaholic's Avatar
Yeah, I'm aware of the distinction you're drawing here, and I agree it's valid. Although it may not be a technically sound approach, I glump detonation and preignition into one mental category, which I think of as "abnormal combustion." I figure that if there's a little glowing lump of deposit in there, it may cause abnormal combustion via either the impromptu increase in compression ratio, via the hot spot (glow plug effect), or even perhaps both factors contribute. In any event, I'll never know exactly what happened. Having a stray cylinder head violently penetrate my hood might be a clue, but by then, it wouldn't matter if I did know, since then it's a bit too late to do anything but ensure that no one has been hurt by the shrapnel. In my here-and-there studies, I have come to believe that hot spot type ingition CAN lead to disastrous pre-ig, if bad enough, but that in milder situations it may be survivable. Not correct?
Old Jan 19, 2005 | 03:27 PM
Torkaholic's Avatar
I'm always amused by attempts to convert perceptions like smell or taste into words. "Fruity" is an interesting description of FP's smell, although not one that I would have chosen. I'd say its about 3/4 of the way from raw acetone to a really nice woman's perfume, if you can imagine such a concept.
Maybe the FP guys got clever and, figuring that most customers would be men, mixed in some "I want you now" human female sex pheromone. . .
Old Jan 19, 2005 | 03:29 PM
IceY2K1's Avatar
Not correct.
Detonation can lead to preignition eventually, but glowing carbon deposits/melted spark plug electrods cause preignition NOT detonation. Preignition is ABSOLUTE and will kill the engine in short time, but detonation while damaging can be withstood for long periods of time. You are talking about detonation previously NOT preignition. Just don't use preignition and you're pretty much correct.
Here read this to understand detonation:
http://www.streetrodstuff.com/Articl...ne/Detonation/
Old Jan 19, 2005 | 03:30 PM
IceY2K1's Avatar
Haha...I've never personally smelled it, that's just what one website said while another said sweet smell.
Old Jan 19, 2005 | 03:50 PM
Torkaholic's Avatar
Not correct.
A good read, thanks for the link. True preignition would be a bad, bad thing to have going on inside one's engine.
Old Jan 20, 2005 | 05:43 AM
This is a different fuel power. Here is an explanation below.
Question:
“I looked on the FPPF website and could not find a FP Diesel Treatment. It looks like this: FP but with green and blue lettering on the label and with the specific words "Diesel Treatment".”
Anyone know what this stuff is? Is it just regular FP?"
Answer:
“Not the same stuff. "LC20" is lubecontrol and "FP60" is what we know has become known as fuel power.
Jeff and Odis are trying to get the word out of the the lubecontrol fuel treatment formulas real name, "FP60".
I think that Lubecontrol, Inc used the Fuel Power name since the 50's but Odis did not own the formulas until the late 80's and thus someone procured it in that time.”
Here are the links for FP/LC.
http://www.lubecontrol.com/reports.htm
http://www.lubecontrol.com/faq.htm
Old Jan 20, 2005 | 10:28 AM
Jeff92se's Avatar
I'm needing a caw
Where are the msds information on both?
Old Jan 20, 2005 | 12:42 PM
I do not have the MSDS information on FP/LC. You might try service@lubecontrol.com to get some more information.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
leatherneck
Sep 30, 2015 09:16 PM
