Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Switching To SYNTHETIC
Old Apr 29, 2005 | 04:18 PM
Jace1283's Avatar
i have a 03, last oil change was when it was athe the dealership when i got it and its time for oil change. What do you guys use who have synthetic and what weight is it, i havnt checked the manual yet. Ill probly just get the mobile one synthetic. Just checking so i dont mess something up, any other relevant info is appreciated
I still cant believe how easy the paint chips, its like a scratch ticket!!! errr
Old Apr 29, 2005 | 04:22 PM
LA02MAX's Avatar
i use mobil 1 5w30, but it basically depends on where you're located.....i've heard the best things about mobil 1, which is why i decided to use it...
Old Apr 29, 2005 | 04:33 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
I have used Mobil 1 since new... 10W-30...
Old Apr 29, 2005 | 05:05 PM
MaximaPolak's Avatar
I used to use Mobile 1 5W-30 Synthetic but not I tried that new Quakerstate Horse Power ****. I dunno if there is a difference but the car runs fine.
Old Apr 29, 2005 | 08:40 PM
Mang's Avatar
For those of you who use Mobil 1 10w30, how often do you change your oil? I was thinking I could go longer than the standard 3000 miles.
Old Apr 29, 2005 | 09:00 PM
dmitry82's Avatar
I use Mobil 1 synthetic oil also!
Old Apr 29, 2005 | 10:02 PM
I still change it from 3000-4000 because I like to drive hard at times.
Old Apr 30, 2005 | 02:10 AM
Bluesbrekr's Avatar
Doctorate in Detailing
This thread will probably get moved to the Fuels and Lubricants forum. There's lots of good info there.
I use Mobil 1 5-30 and change every 5000 miles. I use the Mobil 1 filter, too. (the oversized one)
Old Apr 30, 2005 | 03:52 AM
Lontar1's Avatar
I change it every 5K miles...... and today it is time to change it....
Old Apr 30, 2005 | 09:51 AM
Bobo's Avatar
I'm thiinking about switching from dino to Mobil1 and use the Nissan OEM filter. However, I'm a low-mileage, mostly highway use, (non-daily) driver. Would a 5,000 mile 12-month oil-change interval be too long?
Old Apr 30, 2005 | 03:36 PM
kcryan's Avatar
#k for first time on synthetic, then 5k for the rest. i use M1 5w-30. Speaking of that new Q stuff i think i may get a quart and use it as deoderant, its heat activated like degree deoderant and it would be more cost effective to use than degree deoderant. Seriously though most wear occurs at cold start and this stuff clamis to be heat activated so im not sure if i trust it
Old May 1, 2005 | 01:07 PM
Epacy's Avatar
Unsuccesful STL Coordinator
Ditto. Although I think I changed it before 5000 miles, but definately after 3000. It is worth the money.
Old May 2, 2005 | 03:07 PM
01MaximaGle's Avatar
whats the need for synthetic in a near stock maxima seems like a waste of money to me
Old May 11, 2005 | 11:25 PM
biggy8481's Avatar
I put in the new Q stuff about a week ago... My max starts alot smoother than before... but I don't know what was in it before... but it returned the car to quiet running.
Old May 17, 2005 | 12:39 PM
yogi's Avatar
Mobil 1 synthetic oil....
Old May 19, 2005 | 01:04 PM
csnv's Avatar
can I switch to synthetic from regular oil after 55k miles?
Old May 19, 2005 | 02:02 PM
bladerunr's Avatar
Tests prove that syn is better in any age car (within reason) and it doesn't matter when you switch. check out bobistheoilguy.com for more info than you'll ever need.
I use M1 0w-40.
Old May 19, 2005 | 02:18 PM
csnv's Avatar
i'm in AZ, the car is I35, 55k miles, i'm planning on putting my first 10w30 in it. is it fine (or should i use 0w-40?)? when will i need the second oil change?
Old May 19, 2005 | 08:25 PM
aussie983's Avatar
5w30 or 10w30 should be fine for AZ
Old May 19, 2005 | 08:32 PM
aussie983's Avatar
Just switched recently to 5w30 at around 80K miles. Starts and runs a smoother. Engine seems to want to rev a lot easier too. Maybe a very slight improvement in gas mileage.
Old May 20, 2005 | 09:10 PM
kcryan's Avatar
im thinking of goint with m1 truck/suv 5w-40 any thoughts?
Old May 21, 2005 | 05:10 PM
Max Atlanta's Avatar
I use Amsoil 10w-30 and an Amsoil filter. I have put synthetic in from day one. Back in the mid 1990s I switched my wifes Plymouth minivan over to fully synthetic from dino oil at about 85,000 miles. Nothing bad happened...no leaks, runs, drips, etc. It ran well and got better gas mileage.
Old May 23, 2005 | 02:42 PM
00Max00's Avatar
M1 5w30, M1 filter, 5000mi OCI here
Old May 24, 2005 | 07:07 AM
Colonel's Avatar
Old Fuddy Duddy
AMSOil 5W-30, M1 Filter, 5000 OCI.
Max has been on Syn since 1500 miles, its at 42K now...but it sits a lot in the garage now.
Old May 24, 2005 | 09:58 AM
Virus's Avatar
Well, you can run at least 15k miles on either M1 or Amsoil before changing oil. Let's say you change the filter 2 times during that interval. Seems like a huge waste in money to use dino oil.
Old May 24, 2005 | 01:53 PM
bladerunr's Avatar
I don't think you can go wrong with any of the M1 oils. I may do the same.
gavin68
Sep 18, 2021 12:36 PM
mclasser
22
Nov 12, 2020 01:58 PM
AaronL
Aug 8, 2020 10:31 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
