Torque Converter
I've never heard of it. A full tranny flush will replace all the fluid while the car is running. That includes flushing the torque converter too.
Go to any Jiffy Lube and you can get a flush done for $90. $140 is a bit cheap for normal tranny fluid.
Originally Posted by cefiro8701
cheap means good right??they have a one year warranty..
Don't spend more than $100 for this service that takes 5 minutes to do. But keep in mind, that getting your tranny flushed is much better than just a normal drain and fill. If you haven't kept up on your tranny fluid changing, then I'd recommend you to get the flush. Then after that, keep up with your drain and fills every so often. You can do a drain and fill yourself about every 20K miles and you should be able to keep your fluid in great condition all the time.
cool...i was thinking about doing that...and they dont just pump..i actually saw them doing what they do...oh yeah and jiffy lube charges more in my area for some reason...i've looked into it many times before...
ivorton23
Sep 28, 2015 09:08 PM
carid
Sep 9, 2015 05:06 AM
