Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Switch to synthetic 0W30 oil
Old Jul 8, 2005 | 10:04 AM
  #41
njmodi's Avatar
Do I get a tax break?
I sent a question into SeaFoam support this morning about how long to leave it in the crankcase, and I got a not so useful reply. Here it is FYI:
Your question is easy.
The rule of thumb is " Change the oil when it is dirty "
The use of a gum / varnish melter ( Parts solvent ) in the oil will tend to make the oil dirty faster.
Because Sea Foam is a 100% pure petroleum product, you can put it in the crankcase ( only about 1/4 to 1/3 of the can - put the rest in the fuel ) and you can leave it there - but change it when it gets dirty.
A little vague - because "dirty" means they are going purely by the color of the oil...
Old Jul 8, 2005 | 10:06 AM
  #42
Jeff92se's Avatar
I'm needing a caw
Yes pretty vague as they can't just pick xxx miles. As all cars and all engines for that matter are a bit different.
Old Jul 8, 2005 | 10:09 AM
  #43
kcryan's Avatar
Ok ill admit i havent used it in about 6 months when i fed it through the brake booster.
However if my memory served me correctly it was green in color and quite thin almost similar to the viscosity of water. I could be wrong on that and if its thicker let me know.
Im not saying that this will kill your engine and ruin your car. It actually may help a fair amount with your problem.
Why is this not all over the net? Theres no proof without UOA's and on the three boards i frequent i've never seen a UOA of a car with SF, or a VOA of SF.
Could you use this in your oil? of course. Will it help your problem? most likely it will.
Will it cause higher levels of wear in your engine? I would say yes, but i could be wrong.
My main point here is that although seafoam may help with your problem, there are, in my opinion, better options AutoRX would do the trick nicely i bet and since this isnt too much varnish 1 or mabye 2 treatments would fix the problem nicely i bet. However if it doesnt...Get your money back... Lube control may be able to do the same, If you choose to use LC there are a variety of routes you could use
1) LC Flush as detailed on Lubecontrol.com in the lab report(this would not be my choice as it would be comparable to a seafoam flush) However i would reccomend this over seafoam just based on the knowledge that i know more about this product and i trust it more.
2) This is what i would most likely do. I would buy a HEDO(Heavey duty engine oil) usually avaible in 40 weights. I would bet Delo or Delvac would be good choices. But if your serious about doing this i can check on BITOG for there reccomendations. I would use this and a good filter at your next oil change. i would also add 2,3,or 4 ounces of LC per quart of oil. also add 2 or 3 ounces per 1000 miles of driving. Change this after 3k miles(and mabye do the filter after 1500 or so) Im not really sure how many of these treatmants would be needed to get the engine nice and shiny again but you could take a look after each oil change under the oil cap. I wouldnt reccomend this for the winter, however depending on how much you drive you might be done by then or you could just go back to a good 30 weight with similar doses of LC. for the winter and back to HDEO for summer.
One question, does this engine burn oil? if so there is only one reccomendation i can make. AutoRX.
theres my reccomensations
Old Jul 8, 2005 | 10:10 AM
  #44
kcryan's Avatar
Originally Posted by Jeff92se
Then again, I doubt the seafoam would reduce the viscosity of a 10w or 5w down to a the 0w that you fellas want to run.
I could care less about the cold viscosity its the operating viscosity that matters to me.(30wt-20wt is a big deal to me)
Old Jul 8, 2005 | 10:12 AM
  #45
kcryan's Avatar
Thats a quite vague response......unless you do a UOA every few hundred miles you cant tell when your oil is dirty.........
Old Jul 8, 2005 | 10:15 AM
  #46
njmodi's Avatar
I agree with you on this. There is no way they can give a fixed number. Too many variables.
Old Jul 8, 2005 | 10:19 AM
  #47
kcryan's Avatar
However if you combine this info with the back of the can saying "WORKS AND PERFORMS INSTANTLY" then wouldnt that mean you should change you oil right away??
Old Jul 8, 2005 | 10:21 AM
  #48
kcryan's Avatar
your right, however i would expect a range, for instance somthing like 5-20 minutes of idiling, or 100-200 miles of driving or 1000-3000 miles... somthing to use as reference
Old Jul 8, 2005 | 10:22 AM
  #49
Jeff92se's Avatar
I'm needing a caw
I also contend that seafoam won't reduce a viscosity of the operating either. If it probably won't reduce a 5 to a 0, then why mention a 30 to a 20?
Look, if you have some reference to documented damage from either the net or Bitorg, fine. But SF has been around for sometime. Bitorg as been around for some time. I would think Bitorg would have crutinized this product at least once or twice and that would have given you ample examples to make your case.
Old Jul 8, 2005 | 10:24 AM
  #50
Jeff92se's Avatar
I'm needing a caw
You won't see 5-20 of idling. That is an engine flush interval. Which SF is not and has been stated as not being as such.
Old Jul 8, 2005 | 10:25 AM
  #51
kcryan's Avatar
BITOG may very well have some thread proving my point or dis proving my point, im just not going to look around for it. im also assuming theres a reason why it is pretty seldomly reccomended on BITOG......FRAM has been around a long time too... enough said.
Old Jul 8, 2005 | 10:26 AM
  #52
Jeff92se's Avatar
I'm needing a caw
When does the AutoRX work? 10 min after pouring it in? 10 miles? 50 miles?
Old Jul 8, 2005 | 10:27 AM
  #53
kcryan's Avatar
I never said it wouldnt make a 5w into a 0w or somthing along those lines, it may very well do that, what i said is that i dont care if it does that. There is a large belief on BITOG that no oil is thin enough on start up, so again i could care less about the cold viscosity, its the operating temp viscosity that concerns me.
Old Jul 8, 2005 | 10:28 AM
  #54
Jeff92se's Avatar
I'm needing a caw
Where there you go. I'll just contend that you really have no basis for your opinion.
Fram has been around for a long time. BUT it's also been well documented that their standard filters are inferior. I can go right in this section and pull up a crappy Fram filter cutaway. But you cannot do the same with SF correct? Still enough said?
  #55
kcryan's Avatar
Sorry i was just throwing numbers out there, i meant to put 30k-50k in there at the end to show extremes of both sides, i just wanted to give examples of what they could've said
Old Jul 8, 2005 | 10:30 AM
  #56
Jeff92se's Avatar
I'm needing a caw
But didn't you contend that thin oil is bad? So thin oil is good during startup but not during operating temp conditions? You are not quite making sense.
I know what you mean. BUT what you are stating is not correct.
Old Jul 8, 2005 | 10:32 AM
  #57
Jeff92se's Avatar
I'm needing a caw
What you should be stating is no oil is thin enough AND still maintains the proper film thickness during start up.
  #58
kcryan's Avatar
Hard to answer question but i would bet total for a case like this combining all phases and using 2 bottles which may not be necessary in this case it would be about 7,000 miles, for a 1 bottle appilication it would be about 3500 miles.
Old Jul 8, 2005 | 10:36 AM
  #59
Jeff92se's Avatar
I'm needing a caw
So it takes 3500 miles for it to start working? Or does it start to work "instantly" after pouring it in?
Old Jul 8, 2005 | 10:38 AM
  #60
kcryan's Avatar
Im not going to say thin oil is bad, i just dont like it in VQ's it has it uses but our engines like thicker 30 weights or thinner 40 weights.
Yes, during start up thin oil is good so it can flow quickly from the bottom of the pan to all the parts of the engine. If it was thick at start up all of the parts would be running for a longer time with the minimal protection that the film of oil left on parts provides..... this is why they make xW-x0 weight oils, so they are thinner on start up.........
And yes i know my wording probally sucks i tend to talk as if everyone knows what im talking about when not to many do......
Old Jul 8, 2005 | 10:39 AM
  #61
kcryan's Avatar
yes i forgot to say "to a certain extent" like i always do when saying thicker is better, the same goes for thinner on start up.
  #62
Jeff92se's Avatar
I'm needing a caw
How do you know the VQ likes a particular weight of oil??
Old Jul 8, 2005 | 10:41 AM
  #63
kcryan's Avatar
It is constantly working but it works much slower than any other cleaner i know of. The real cleaning will be recognized in the rinse phase which is after 1500 miles. at the 1500 mile point you change the oil and put in a regular non synthetic oil and new filter w/o RX and you let the crap begin to come out of your engine..
Old Jul 8, 2005 | 10:42 AM
  #64
kcryan's Avatar
UOA's UOA's UOA's UOA's and reccomandations.
Old Jul 8, 2005 | 10:47 AM
  #65
Jeff92se's Avatar
I'm needing a caw
Which you happen to have correct? I can't see how a minor difference in viscosities (especially broken down within the same viscosity class) could be consistantly shown to have a measurable benefical effect on all VQs of varing mileage and condition.
Old Jul 8, 2005 | 10:48 AM
  #66
Jeff92se's Avatar
I'm needing a caw
I specifically asked when it STARTS working.
Old Jul 8, 2005 | 10:54 AM
  #67
kcryan's Avatar
got me ask frank..id bet the seccond its put in
Old Jul 8, 2005 | 10:55 AM
  #68
kcryan's Avatar
A 30 weight oil could be a SAE30 or a SAE39 or anywhere in between either way it qualifies as a 30 weight.
Old Jul 8, 2005 | 10:59 AM
  #69
Jeff92se's Avatar
I'm needing a caw
May I see some data that supports that one particular specific viscosity is better than another? Especially if it's falls under the same 30 weight label?
Old Jul 8, 2005 | 11:04 AM
  #70
kcryan's Avatar
Feel free to search BITOG esspescially in the UOA library try using "VQ" as your search.
Also in the main oil forum theres been a bunch of reccomendations saying that the VQ's like heavier oils....Most have been in reference to the VQ35 but the same general rule holds true for VQ30's as well
There was also a past thread on this site where somone (I believe silver 00 max) mentioned that VQ's would like GC because it is thicker
Please post any links you find if you dont mind.......
Old Jul 8, 2005 | 11:08 AM
  #71
Jeff92se's Avatar
I'm needing a caw
I was the one asking you.
Old Jul 8, 2005 | 11:35 AM
  #72
Jeff92se's Avatar
I'm needing a caw
I ran "seafoam" though their search engines. Couldn't find any real evidence of Seafoam being bad. The ONLY reference I saw was from Frank which didn't actually specifiy nout using seafoam but just suggested using products with the same chemcials as AutoRX.
There WERE comments that said Seafoam was bad. But again, they were mostly opinion and were unfounded. ie.. mixing up Seafoam and engine flush.
I even saw YOU post directly in a thread discussing Seafoam.
Old Jul 8, 2005 | 12:02 PM
  #73
kcryan's Avatar
Not suprising, i've posted in many threads there
Old Jul 8, 2005 | 12:03 PM
  #74
kcryan's Avatar
Asking me to find information for you?? my current rate is $175 an hour, however it is negotiable, let me know what works for you.
Old Jul 8, 2005 | 12:05 PM
  #75
Jeff92se's Avatar
I'm needing a caw
Again inocorrect. I was asking you to back up your statements.
Old Jul 8, 2005 | 12:09 PM
  #76
kcryan's Avatar
Fair enough i suppose...
http://theoildrop.server101.com/ubb/...=002950#000000
Seccond post down.
I wont say i told you so......or will i
Old Jul 8, 2005 | 12:10 PM
  #77
kcryan's Avatar
the whole thread is worth reading
Old Jul 8, 2005 | 12:14 PM
  #78
Jeff92se's Avatar
I'm needing a caw
Um yes. "bunch of Seafoam". How very scientific.
Old Jul 8, 2005 | 12:18 PM
  #79
kcryan's Avatar
http://theoildrop.server101.com/ubb/...=002896#000000
http://theoildrop.server101.com/ubb/...=002854#000000
Seafoam has it's uses....to be used to clean the pistons and valves.
MMO has it's uses....for r/c aircraft.
LC/auto-rx are in a class of their own.
Theres many more on there i just really dont feel like looking
The above quote from user "Darkdan" sums it all up in my view.
If he was talking about somthing to suck up with the intake to clean valves and such id reccomend either seafoam or distilled water, but thats what hes asking...
Old Jul 8, 2005 | 12:21 PM
  #80
kcryan's Avatar
Copper and lead 3x normal averages???????????????????????????
Thats scientific enough for me. Mabye he added a little too much or somthing there is a possibility of that but 3x the wear on the bearings is far to large of a chance for me(and others i hope)to take on a car as good as this, if this were a winter 350$ beater id say go for it with seafoam, but this car deserves better.
