Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
oil change: 99 auto w/ 99k miles, what oil to use?
Old Jul 7, 2005 | 02:09 PM
sook's Avatar
its time for an oil change, the first one since i bought the car. its got 99k miles. its an autotragic. i dont drive it hard or take it to the track, but i dont pussyfoot it either. what oil should i use? brand, type, synthetic, etc. i dont know anything about the differences really, other than that there are! lol
thanks!
Old Jul 7, 2005 | 02:14 PM
Loe max's Avatar
Do you know which type of oil the car used previously? If not, its safe to stick with regular dino oil.
Old Jul 7, 2005 | 02:22 PM
Bobo's Avatar
I would recommend Castrol GTX 5w30 in dino oil or Mobil 1 5W30 in synthetic. Buy a good quality oil filter such as Nissan OEM, Purolator PureOne or WIX. Do not buy a Fram filter. You could use a 10W30 in Arizona but I would be inclined to stick with the Nissan preferred weight which is 5W30 for all temperatures.
This should be posted in the Flluids & Lubricants forum by the way.
Old Jul 7, 2005 | 02:27 PM
MAXRB8's Avatar
Okay beat me up here but what's wrong with Fram filters? Just trying to help you pad your post whoring
Old Jul 7, 2005 | 02:37 PM
1FSTMAX's Avatar
mobil one..
Old Jul 7, 2005 | 02:38 PM
Sentinal's Avatar
Its been proven that FRAM filters are the crappiest filters that you can get. Just go into the Fluids/Lubricants section and read the stickies. Just stick with Mobil-1 oil and filters, cant go wrong with them.
I just changed my oil yesterday from dino to synthetic and used Mobil-1 SuperSyn Extended Performance 10w30 and a Mobil-1 M1-110 oil filter. And I have an autotragic too and 173k Miles. I also drive pretty hard 60% of the time, in 80-95 degree temp. So far no leaks
Old Jul 7, 2005 | 02:42 PM
Bobo's Avatar
First its my good buddy Frank Fontaine taking a daily swipe at me and now its you.
The member following your post beat me to the punch. All I can add is Fram filters = Altezzas, lol!
Old Jul 7, 2005 | 02:50 PM
TurTLe*'s Avatar
Castrol GTX 5w30. is that a pure dino or a semi blend? I seen it at store going for about 2.19-2.49. Compared to the normal oil i get which is like 1.29, i know 5.00 are for syn. so are the Castrol GTX semi blends are pure dinos. I'm looking into running Castrol GTX 5w30 on my first oil change with this maxima.
Old Jul 7, 2005 | 03:09 PM
Bobo's Avatar
It's a pure dino and from what I've seen is most highly recommended for dino juice on this website.
Old Jul 7, 2005 | 04:54 PM
chenzarino's Avatar
it's normallya best practice to stick with the same type of oil that the car has been running on, dino or syn.
Old Jul 7, 2005 | 05:51 PM
konak85's Avatar
+1...............
Old Jul 7, 2005 | 08:50 PM
TurTLe*'s Avatar
yea this site has GTX highly valued almost right behind mobil 1. i dont feel like spending $5 a quart on oil. so i'ma look at GTX. Any place that carries it less then 2.19/quart.
Old Jul 7, 2005 | 09:28 PM
siballiance's Avatar
I always Use Mobil 1 and i have been running for long time
i over drive 200 miles and it dosent look black
i did a little test
but i take a good car of my maxima
Old Jul 8, 2005 | 01:27 AM
Sniper's Avatar
Look for a sale. Most auto parts stores will run a sale now and again on Castrol. When it goes on sale, buy a case or two.
Also, 5W-30, I use a Wix filter, but you can usually find a filter at the dealer for about the same price. I've seen fram filters come apart for no reason only a few miles after an oil change.
Old Jul 8, 2005 | 05:09 AM
mmlloo's Avatar
Got a similar question. This is my first time posting, and I apologize if this question has been asked before. My 98 SE has about 98k miles. I have been using mobile one from the beginning and stopped at about 85k miles. I have been going to the local Nissan dealer to get their $19.99 regular oil change since then. While I was cleaning out my garage last week, I found another 4 qt of mobile one. Not wanting to waste the oil, I am just wondering if I can switch back to using mobile one for one more time and then go to regular oil again?
thank you.
Old Jul 8, 2005 | 06:20 AM
Bobo's Avatar
The first mistake you made, mmlloo, was going to the stealership for their oil change special. I trust you were using Mobil 1 synthetic, were you not. Then you started using whatever crap bulk dino the stealer through in. Now you want to go back to Mobil 1. If it is in fact the synthetic, use it, and stay with it. Look for some on sale, buy the Nissan OEM filter and do your own oil changes.
My local stealership uses Pennzoil a lot of the time, which has paraffin in it, and is crap.
Old Jul 8, 2005 | 09:26 AM
mmlloo's Avatar
Yes, I was using Mobil 1 for the 1st 7 years of the Maxima and always OEM filter and crush washer. So it is ok for me to switch back to Mobil 1? I wasn't sure if it's ok to go back and forth between synthetic and regular oil.
Old Jul 8, 2005 | 05:00 PM
Bobo's Avatar
By all means, switch back to Mobil 1.
Old Jul 8, 2005 | 09:20 PM
Jeff92se's Avatar
I'm needing a caw
In the stickies
http://forums.maxima.org/showthread.php?t=227996
thanks!
Old Jul 8, 2005 | 09:45 PM
kcryan's Avatar
i did a little test
What do you mean overdrive?
Old Jul 9, 2005 | 07:42 AM
JwaxMax99's Avatar
i did a little test
Ah, what are you saying...?
captchaos
Mar 15, 2016 12:18 PM
markevans999
Oct 25, 2015 08:27 AM
kjlouis
Oct 3, 2015 05:29 AM
LtLeary
Sep 14, 2015 12:33 PM
crazyespn
Sep 3, 2015 01:30 PM
