Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Oil Filter
Old Nov 12, 2005 | 04:39 PM
  #41
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Originally Posted by Virus
I used the M1-105 up until 50k and then switched back to the M1-110 after finding the psi for the bypass is different. Will that matter? Probably not, but the M1-110 is doing a fine job. I am curious to see some testing results of the new Amsoil Ea filters. They have similar specs to the Mobil 1.
Calibration of the bypass valve only comes into play if the pressure drop across the element is greater than the opening pressure of the BP valve. If the valve is calibrated to open under too little pressure, then you are needlessly circulating unfiltered oil. If it's calibrated too high, you could potentially deprive the engine of oil if the filter were to become restricted/clogged.
The new AMSOIL EaO filters are advertised as be very efficient, durable and they boast a tremendous capacity as they employ new nanofiber technology. I realize that most people won't do this, but the recommended change interval for these filters is 1 year/25,000 miles. The recommended application for the Maxima is the EaO-13. The good news is that the EaO-13 is nearly 1 inch longer than the previous SDF-13, putting it roughly the same size as the 9E000 OEM filter. I intend to order one of these in the near future and post some pics side-by-side with an SDF-13 and OEM filter.
Old Nov 14, 2005 | 03:47 AM
  #42
Virus's Avatar
Talkinghorse, 1 inch longer actually makes it the same size as the M1-110. I was excited to read about Amsoils new EA filters. They are roughly the same price as the M1's. I must admit, I get a little miffed when people state, "I purchase Mobil 1 because it's easier to go to the store and buy it". Personally, I find it easier to either call you or since you were nice enough to include a preferred customer with my last order I can just place my order over the internet and have it at my doorstep within 2 days. Normally it's here the next day since I'm within 2 hours of a distribution facility.
Old Feb 6, 2006 | 06:55 PM
  #43
zgrm100's Avatar
gues where can I get the OEM 9000 filter or watever online for 25$ off and free shipping?
Old Feb 7, 2006 | 04:42 AM
  #44
Jibberish18's Avatar
Purolator Pureone. Reason? Fairly cheap, excellent filtration ability and quality, love Purolator products.
Old Feb 22, 2006 | 08:15 AM
  #45
boondoxmax's Avatar
I used it for the first time a month ago and I love it. I've tried them all.
Mobil 1- very good, but to expensive
Bosch- like alot and use them more than anything else-good price
Fram-hell no won't let it touch my car
Pureone are nice price and has the best filtration of any filter. Only problem is PEPBOYS is always outta stock. HAve to buy in bulk
Old Feb 22, 2006 | 07:59 PM
  #46
GimmeTorq's Avatar
For the price, Purolator, NAPA Silver (Wix) or Nissan 90E00... They are all good ones... Take your pick.
Old Oct 14, 2006 | 02:32 PM
  #47
VQuick's Avatar
Chassis Freak
What would people recommend for the best short filter (2.5 inches long) if the OEM short filter is crap? How long is the M1-105 and how expensive is it?
Old Oct 14, 2006 | 03:42 PM
  #48
glenmoormax's Avatar
10 psi
mobil 1 or the k&n if its on sale.
Old Oct 15, 2006 | 06:03 AM
  #49
What change intervals to you intend on using? If you are going to change it every 3k, then just about anything will work. The OEM, Purolator Pure-One, WIX and NAPA Gold are very good filters for up to 7500 miles. If you are using synthetics for extended drain intervals and/or just want a top-tier filter, the M-1 Extended Life or AMSOIL EaO should be considered. These premium filters are generally more efficient; they have higher capacity; and the medium is such that it will not degrade from the hot oil running thru them. The AMSOIL EaO is advertised as being the most efficient filter on the market and it can be used for up to 25K or 1 year of service.
my03maxima
Jul 28, 2024 07:40 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
Justin Kroll
Oct 1, 2015 07:03 PM
