Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Bigger oil filters
Old Sep 20, 2005 | 10:16 AM
sky jumper
Bigger oil filters
I believe all of the recommended oil filters for the VQ30 are of the small diameter variety (and some are the short kind as well). are there any large diameter or large capacity filters that fit our engines?
from my recent research, it seems that a larger filter will increase flow and help prevent the bypass valve from opening. I'm also planning an Auto-RX cycle and want the biggest filter possible to catch all the crud.
Old Sep 20, 2005 | 04:31 PM
Virus's Avatar
It's all in the sticky on the top of the forum. There are quite a few. Keep in mind that nobody knows what the psi of the bypass valve is rated at with the bigger filters. Amsoil is 2 or 3 psi more on the oversized filter than the one they recommend.
Old Sep 25, 2005 | 05:46 PM
Weimar Ben's Avatar
Helicopters! Money!!!
The stock filter is the exact same filter that is used on a Honda CBR600.
Old Sep 26, 2005 | 08:29 AM
sky jumper
update: I've been doing a bit of research on this, and here's what I've found so far. this applies to 4th gen VQ30s only.
the following "oversize" filters also fit the VQ30:
- M1 104
- Wix 51334 and comparable Napa Gold 1334
- STP 2808
- Autozone Valuecraft 2808 (same size as M104, STP, and Wix. fittment verified by putting it on my car).
these are "oversize" in the sense that they have a larger diameter than OEM, however, they are a bit shorter.
the question at this point is - do they actually have a larger filter media? soon to be verified when I cut open the 2808 and an OEM 9E000 and compare.
NOTE: the M104, STP, and AZ 2808 all appear to be the exact same filter. IN FACT - I also looked at the M105 (larger OD than M104) and out of 6 filters on the shelf, 4 of them had STP 3950s in the box!! now you might say someone switched them to get an M105 at the STP price - BUT, when I looked at the filters in the STP3950 boxes they were slightly different (the M105 and "M1-STP3950" were much heavier than the 3950s in the STP boxes - and, the M105 and "M1 STP3950" appeared to be exactly the same, with the same thread end BPV, while the "real" STP3950 had a closed end BPV). this makes me believe that these M105 boxes were in fact shipped with STP filters in them - if someone just switched them at the store the 2 STPs would be the same, but they are not!
I bought both the real STP3950 (which will be free after rebate) and the "M1 STP3950" (but of course didn't pay the M1 price - just the $2.89 STP price) - I'll be cutting them both open soon and will post pictures soon...
Old Sep 26, 2005 | 10:04 AM
scopium
i use K&N its a bit expensive but a bit larger ( longer)
my03maxima
Jul 28, 2024 07:40 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
Justin Kroll
Oct 1, 2015 07:03 PM
