Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
View Poll Results: Is it risky to change to synthetics at 77000 miles?
I wouldn’t do it
16.00%
Change tranny oil but stay with standard motor oil
8.00%
Change engine oil to synthetic but use standard for tranny
8.00%
Yea, change both to synthetics!
68.00%
Voters: 50. You may not vote on this poll
Synthetics, risky or not
Old Oct 17, 2005 | 05:12 PM
  #41
Bobo's Avatar
Syn-blend is only about 10% synthetic oil and is a waste of money. Blend your own mix at higher concentrations of synthetic oil.
Old Nov 25, 2005 | 02:33 PM
  #42
Fr33way™'s Avatar
Wild for Width
I use dyno for crankcase and MT-90 full syn. for gear oil because of the improved shifting.
Old Nov 25, 2005 | 04:02 PM
  #43
konak85's Avatar
Originally Posted by randy021186
hey i am having this problem also i want to switch to full synthic, i am at currently @ 70000 miles and the last guy who did my oil change at some lube said i need a flush, now after driving a couple of miles my oil is dark ......as for the tranny the oil is red and i am scared to do a flush ....is there any way to clean the engine without damaging anything.....as for the tranny i just keep changing the fliud 15-20k miles
Do the auto-rx leak treatment before switching just to be safe. It also cleans and flushes the engine. This is what i am doing before i switch. BTW, i have 146,000miles. auto-rx.com
Old Nov 25, 2005 | 08:35 PM
  #44
Bobo's Avatar
Old Dec 5, 2005 | 08:54 AM
  #45
SS427's Avatar
Originally Posted by DrKlop
The only thing that scares me is the possibility on leaks. Do you guys think I should go for it or not?
The car got 77k miles, before I got it 4k miles ago it was driven in Connecticut.
Your engine will not leak from using Mobil synthetic . In fact it can help clean the seals , especially the rotational front and rear main seals so they will function better over the rest of the cars life . It will also slowly clean other engine internals so no need to flush the engine before switching over to it .
The Mobil website FAQ states when switching not to go to full extended intervals until the synthetic has been used 2-3 intervals . In saying that , they mean the oil has "cleaning abilities " . Also , Mobil paid a nationally known seal company big bucks to test the compatability of their Supersyn synthetic before it was first announced . The stuff is good for the go in that respect when used in modern engines .
Was Mobil going to be the synthetic of choice for your uses ?
mclasser
22
Nov 12, 2020 01:58 PM
Fbana41
Aug 29, 2016 12:18 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
pjgreek
Sep 9, 2015 09:30 PM
flu2000
22
Sep 2, 2015 07:29 AM
