Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
BG Air Intake Cleaner
Old Jan 23, 2006 | 04:27 PM
Kolyan's Avatar
in Directions For Use it says: clean TB with half of can, spray into throat working butterfly back and forth. Start engine and spray other half into throat while engine running.....
is it a good idea to spray INSIDE? i thought u only supposed to clean the build-ups outside, no?
Old Jan 27, 2006 | 05:07 PM
Kolyan's Avatar
anyone know this ???
Old Jan 27, 2006 | 06:17 PM
MaxBoost925's Avatar
Drug Money
Don't spray into the motor, it starts running eratically... just dont spray into the motor.
Old Jan 29, 2006 | 07:09 PM
aussie983's Avatar
Ive sprayed inside it and its been fine.
Old Feb 28, 2006 | 10:17 AM
Tfvesquire's Avatar
You can spray it inside the TB all you want, in fact, it does a great job of getting a lot of the carbon deposits moved down towards the cat and out the rear. While the butterfly valve is wide open, spray the cleaner inside and use a toothbrush to break the deposits loose. I haven't tried the Sea Foam treatment, because I've read mixed opinions about it damaging the O2 sensors.
Anyway, do not spray any cleaner in the TB WHILE THE ENGINE IS RUNNING!! You will throw all kinds of codes. Once you are done spraying inside, reinstall the intake hose and MAF sensor and fire the engine. You will have to lightly press the accelerator down (don't floor it!!) to get the engine to clear its throat. Then give a couple of good throttle presses to clean out the carbon.
Good luck with that!!
TallTom
57
Oct 14, 2025 05:16 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
