Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
octane booster
Old Sep 1, 2006 | 09:56 AM
ToneBoat923's Avatar
octane booster
So after reading the mannual It says the max likes higer octane (91) I just filled up with 87 ....so would It do any harm to put in some octane booster? When i start the car in the morning sometimes the engine sputters and wants to stall unless I give it gas....So I'm thinking it sthe gas....unless you guys think its something different?
Old Sep 1, 2006 | 10:30 AM
GBAUER's Avatar
water in the gas or bad fuel or clogged injectors or bad coil pack or bad plug or...
shall I go on?
Octain boost will fix the low fuel issue, but the only problem you should see is knocking, not stutterin to my knowlege. You have something else going on as well.
Old Sep 1, 2006 | 11:35 AM
TXT-1's Avatar
Agreed, I doubt octane booster will fix this. Seafoam it.
Old Sep 1, 2006 | 01:38 PM
GBAUER's Avatar
Originally Posted by TXT-1
Seafoam it.
uh, no. Get some iso-propal alcohol in the gas tank to mix the gas and water again (ethanol attracks water and at .5% water, the ethanol and water separate out and sink to the bottom of the tank where your pump is sucking).
Old Sep 1, 2006 | 05:23 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
octane boosters..... waste of money.... just run the car with 91+, also might want ot flush your injectors,.....
Old Sep 1, 2006 | 06:12 PM
spencediggy's Avatar
octane booster did nothin for me....im runnin 93 octane since i got the car n still pinging.....
but i got the dealership to swap the engine for a new one.
Old Sep 1, 2006 | 06:17 PM
NmexMAX's Avatar
dot dot dot ...
Are you saying IPA is ethanol?
Isopropyl > iso-propal. (IPA)
IPA =/ ethanol
Old Sep 1, 2006 | 06:34 PM
Kevlo911's Avatar
Kevlo for President
drfuelmax
mmkay?
Old Sep 1, 2006 | 06:44 PM
NmexMAX's Avatar
dot dot dot ...
mmmk
Old Sep 1, 2006 | 08:11 PM
beancooker's Avatar
If you add up the cost of a decent octane booster (not the 99 cent store s**t) and divide that by 15 (the average gallons needed when the idiot light comes on) you'll see it's cheaper to pump in premium!
Old Sep 1, 2006 | 08:23 PM
VqMoNsTeR's Avatar
Octane booster is garbage. Even though gas is $100 per gal. Its not worth messing up your car to save a few bucks. You will be needing what you saved to fix it...
Old Sep 1, 2006 | 08:45 PM
SoonerFan's Avatar
Cletus
seafoam will fix anything
Old Sep 2, 2006 | 10:36 AM
Lontar1's Avatar
will it fix my headache...
Old Sep 2, 2006 | 10:39 AM
NmexMAX's Avatar
dot dot dot ...
Don't drink so much...
Old Sep 2, 2006 | 11:52 AM
Lontar1's Avatar
cann't stop that....... hehehehe
Old Sep 2, 2006 | 11:56 AM
NmexMAX's Avatar
dot dot dot ...
12 pack of Bud waiting for the tranny fluid to drain...
Your filter change write up > *
Old Sep 2, 2006 | 01:09 PM
I think ill just throw some 91 in there thants for the help guys
Old Sep 2, 2006 | 01:50 PM
CaTalyst.X's Avatar
(WARNING, COMPTONSPEAK)
w3rd
Old Sep 2, 2006 | 10:10 PM
SilverMax_04's Avatar
You did not say how many miles you have on your Max. There is a chance your fuel injectors are partially plugged. I believe in giving my injectors a cleaning every 7.5K miles by running a bottle of Techron through them (blended into a full tank of gas) just before I change my motor oil (synthetic). That would be my first line of attack on this problem.
If you are not getting pre-ignition (knocking), then the 87 octane is probably not the problem. I run regular in my Max all the time and have no problems -- even run 85 octane here at 6 K feet elevation. In my 04 owners manual it says that regular gasoline is OK to run in the 10.3 to 1 compression ration VQ engine. Given that your VQ is only 10.0 to 1 -- this should also hold for your VQ.
If you frequently race and or call for WOT, you should run only premium gasoline in your VQ. Otherwise regular is fine and appears to give slightly better gasoline mileage when cruising (not stop and go) on the interstates.
Old Sep 3, 2006 | 06:06 AM
Bobo's Avatar
When was the last time you changed your fuel filter?
Old Sep 3, 2006 | 01:29 PM
The fuel filter could be the problem. But this filter will be more of a problem if you call for WOT (wide open throttle). If the filter is the problem, the engine will sputter and not run right because the filter is starving the engine for fuel. Try it and see what happens.
MichMaxFan
Sep 30, 2015 09:18 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
JoshG
51
Sep 21, 2015 10:41 PM
imported_Nismo_max
Sep 20, 2015 08:19 AM
sdotcarter
Sep 2, 2015 09:53 PM
