Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
synthetic oil...............
Old Oct 16, 2006 | 07:49 PM
ktranne's Avatar
NOOB
hey guys, my brother is a member of another Nissan and his friends told him that using "fully synthetic" motor oil will make the gaskets leaks oil later. Wonder what you guys think? I have a 00 and always using "fully synthetic" oil.
Old Oct 16, 2006 | 08:20 PM
d00df00d's Avatar
Old enuf to pick his own gears
If you ALREADY have seals that are worn, synthetic oil will expose them sooner because it will leak more readily. That is all. Synthetic oil does not actually harm seals.
Old Oct 16, 2006 | 11:05 PM
Ceasars Chariot's Avatar
Old Maxima Legend
yeah not sure what i have to say applies, but i switched to 5w-30 synthetic at around 160,000 miles. Then started to notice the engine was leaking a bit and burning it too. at least a quart every 3000 miles. So this oil change I went with a 10w-30 and will see how it goes. No spots on the garage floor so far and its been about a week. i dont know much about it, but it appears running synthetic isnt going to work for me ?
Old Oct 16, 2006 | 11:36 PM
d00df00d's Avatar
Is the 10w-30 synthetic?
Old Oct 17, 2006 | 11:06 AM
Atl92Se's Avatar
only if it says so on the bottle when you buy it.
I have always used 10-30 for all my Max.
Old Oct 17, 2006 | 11:07 AM
d00df00d's Avatar
I know that...
I was asking if the 10w-30 that Caesars Chariot says he switched to was synthetic.
Old Oct 17, 2006 | 02:27 PM
Bobo's Avatar
Time for two trials of AutoRX. Caesar.
Old Oct 17, 2006 | 03:05 PM
SilverMax_04's Avatar
In the past I owned an 86 Celica that I bought used. The engine burned synthetic oil like it loved the diet. I switched back to dino oil and the oil consumption went down about half to about a quart every 6 K miles (the oci I was using at the time). In both instances I was using 10W30 weight oil. I regretted buying that car used, and have never even looked at another used car. There were other problems with the sun roof, etc. But there were no noticable oil leaks on the garage floor from either oil.
Old Oct 18, 2006 | 05:27 AM
04BlackMaxx's Avatar
If I did my own oil changes I may have went with synthetic, but my only reason would be prolonging the lift of the engine...Ive driven 64,000mi since new on dino with 3,500mi changes done religiously, ive heard from mechanics that this is all it takes to get the most from this motor.
Old Oct 18, 2006 | 11:40 AM
04Black,
You are certainly safe doing this. If you are using a good dino oil like Castrol, I would consider pusthing your oil change interval to 5 K miles. Check the stickies here for the best dino oils.
Old Oct 26, 2006 | 06:52 PM
gtp2k1's Avatar
I have used Mobil 1 for a long time...in virtually ever car I've owned.
I love it.
Woo hoo! My 15th post.
Dean
Old Oct 28, 2006 | 03:50 AM
maximamaxy's Avatar
I've used shell fully synthetic 10w-40 for the past 4 years and have no leaks so far. So it wont cause damage to the seals if they have not already been damaged. The synthetic is made up of smaller compounds, and hence why it will leak easier than normal motor oil.
Old Oct 28, 2006 | 09:12 AM
absoundlab
I use 10 30 reg.
Old Oct 29, 2006 | 05:51 PM
grateful1's Avatar
........+1
Old Oct 29, 2006 | 06:01 PM
grateful1's Avatar
Originally Posted by absoundlab
I use 10 30 reg.
And I use 5w30.
mclasser
22
Nov 12, 2020 01:58 PM
Fbana41
Aug 29, 2016 12:18 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
pjgreek
Sep 9, 2015 09:30 PM
flu2000
22
Sep 2, 2015 07:29 AM
