Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
changing oil......
Old Oct 24, 2007 | 12:06 PM
jimmypronet's Avatar
changing oil......
guys im changing my oil right now and it was my first time doing it on this car... im having hard time getting the measurement on the deep stick.... how many quartz should i put..... need advise plz.... Thnx
Old Oct 24, 2007 | 12:28 PM
!PrjctMax!'s Avatar
Put about 4.75 in and go from there.
Old Oct 24, 2007 | 12:38 PM
Cool! Thanx men
Old Oct 24, 2007 | 12:50 PM
Kryogen's Avatar
worth using synthetic?
Old Oct 24, 2007 | 12:53 PM
!PrjctMax!'s Avatar
Only 5W30 Mobil 1 Synthetic here
Old Oct 24, 2007 | 01:41 PM
SilverMax_04's Avatar
This thread belongs in the Fluids and Lubes section of this site. Check out the good advice on this thread about changing oil in a 6th Gen Max.
http://forums.maxima.org/showthread.php?t=407421
There are other threads and stickies in the Fluids and Lubes section with good advice. Don't just stay in the 6th Gen posting section of this site.
Final point: The volume of motor oil you need depends on the size of the filter you are using. Some Mobil 1 filters are larger than the Nissan filter and thus require more oil to fill them. Better to underfill (slightly) than overfill (slightly) you engine with motor oil. So its best to not put all of the oil you think you need in when you do the re-fill. Leave out about 1/2 a quart and see where the level falls on your dipstick after running the engine for at least 10 minutes. You can easily add more oil to bring it up to full. It is much harder to try and remove some oil if you overfill.
Old Oct 24, 2007 | 02:19 PM
i think i will convert my injen CAI to short ram.. water just got in to muh engine so i need to change oil and keep it on flushin...... it rains here on texas alot.....
Old Oct 24, 2007 | 02:49 PM
NIKV69's Avatar
Depends of what filter your using. The stock small one I would put in 4 and a half and check from there.
Old Oct 24, 2007 | 04:55 PM
digitalfish's Avatar
how much water did you have to drive through to flood it? I'm still on the fence about a CAI
Old Oct 24, 2007 | 05:12 PM
!PrjctMax!'s Avatar
Most likely a ****ing lake!
Old Oct 24, 2007 | 06:16 PM
KCMAXX's Avatar
KC's FINEST
http://un2sg4.unige.ch/athena/minera..._orpierre.html?
Old Oct 24, 2007 | 07:32 PM
!PrjctMax!'s Avatar
Old Oct 25, 2007 | 01:02 PM
KCMAXX's Avatar
KC's FINEST
Old Oct 26, 2007 | 09:19 PM
kcryan's Avatar
deep stick? does my car have one of those?
Old Oct 27, 2007 | 04:53 PM
Ammi's Avatar
350 Detroit Muscle
Did you bother looking at your owner's manual?
doctorpullit
Mar 29, 2016 11:08 AM
MaxLvr21
Oct 17, 2015 12:11 PM
jds22
Sep 29, 2015 02:03 PM
Noela
Sep 26, 2015 08:22 AM
