GM Syncromesh fluid?
I searched around couldn't find much info. I used to use this stuff in my Honda's and they shifted smoother after putting this fluid in. Has anyone tryed this stuff in their Maxima? How does it work with our trannies? It is the same stuff as the Pennzoil Syncromesh
Don't use any GM products. There not engineered for our cars It's pacifically GM and definetly not in our Trannies and other major engine components. If It's an auto tranny we they use the GL-4 and for the manuals they also use the GL-4 oil.
Are you tyring to say that we use GL-4 in auto trannies as well?
![Confused](https://maxima.org/forums/images/smilies/confused.gif)
redline makes gl-4 fluids that is called shockproof. it is specially designed to protect the syncros and ive heard some people put the light shockproof in. (as opposed to the heavy)
I still prefer the MT-90 and Amsoil MTG GL-4 oils. Last I checked, the Pennszoil Synchromesh is a much lighter oil than the 75w-90 recommended by Nissan.
Dave
ok thanks for the info, i have no experience with but ive heard from other people that the shockproof is suppose to add extra protection to the syncros. apparently its still not a good alternative.
i ordered a case of amsoil mtg gl-4 from talkinghorse so im looking forward to putting that in after i do my clutch work.
Shockproofs give more protection to the gears and bearings, not the synchros.
While Maxima trannys have bearing issues, it's not the kind of problem that the shockproof oil will help.
GM Synchromesh is the same fluid as Pennzoil Synchromesh and I've used it in my transmission and it worked just fine. MT-90 is a better fluid, but in a pinch the Synchromesh works just fine.
Shockproof is a bad idea in our transmissions. I know some people like to use it and would argue this with me till they're blue in the face, but they haven't taken apart over 700 transmissions in their time working at a high performance trans shop like I have. The results of a transmission that has been run with Shockproof for a long time are ugly. I've seen it time and time again. I would not run it in my trans.
MT-90 gets my vote. However, I also own a subaru and use redline as part of a tranny cocktail. It is 2 parts Castrol HypoyC one part redline lightweight, and 1 part pennzoil synchromesh. It has been tested in subaru trannies for years and works great. But every car is different. With my max I have had the best luck with MT-90
Maxima.org Sponsor and Donating Maxima.org Member
I would not recommend people use synchromesh fluid in Nissan or other transmissions that require a GL-4 lubricant. To the best of my knowledge, synchromesh fluids are light viscosity and contain no EP additives. GL-4 applications require a certain amount of EP additives. Synchromesh fluid might seem to work fine in the near-term, but probably won't provide adequate protection.
80K miles on my ShockProof MEDIUM and I took the tranny apart to put in the Quaife and it still looked like brand new. There was no sludge, or wear anywhere inside the transmission. Car has been raced, and used as a DD also.
I nolonger have a Maxima, but I have changed that stuff every year and it was always clean and never gave me ANY issues.
Dave
06-06-2017 02:01 PM
fastcarny
10-12-2015 07:06 AM
Need help
23
10-02-2015 08:56 AM
