Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Seafoam
Old Jan 30, 2008 | 12:22 PM
JHASS's Avatar
Seafoam
What are your thoughts on using SEAFOAM in the 5th gens? I have seen mixed reviews on this product. I DID SEARCH on google and on the org but saw older posts. My buddy who has a Lexus tried it & said it worked had better tb response.
I have seen some people say it messed up there o2 sensors & had the CEL come on... I am not trying to mess up my engine so any thoughts or advice would be much appreciated, THANKS.
JHASS
Old Jan 30, 2008 | 12:46 PM
sicivic89's Avatar
JHASS
I've used seafoam on three different cars. A Honda Accord, Infiniti I30 and a Maxima and never had any problems with O2 sensors or CEL coming on. I've had a friend use them on several of his cars and he never had any problems either. Just don't boog the engine down too much when adding it to the intake manifold. I think the stuff works great. All the junk comes out as nasty smelling white smoke.
My friend and I have the idea to try putting the seafoam in a spray bottle and spraying it as a mist after the MAF but just before the throttle body. That way it would be evenly spread throughout the airstream cause I feel the the brake booster line on Maxima's would biases the last three cylinders on the intake manifold.
Old Jan 30, 2008 | 01:11 PM
Pearl93VE's Avatar
I can has?
Haven't had a problem with it in any of my vehicles, though I would only use it for what it is designed for. I do not put it in the gas tank, or oil either as 3rd gens have very finicky injectors. You should be fine running it through the brake booster, and it should reach all cylinders.
Old Jan 30, 2008 | 02:27 PM
NmexMAX's Avatar
dot dot dot ...
:I see this is the second thread and 3rd time you've posted this
http://forums.maxima.org/showpost.ph...postcount=4790
Old Feb 3, 2008 | 12:52 PM
UncleMax98's Avatar
I have used Seafoam many times, no problem. Lots of smoke, however. Berryman Chemtool makes a similar product "Total Combustion Cleaner" which I think works better.
220k+ A32
Sep 23, 2015 03:38 PM
MrEous
41
Dec 5, 2005 03:50 PM
E55AMG2
50
Dec 21, 2004 09:15 PM
MrGone
58
May 25, 2004 11:57 AM
