Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
When should you change up fluids?
Old Feb 25, 2008 | 09:58 PM
xtearitupx's Avatar
I read through the stickies and how to's but haven't found a definitive timeline on when to replace these fluids like power steeling, atf, oil, as far as mile intervals go. Like its said to do an oil change every 3k miles, what about the rest of these fluids?
And any definitive signs to show that you need to?
Thanks in advance
Old Feb 26, 2008 | 09:35 AM
nsnrider's Avatar
stick to your maintanance schedule in the owners manual unless you are using synthic oils, then it would depend on other factors and oils.
this question is too general and can be answered many different ways with more than one right answer.
go throught the stickies again, alot of the info is in there.
Old Feb 26, 2008 | 07:09 PM
Bobo's Avatar
Automatic transmission fluid should be replaced every 30k. Drain and fill at 30k, flush at 60k and repeat the process. Antifreeze is every 2 years or 30,000 miles. You can go longer than 2 years if you use an extended drain coolant like the Nissan anti-freeze.
Power steering fluid is probably every 60k miles or perhaps sooner.
It also helps to bleed the brakes and replace the brake fluid as it is hygroscopic and retains moisture which in turn can affect brake components.
Old Feb 26, 2008 | 07:49 PM
xtearitupx's Avatar
any recommended brands you can just shell out?
Old Feb 26, 2008 | 10:42 PM
adrenaline_rush_fanatic's Avatar
ATF:http://forums.maxima.org/showthread.php?t=110363
AntiF:http://forums.maxima.org/showthread.php?t=203347
PowSteer:http://forums.maxima.org/showthread.php?t=172761
Brake:http://forums.maxima.org/showthread.php?t=553314
Oil:http://forums.maxima.org/showthread.php?t=166313
ya gotta read around to get all your information.
But after all...it is a relationship you have with your max
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
iamute
Sep 20, 2015 05:22 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxxx10
Sep 13, 2015 03:16 PM
