Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Clutch Fluid Replacement
Old May 25, 2008 | 09:57 AM
wyche89's Avatar
My clutch fluid is pretty dirty. It's like a dark brown, and since you're supposed to use brake fluid in there, I'm assuming it's supposed to be the color of brake fluid. So how do you swap it out? I saw a process on motorvate.com about how to bleed the system, but I need a howto for a fluid replacement and bleed. Also if somebody could explain in detail where the lower bleeder valve is, that would be great, because the pic on motorvate wasn't really that clear. Thanx
Old May 27, 2008 | 04:22 PM
wyche89's Avatar
anybody?
Old May 27, 2008 | 05:02 PM
Kevlo911's Avatar
Kevlo for President
http://www.autozone.com/shopping/rep...00c152800764d8
Scroll down to bleeding
It's basically like brakes. I believe you will be able to bleed unit you see new fluid
CorollaULEV
30
Aug 9, 2021 08:11 PM
rbuswell
Nov 17, 2016 04:54 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Mrbizness1
Aug 18, 2015 08:43 PM
