Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
frozen oil
Old 12-31-2008, 09:39 AM
bucketheadd's Avatar
frozen oil
hello, i am @ ft. drum, ny today and it is around 5 degrees and -10 with wind chill
i went to put a quart of oil in the engine that i had in the trunk
when i opened it and tried to pour, it came out thicker than syrup
what is a good cold weather oil to use so i dont damage my engine
thanks
bucketheadd is offline
Old 12-31-2008, 09:59 AM
Kevlo for President
Kevlo911's Avatar
0w-30.
Kevlo911 is offline
Old 01-01-2009, 09:15 AM
Drockb418's Avatar
5-30 should do fine
Drockb418 is offline
Old 01-02-2009, 07:23 PM
96blkonblkse's Avatar
5W30 should be fine. Factoring in wind chill we've gotten down to -21, while the temperature was hovering around -10 to -12.
Ive never had a problem with 5W30.
96blkonblkse is offline
Old 01-03-2009, 06:09 AM
Maxima.org Sponsor and Donating Maxima.org Member
talkinghorse's Avatar
thanks
Obviously any oil will be thicker at 5 deg than it is at 70 deg...what weight oil do you typically use in the vehicle?
As the other folks have said, either a 5w-30 or 0w-30 will work well for you. 5w-30 is Nissan's recommended viscosity for your engine, year-round. Nissan does not recommend 10w-30 if the temps dip below zero deg F. Also, generally speaking, synthetic oils typically have lower pour points than their petroleum counterparts.
talkinghorse is offline
Old 01-31-2009, 05:36 PM
Bobo's Avatar
You're talking Celsius, however. I suspect wind chill is irrelvant to oil as wind chill just makes it feel colder. -10 to -12 Celsius equates to +12 to +14 Fahrenheit.
I use 0w30 synthetic (Esso Extra XD3) and I live in the same general area as the poster quoted below.
QUOTE=96blkonblkse;6790700]5W30 should be fine. Factoring in wind chill we've gotten down to -21, while the temperature was hovering around -10 to -12.
Ive never had a problem with 5W30.[/QUOTE]
Bobo is offline
Old 02-05-2009, 11:04 PM
SilverMax_04's Avatar
Whether the temperature is measured in Fahrenheit or Celcius, wind chill is only for the human body -- not for motor oil. The only effect that a big wind-chill difference will have on motor oil in an engine is to cool the engine much faster after that engine is turned off. But the actual temperature controls.
The molecules in motor oil only see the actual temperature of the location and that is the temperature that determines how easily the motor oil will flow (in the engine or out of a bottle). And most synthetic motor oils will exhibit better flow characteristics for a given motor oil weight than the comparable dino oil of the same weight.
SilverMax_04 is offline
litch
123
01-04-2024 07:01 PM
Miket2006
03-01-2021 03:55 AM
mclasser
22
11-12-2020 01:58 PM
06-06-2017 02:01 PM
05RLS2
04-14-2016 11:49 AM
Quick Reply: frozen oil
