Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Oil Analysis for Built Motor result
Old Dec 21, 2009 | 02:44 PM
streetzlegend's Avatar
Here is my oil report, it was castrol GTX 10w40 with comp cam break in oil, and used for 1000 miles.
Old Dec 21, 2009 | 10:15 PM
aic96max's Avatar
sweet,what did they charge you to analyze the oil you sent , is there a kit they ship to you to send the oil in? high sylicone, lol yeah, from all the silicon you used on that ****!!!!
Old Dec 21, 2009 | 10:24 PM
well sometimes high silicone also means its due from bad air filtering. its 25bucks they send u a free kit.
Old Dec 23, 2009 | 05:13 AM
KRRZ350's Avatar
Link is down.
I know you know this, but posting it anyways for others. On a VQ I wouldn't worry about silicone content for a long time, considering a motor build requires at least two entire tubes of the stuff.
Old Dec 29, 2009 | 01:12 AM
1993-VG30E-GXE's Avatar
Great post here - now I'll copy you and go to the same place for the oil testing. They service Canada too I believe. Streetz which value in your list is the ZDDP - it's not the Zinc alone is it? I wonder how to calculate % Weight from that data.
Old Jan 16, 2010 | 08:20 PM
smokinjoe's Avatar
Nice! Good info
Old Jan 16, 2010 | 09:20 PM
Thanx, I will be doing another analysis after this current oil. I have some track time in this oil as well, but its to soon to change it. I am interested to see how the results differ now that I am using full synthetic Rotella T6.
Old Jan 19, 2010 | 09:11 AM
Nealoc187's Avatar
SLOW
Silicone and Silicon are not the same thing. While silicone contains silicon, silicone is a sealant, whereas silicon itself is what makes up sand and dust.
High silicon content (notice it says silicon on the oil report, not silicone) could be a result of bad filtration, aluminum casting issues (our intake manifolds for instance are sand cast aluminum).
Old Jan 21, 2010 | 11:46 AM
mrgooch42's Avatar
Excellent report.
Old Nov 10, 2010 | 11:27 PM
Here is my latest report, the previous one showed very high Chrome, but looks like it was either a lab thing, or something:
Old Nov 15, 2010 | 06:19 AM
Nealoc187's Avatar
SLOW
was this the old Rotella T Synthetic like it says on the report or the newer named Rotella T6 Synthetic?
The reason I ask is that I have heard that the new T6 Synthetic has less zinc than it did when it was just called Rotella T Synthetic, and your oil report shows a good bit less zinc than the previous two (16% less than your previous change and 10% less than the one before that).
Old Nov 15, 2010 | 07:08 AM
So far all my reports consist of Just T6. Now is when i went with regular T non synthetic for higher visc
Old Nov 15, 2010 | 02:49 PM
Nealoc187's Avatar
SLOW
I sent you a PM about Shaeffer Moly Bond X200 15w40 that I was reading about.
Old Nov 15, 2010 | 03:35 PM
Mar 12, 2020 12:06 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
RWCreative
Sep 21, 2015 11:01 AM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
