Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
radiator fluid
Old Sep 7, 2014 | 12:15 PM
JohnnyRuiz's Avatar
radiator fluid
hello is it ok to just put water in my radiator on my 06 maxima or do i have to put antifreeze
Old Sep 7, 2014 | 01:10 PM
In a pinch and as a temporary solution, water is fine. Try to use distilled water though.
But to do it right, it definitely needs antifreeze. Usually it's a 50/50 mix of water and antifreeze. Read your owner's manual, it will tell you.
Old Sep 7, 2014 | 02:32 PM
chrome91's Avatar
as Wizard said, you can only use water in a pinch IE you ran out of coolant on the highway and need something asap. straight water isnt good for the engine and in the cold it will freeze and blow out your frost plugs
use 50/50 of coolant and distilled water. i usually go 70/30 coolant to water in winter from driving in -40c and lower
Old Sep 7, 2014 | 06:00 PM
JohnnyRuiz's Avatar
Thx
Old Sep 7, 2014 | 06:02 PM
JohnnyRuiz's Avatar
Thx for the info guys
Old Sep 7, 2014 | 10:19 PM
JohnnyRuiz's Avatar
Is it easy to flush the radiator at home
Old Sep 8, 2014 | 05:02 PM
chrome91's Avatar
drain the coolant from the radiator, remove one of the heater core hoses going to the firewall, blast water through the heater core hose, that will flush it out. afterwards, add straight coolant to the system because straight water will already be in from flushing it. after it runs and circulates for a while test the strength to make sure its okay
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Need help
23
Oct 2, 2015 08:56 AM
