Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
First!!!....Let's talk about torque wrenches?
Old Dec 9, 2007 | 07:01 PM
Greeny's Avatar
¯\(°_o)/¯
Dedicated to irish44j..
thank you..
Old Dec 9, 2007 | 07:41 PM
irish44j's Avatar
retired moderator
second
Old Dec 9, 2007 | 08:10 PM
Greeny's Avatar
¯\(°_o)/¯
So my wife bought me a new torque wrench for my b-day...(i broke my old one)
Craftsman 1/2" drive 20-150lb rating...yay
Old Dec 9, 2007 | 08:24 PM
irish44j's Avatar
retired moderator
same one I have
although I managed to crack the locking collar on it by abusing it too much. Still works fine though, just doesn't lock as well.
Old Dec 9, 2007 | 08:28 PM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by irish44j
same one I have
this will prolly happen to me soon.
Old Dec 9, 2007 | 10:26 PM
Cutler's Avatar
I own the same one but older model..
Old Dec 10, 2007 | 07:05 AM
Puppetmaster's Avatar
mine did too and they won't replace it w/o a receipt, even though it is a "hand tool". Maybe I need try replacing mine again with some other person at Sears.
Old Dec 10, 2007 | 07:32 PM
SEmy2K2go's Avatar
Go BUCKS!!!
I've got like 8 of those.
true story
well....one of them anyways.
Old Dec 10, 2007 | 07:44 PM
BLACKonBLACK98's Avatar
Former Vendor
looks like the one i have too, but i didn't get the nifty case i don't think.
Old Dec 10, 2007 | 07:57 PM
Terrentius's Avatar
I gotta get me one of them.....
Old Dec 10, 2007 | 08:10 PM
aznsap's Avatar
thats the one i have
goon9's Avatar
Mine
Old Dec 10, 2007 | 08:13 PM
MrGone's Avatar
Old Dec 10, 2007 | 08:16 PM
irish44j's Avatar
retired moderator
Originally Posted by goon9
Mine
baller......
Old Dec 10, 2007 | 08:25 PM
Greeny's Avatar
¯\(°_o)/¯
baller......
http://forums.maxima.org/showthread.php?t=547602
Old Dec 10, 2007 | 08:40 PM
BenStoked's Avatar
Jesus was a Zombie.
seems to be sears policy....
its total bull ****
Old Dec 10, 2007 | 08:46 PM
irish44j's Avatar
retired moderator
interesting....I originally had a craftsman 3/8" torque wrench, but the block sheared off when I was using it as a breaker bar (). I took it back and they didn't have another one, so they just gave me the 1/2" as a replacement. No receipt, no hassle.
Why would you need a receipt? Where else besides Sears can you buy craftsman?
Old Dec 10, 2007 | 08:48 PM
goon9's Avatar
Can get them on ebay, but I NEVER needed a recipet. But I only brought in broken sockets and couple rusted wrenches.
Old Dec 10, 2007 | 09:17 PM
MIKE2K2's Avatar
Custom User Title
K-mart has a limited selection of Craftsman tools now.
Old Dec 11, 2007 | 12:20 AM
elusivemax93's Avatar
i use cornwell beam style torque wrenches i have a 3/8's and a 1/2 inch beam style torque wrench like this one
Old Dec 11, 2007 | 05:48 AM
KRRZ350's Avatar
Originally Posted by KRRZ350
And why exactly do you feel that the needle type is innacurate? Because they are not. Calibration/age/damage, along with using one not within the middle of it's range is where you will run into trouble. IE if tourqe wrench X goes from 0-75 ft/lbs, it will not be as accurate at 75ft/lbs. I have three that I use on a regular basis (all craftsmen) depending on the force needed. The smallest is a click type, the two larger are needle.
From a previous thread, thought it would be useful info in here.
Old Dec 11, 2007 | 07:16 AM
Colonel's Avatar
Old Fuddy Duddy
I have read on occasion that Torque wrenches need recalibrated. Does anybody do that?
What "position" do people leave their wrenches in when not in use? Meaing is there a specific setting that its left in?
I have had mine a few years and want to make sure its still the tool of exact measure it should be. I have the Craftsman "digital" 3/8 drive.
Old Dec 11, 2007 | 07:37 AM
its total bull ****
Yeah, but this thread reminded me that I need to try again, not that it really matters since I only use it for lugs these days and I just need to be careful the settings don't change while I'm tightening. I'll let y'all know what happens.
Old Dec 11, 2007 | 10:28 AM
i dont have to worry about setting my torque wrenches back down to zero because the beam style torque wrenches dont get messed up fro turning the dail on the side up and leaving it set there. And this i know from my Co-Workers/College Instructors/Tool truck guys all saying the same thing that a beam style torque wrench doesnt have to be turned back down after use. as for recalibrating them usually best to have it done by some pace that can do it or for the few of us using Quality tools off the tool trucks can just take it back to our tool dealers and have them calibrate them.
Old Dec 11, 2007 | 01:00 PM
mtrai760's Avatar
'Trynna' is not a word
As a general rule... Torque wrenches should be stored at there lowest torque setting, but never go below the lowest marked setting. They should not be used in the first or last 10% of the torque range they are rated at, so if you had a torque wrench that went from 0-100 in/lbs, you should only use it for torquing between 10-90 in/lbs. Torque wrenches should be used for that function only, they should not be used as a regular ratchet wrench, they should not be used for removing bolts/nuts unless you are just check the torque level they turn at. Then a regular ratchet should be used to finish removing it. We recalibrated our torque wrenches every six months, unless it was dropped, then it had to be sent out right away. If the torque was suspect for any reason, the wrench would also be sent out. This was for military aviation use, where EVERY single bolt/nut/screw was torqued, so we used the torque wrenches several dozen times a day. Light automotive use is not so life and death
Old Dec 11, 2007 | 02:12 PM
pmohr's Avatar
No more Maximas...
Sears' return policy on torque wrenches is regular replacement within 60 or 90 days IIRC. Most likely because they're often abused and can go out of calibration relatively easily. When I worked in SAC I would bring in my torque wrench every few weeks and get it replaced no problem, since I have this bad tendency to use it as a breaker bar.
They swapped out a 1/2" for a 3/8"? That's weird.
K-Mart and Sears Holdings have been one for a while, now. Return policy should be the same at either store.
In any case, here's mine:
Old Dec 11, 2007 | 06:42 PM
MorpheusZero's Avatar
I've got a Sears 1/2" drive and 3/8" drive. I have beaten the crap out of them, using the heads as a hammer to knock out bolts on more than one occasion.
I have since changed my ways, but one of the clickers has become difficult to switch torques and one has become easy. Strange stuff.
Old Dec 12, 2007 | 06:51 AM
Colonel's Avatar
Old Fuddy Duddy
Good info. I was unaware of the 10% rule. Guess I need to go get another wrench as I use mine in the upper 10%.
Other than that, I do use them as described above. I have not had it recalibrated though....
Old Dec 12, 2007 | 12:00 PM
RW-Maxima's Avatar
Sears torque wrenches don't carry the lifetime warranty even though they're labelled Craftsman. That's probably why the wanted the receipt.
The other advice here is good. Unload the spring when not in use, don't use it to undo fasteners or as a regular ratchet.
You would need a known weight or reliable yield to recalibrate a torque wrench. And of course a way on the wrench to adjust it. Very few people do it.
Old Dec 12, 2007 | 01:45 PM
I have heard of people getting turned down for the Craftsman warranty because of "shop abuse."
Old Dec 12, 2007 | 04:35 PM
Kevlo911's Avatar
Kevlo for President
I use the 8 do0lla autozone special
Old Dec 16, 2007 | 04:47 PM
sshocker96's Avatar
Me too. Maybe that's why that head gasket blew, huh?
Old Dec 16, 2007 | 10:52 PM
joebangaa's Avatar
I love just about everything made by Craftsman but their torque wrenches have seemed to generate several complaints, particularly when it comes to the plastic locking ring. I don't use mine very often so it's served me well for years, but I know many others who do use them often and swear that the plastic ring is a design flaw. They've even gone as far as saying they prefer a cheapo Harbor Freight-type torque wrench over a Craftsman. Considering a brand new torque wrench from Harbor Freight costs ten bucks whereas JUST recalibrating a Craftsman would cost 30 dollars (without shipping), it's hard to argue with their logic.
Old Dec 17, 2007 | 07:51 PM
MDeezy's Avatar
I thought I was the only one!
my autozone charges $90 to rent it. but its 20-250 ft/lbs. Very effective and works well.
Old Dec 20, 2007 | 09:08 AM
L.M.L.
I've got Mountz MTZ80TH wrench. was a bit expensive but good quality.
Old Dec 24, 2007 | 01:07 PM
5thgenmaxima's Avatar
These are the 3 I have now.
After the new year I'm going to be trading my 1/2" drive wrench in on the one below... Just had a guy in the shop have to do a Headgasket again for free since our angle meter doesn't work. He torqued all bolts then tightened them 90 degrees then 155 degrees off of guessing...Re doing a headgasket for FREE FTL...
This one (or the newer version that looks just like it) has an angle meter built right in for torque to yield bolts.
Attached Thumbnails First!!!....Let's talk about torque wrenches?-wrench.jpg
Old Dec 25, 2007 | 10:19 AM
00MaxSE's Avatar
Pointy Elbows
$19.99 from Murrays. Got it 5 years ago.
Also have this Craftsman one...no clicking FTL
Old Dec 28, 2007 | 05:52 PM
00MaxSE's Avatar
Pointy Elbows
Exclamation ZOMG!
Old Jan 1, 2008 | 10:37 AM
nismology's Avatar
I've read in quite a few places that click-type torque wrenches are accurate from 20% of max to 100%. Accuracy only suffers on the low end.
Old Jan 1, 2008 | 11:32 AM
spdfreak's Avatar
Has Consumer Reports ever had a comparison?
