Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
Maintenance on Floor Jacks?
Old May 18, 2008 | 11:30 PM
steven88's Avatar
Need A Light?
I have two craftsman floor jacks...one is 2 1/4th ton and the other is 3 ton
I bought them December 2005...they have NEVER given me a problem...no oil leaks or sticking saddles etc...but I am concerned with using these down the road...2 and half years is nothing...but what about another 5 years from now?
I read the owners manual that came with the floor jacks...and it simply says something like, "for safety reasons, bring your floor jacks to an authorized sears location for maintenance every year." Do any of you guys follow this rule? If so, how much is it for inspection and/or repair?
I just don't want the floor jack to give out one day all of a sudden....thanks in advanced!
Old May 25, 2008 | 09:21 PM
steven88's Avatar
Need A Light?
50 views and no hits?
Old May 26, 2008 | 05:32 AM
edjose17's Avatar
Always use jackstands and you will be protected against any floor jack failure.
But to your concern, at least I have never sent any floor jack to be inspected for maintenance needed.
Old May 26, 2008 | 05:18 PM
steven88's Avatar
Need A Light?
how long have you had your floor jacks?
Old May 26, 2008 | 06:38 PM
edjose17's Avatar
I bought it about 2 1/2 years ago. I use the jack about once a month to raise the car to wash the under side of car.
Old Jun 2, 2008 | 05:56 AM
DONS459's Avatar
Never had problems with my old floor jack and i used it for over 10 or 15 years before i bought an aluminum one. No maintance except a little oil on the pivot points. And i always use jack stands along with it.
Old Aug 3, 2008 | 09:21 PM
steven88's Avatar
Need A Light?
anybody else have inputs?
Old Aug 4, 2008 | 06:53 AM
Kevlo911's Avatar
Kevlo for President
I tried to look online but I didn't find anything.
Old Aug 4, 2008 | 09:03 AM
!PrjctMax!'s Avatar
Stupid question, but how do you go about doing that with such little clearance?
Old Aug 6, 2008 | 08:29 PM
choray911's Avatar
The Crazy Azz Cracka
You have nothing to worry about safty wise. I have a jack that was bought from harbor freight about 3 years ago. I use it to jack up my Miata 3 to 4 times a month for races and other maintanence. It does leak a little and you will know when it is going bad. When the pump is going bad the car is slow to raise, or will not go up at all when you pump. When the car is up, the release valve will keep the car up, and this will rarely go bad. The problem most people have is the car not going up, coming down has not been a problem.
I have to bleed the system every few months to get it to pump correctly.
Old Aug 8, 2008 | 10:35 AM
1trucavalier's Avatar
most jacks are pretty safe but none safe enough to get under your car without a floor jack. I use them almost everyday i have blown the seals in 5 jacks in 3 years (thats how much i use them). If you can make sure you have at least a 2 ton + because they will last longer and ALWAYS use a jackstand.
Old Aug 19, 2008 | 12:23 AM
mrrsx2006's Avatar
Use a jackstand! what will you do if the car drops?
Old Aug 21, 2008 | 04:15 PM
Shoey1's Avatar
just grease or oil them from time to time to keep them pivoting smoothly. i have never heard of a floor jack dropping for no reason. and if one did it was probably overloaded for its specified capacity, or was damaged
Old Aug 21, 2008 | 09:40 PM
adamgh81's Avatar
wannabe max mechanic
+100 on the jackstands. Safety first, I have a family friend who is disabled from the waist down from working on his car and the jack went out on him. You can get a set for under $30.
Old Sep 1, 2008 | 08:27 PM
NissanTun3r's Avatar
I'd buy a new jack every 5-7 years..they don't cost too much
Old Oct 1, 2008 | 10:58 PM
knight_yyz's Avatar
Toolie
the hydraulic oil should be changed periodically. It will help the seals last longer. Contaminated hydraulic oil can cause some nasty damage.
Old Oct 24, 2008 | 07:35 PM
00MaxSE's Avatar
Pointy Elbows
Smile
Bleed the air out of the cylinder on occasion too.
Old Nov 12, 2008 | 12:22 PM
bpk01's Avatar
Where is the best place to set the jackstands? for any sistuation
Old Nov 15, 2008 | 04:55 PM
bigjoe87865's Avatar
+1 ^
im in the market for a new floor jack that wont break the bank... advance auto parts has some generic brand jack 2.5tons that comes with 2 jackstands (which i dont own) for $41
any other suggestions?
Old Nov 25, 2008 | 06:28 PM
nismo97se's Avatar
axle stands are ideal
Old Jan 2, 2009 | 11:06 PM
blkAEmax82's Avatar
Glory Glory Man United
Hey J and Knight,
Sorry if this sounds , but I did Google it before asking. Do you guys have any good links or info on these maintenance procedures?
Old Jan 3, 2009 | 08:14 AM
00MaxSE's Avatar
Pointy Elbows
^ Did yours come with an instruction manual? Mine included all the info in there.
I'll take a pic of the pages if you don't have it.
Old Jan 3, 2009 | 10:22 AM
blkAEmax82's Avatar
I don't have a instruction manual sir, since I got it from a friend. If you can take pics that will be great,thanks J !
-Roger
Old Jan 3, 2009 | 11:48 AM
00MaxSE's Avatar
Pointy Elbows
Here
Old Jan 6, 2009 | 12:57 AM
blkAEmax82's Avatar
Hey J,
Thanks yo, thats perfect !
Old Jan 6, 2009 | 05:16 PM
00MaxSE's Avatar
Pointy Elbows
Sure thing
Old Jan 17, 2009 | 01:15 PM
tresboi's Avatar
I've tried time and time again to bleed & refill my jack according to procedure but no go - it still won't lift more than a few inches and won't hold at all. I've done regular maintenance on hydraulic jacks before and have never run into this situation. I'm beginning to feel like I wasted $60 on this thing.
Old Feb 20, 2009 | 09:33 PM
willdotcom's Avatar
Get Jack Stands!
Never, ever use jacks to lift your car without jack stands. Also, chock the set of tires that are on the ground.
GET JACK STANDS RIGHT NOW!
Old Feb 21, 2009 | 06:27 AM
choray911's Avatar
That has been established.
Old Feb 21, 2009 | 09:53 AM
00MaxSE's Avatar
Pointy Elbows
He was just getting his 15th post....
Old Feb 23, 2009 | 06:06 AM
choray911's Avatar
IC, Post ***** in Training.
TKHanson
Nov 24, 2018 01:39 AM
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
