Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
heli-coils...flywheel bolts.
Old Jul 5, 2008 | 10:55 AM
black_maxed95's Avatar
The heads of two flywheel bolts (the bolt that holds the flywheel to the crankshaft) broke off when I intalled my lightened flywheel. Now I need to take the tranny off again and I want to fix those bolts. I will need to drill them out, re-tap and insert the heli-coils with threadlocker if I understand dorrectly.
My question is, where can I get a good heli-coil kit? Should I buy an entire set or just the size I need? I dont have too much money to spend. Also if anyone knows the thread pitch of the flywheel bolts that will help but I can figure that out on my own if i have to.
...or should I tap it to the next size larger?
Old Jul 5, 2008 | 04:32 PM
MDeezy's Avatar
in for results.
One of my flywheel bolts are cross threaded, and will need at least re-tapping.
Old Jul 5, 2008 | 04:40 PM
JamesNH's Avatar
how do you know that the threads are garbage? I got my helicoils at local store and only got the size i needed, it was like 30$ if i remember correctly. I came with the helicoils, the tool to turn them in and a tap.
Old Jul 6, 2008 | 12:20 AM
the threads arent necessarily garbage but they will be when I have to re-drill them. I have a full 80 piece tap & die set so should i tap it to the next size larger or heli-coil it?
Old Jul 6, 2008 | 02:25 AM
Maxima_Joe's Avatar
4th Gen Parts King
I would try an easy out/screw extractor before I even thought of tapping them. The threads are probably fine and it shouldn't be a problem to get the broken bolt out with an easy out. How did the heads snap?
Old Jul 6, 2008 | 10:37 AM
ya I never thought of that since Ive never used easy-outs before. I ordered a set so I will try that.
By the way they broke using an air impact gun trying to get them out. I learned that they should be taken out by hand.
Old Jul 16, 2008 | 05:29 PM
JamesNH's Avatar
Why not put in a drill bit smaller than the bolt run it in a good amount in the middle, then put the drill in reverse. Works for me all the time.
Old Jul 16, 2008 | 06:09 PM
Maxima_Joe's Avatar
4th Gen Parts King
That's what a screw extractor/easy out does.
Old Jul 16, 2008 | 08:18 PM
Ya I got my easy outs that I ordered, havent used them tho. It will be probably 2 more weeks due to vacation and work schedule that I will now have time to take my tranny off.
Anachronism
Jul 9, 2002 06:25 PM
JR_Anders
Jun 21, 2002 05:57 PM
DNA21
Aug 4, 2001 09:29 PM
diesel9119
Apr 22, 2001 06:56 PM
