Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
floor jack question..
Old Mar 15, 2010 | 12:58 AM
kv2's Avatar
kv2
I recently got this jack from harbor freight http://www.harborfreight.com/cpi/cta...emnumber=94629
I have one problem with it. To lower the saddle you use the long handle which turns some teeth, connected to some other teeth which releases the pressure.
I find it very difficult to rotate the handle in tniy increments as to actually lower the car into jack stands at a safe speed. They pretty much almost drop onto the stands.
Is this just me?? or is there some special technique? or is there any way to adjust the lowering speed??
if not i think i just might have to return it and get a different one.
thanks!
Old Mar 17, 2010 | 07:05 PM
Andrew's Avatar
Seems that the seal went on the jack. Its common and if you are handy you can fix it.
Old Mar 24, 2010 | 08:02 PM
whitemef's Avatar
That's exactly the same jack I use and have had no problems with it. How long have you had that jack? The have a pretty decent warranty. If it is giving you problems then you should take it back for a replacement.
Old Dec 11, 2010 | 05:56 PM
Pete the Sneak's Avatar
I have a Harbor Freight jack and it is just a nice as my craftsman unit. In some ways it is better. Mine works smoother than the craftsman in ability to lower slowly.
Old Dec 17, 2010 | 01:14 PM
LA02MAX's Avatar
You could get a pair of vice grips on the handle.....more 'ghetto' way of doing it but it allows for an easy and smooth operation.
Old Dec 20, 2010 | 11:25 AM
bpinfiniti's Avatar
I also have a similar harbor freight jack. Never had any issues with it lowering. I just turn it slowly and it works.
Old Dec 23, 2010 | 11:22 AM
djfrestyl's Avatar
Suspension Yoda
I just bought the same one, and experienced the same issue. The teeth on the gears skip, makes it very hard to slowly lower the jack
Here's the trick.
Instead of trying to lower the jack when the arm is vertical, lower it when it's horizontal (parallel with the ground)
Old Dec 23, 2010 | 03:00 PM
ampire's Avatar
I will be getting a low profile HF floor jack to put in my trunk, any tips on having it not bang up the inside? I was thinking I'd make like a wood box for it to sit in.
Old Dec 23, 2010 | 03:02 PM
djfrestyl's Avatar
Suspension Yoda
Not bang up the inside of what?
Old Dec 23, 2010 | 03:46 PM
maxima07's Avatar
Do you have any pressure on the handle when trying to turn it. I noticed on mine, If there is pressure on the handle, it makes it hard to turn and lower the jack.
Ampire - put it in a luggage case
Old Dec 23, 2010 | 06:35 PM
YelloMantis's Avatar
These work quite well:
http://www.calcarcover.com/product.aspx?id=1163&cid=98
Old Dec 24, 2010 | 08:51 AM
ampire's Avatar
Nice thanks Yello
Old Jan 5, 2011 | 12:53 AM
amiragriffiths's Avatar
I was using same jack prior to current one and it was working fine with me. I found a bit speedy but wasn't that much.
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
homewrecker
Sep 23, 2015 03:41 AM
