Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
alternator. or something else?
Old Jan 23, 2015 | 09:52 PM
nissianmaxi2002's Avatar
At first my battery kept going dead. (I kept getting jumps) Then I bought a battery at walmart. Then a week later that battery kept going dead. So I bought a new alternator. Had my friend put it in. The old battery (the recent one I got at Walmart) was completely dead. Dude said the battery was fried. So I went to Walmart and they replaced it. I got the NEW battery . Now today my kept went dead yet again!?? Brand new battery brand alternator. Battery still going dead please help. I don't want to take it to a shop and get ripped. I'm a single mom . This is my only transportation
Old Jan 23, 2015 | 10:02 PM
chrome91's Avatar
sounds like a parasitic drain, get a cheap test light, has to be incandescent bulb NOT LED
disconnect the negative battery terminal, wait 10 minutes for the PCM to go to sleep, clamp the test light to the negative battery terminal and press the probe of the test light to the now disconnected negative battery cable. if you have a drain, the test light will glow bright. remove fuses from your fuse panel one at a time, if you pull a fuse and the test light goes out or very dim thats the system you have a drain on
so for example you get to the radio fuse, pull it, and your test light goes dim. something on the radio circuit is causing a parasitic drain. if you have aftermarket electronics like a remote starter or aftermarket alarm, disabling those is usually the place to start
Old Jan 24, 2015 | 12:03 AM
how many darn threads do you need on your problem? Enough already.
https://maxima.org/forums/5th-genera...r-trouble.html
DJLAX152
May 4, 2021 11:46 AM
Samedi
Aug 13, 2015 04:05 PM
Superbform
Aug 11, 2015 08:10 PM
Tanman
Oct 26, 2002 12:25 PM
driver824
Jul 29, 2002 09:30 PM
