VQ35 Hybrid Powertrain
Old 01-05-2009, 06:43 PM
2060lbs and falling...
Broaner's Avatar
After a long hiatus from the VQ Powered S13 world I've decided to go ahead w/ the LS1 swap. So its time to put this powertrain up 4 sale. Its been a long hard road to come to the conclusion that the VQ is not for me. I need more power because I'm a freak of nature. This exact motor package as it is put down the following dyno. The lack of peak power is due to the fact that its breathing through the A32 upper and lower manifold. The A32 IM is very restrictive up top for even the VQ30. With the correct IM this VQ35 would put down somewhere in the 230wheel range with minimal tuning. I have the correct top feed injectors to complete the setup but not the TB or actual IM.
Z33 6Spd Tranny w/ less than 30k(Bought from yard for $800)
A32 ECU and Modified Harness
A32 Slightly Lightened Flywheel
Polished VQ30 Timing Chain Cover.
ACT Stage I Clutch(Less than 5K on)
TOB Spacer to adapt Z33 TOB to A
Hybrid VQ35DE Swap(VQ35 Longblock with VQ30 Timing Chain system)
Unorthodox Racing Underdrive Pulley.
Custom 2" True Dual header dump pipes with Magnaflow 2" flowthrough mufflers.
No Power Steering or A/C
350Z Exhaust Manifolds Modified to clear steering shaft.
Custom One Piece Steel Driveshaft
Custom Motor and Tranny Mounts
APS Extra Capacity Oil Pan($400+)
B&M STS
Nismo Titanium Shiftknob
This setup will bolt in but will require modification of the sway bar mount and the shifter hole. The package is not entirely buttoned up and will need some creativity but it is certainly an good assemblance of parts. Asking $2500. Will deliver within 300 miles of Madison, WI. Will deliver further for $.46/mile.
Please contact broan@wisc.edu with questions, concerns or inquiries.
Broaner is offline
Old 01-06-2009, 09:11 PM
kzoosho's Avatar
was this a fwd vq35?
kzoosho is offline
Old 01-07-2009, 03:04 PM
Broaner's Avatar
Yes. Block is from an A33B. Had less than 50K on it when bought from the yard. I put less than 10 hours on it since assembling in hybrid form.
Broaner is offline
Old 01-09-2009, 07:57 AM
Broaner's Avatar
Also, forgot to mention that the tranny has a B&M STS and a bad@ss Nismo Titanium style shift ****. :added to original post.
Broaner is offline
Old 01-09-2009, 03:39 PM
dfownz's Avatar
Willing to sell just the motor?
dfownz is offline
Old 01-10-2009, 02:04 AM
goldtooth's Avatar
How much just for the engine plus delivery to Chicago? (curious)
goldtooth is offline
Old 01-11-2009, 09:22 PM
Silver Tooth S2K 9k FTMFW
95 maxima se's Avatar
damn wish i had the money for it for my s13
95 maxima se is offline
Old 01-12-2009, 04:08 PM
Broaner's Avatar
Yes, I am willing to sell just the engine. After a weekend of no activity on the package as a whole I'm interested in parting out to get the cashflow going in the direction of the LS. I will look at my records when I get home to see how much I paid for the yard motor. I can sell it with or without the APS Oil pan. I'd imagine you guys don't want that oil pan unless ur planning on using this for a RWD project as well. Only thing I can say for sure is that I will want $400 more for the motor if the pan is included.
I will deliver this motor to Chicago but I want COD and will need at least two people there or a cherry picker to lift it outta the bed of my truck.
Broaner is offline
Old 01-13-2009, 11:31 AM
wat
AceofSpds's Avatar
Dang, have you tried posting this on zilvia?
im sure at that price it would sell.
Im probably going to do the same as you and sell my SR for an LSx setup next year probably.
AceofSpds is offline
Old 01-13-2009, 04:17 PM
happy4444's Avatar
wise choice with the ls-1... lots of luck w the install. idk where ur located but if your shoppin for a motor and t56 theres a junkyard that only sells ls1's and lt's.. its in bristol, PA
happy4444 is offline
Old 01-13-2009, 09:25 PM
Broaner's Avatar
< I'm in Madtown. I probably won't be getting the actual motor for a year or two because I'm gonna fully tube the chassis with a mockup plastic block before I get the motor. So the prices come down or the LS-6's become affordable. Don't worry I still get my speed kicks. It just comes in the form of two wheels.
Broaner is offline
Old 01-28-2009, 10:18 AM
daverussell's Avatar
Damn it man. If you still have this after I get my tax return back (should it be enough) you may be hearing from me. I have always wanted to make a road trip to WI!!!
daverussell is offline
Old 02-23-2009, 06:21 PM
Broaner's Avatar
Still got it fellas and its tax season now. Possible sale going down on some driveshaft and tranny stuff on Freshalloy. I'm thinking about putting the tranny up on My350 if that comes through.
Broaner is offline
Old 02-25-2009, 07:08 PM
Product_Of_Korea's Avatar
so how much do you want for just the vq?
Product_Of_Korea is offline
Old 04-12-2009, 07:02 PM
Broaner's Avatar
Sorry for not responding sooner. I'm almost never on here. I'd take $500 for the VQ if you pick it up. Or you can pay shipping. I'd use UPS Freight. They'd be picking up from a business loading dock. Delivering to a business would be significantly cheaper than a residence.
Everything is still up for grabs besides the drive shaft and clutch slave.
Please post all responses and inquires of these items in this thread and to my email at broan@wisc.edu
Broaner is offline
James92SE
142
01-02-2024 09:23 AM
mclasser
22
11-12-2020 01:58 PM
jfl330
09-04-2015 01:44 PM
umnitza
09-01-2015 01:03 PM
Quick Reply: VQ35 Hybrid Powertrain
