Tranny Cooler is installed
Old Jul 22, 2002 | 01:19 PM
deezo's Avatar
Sorry if the pic is too dark.
It took me about 2 hours to figure out where I was going to put the thing but I decided this was going to be the best place to mount it for me. I run the highway a lot and wanted it to get as much air possible. The best thing about doing this intall is that you really don't have to drain the tranny fluid to do this. I fluid that was lying in the hose itself which was not much even in small amounts.
http://a5.cpimg.com/image/57/D9/1149...-028001E0-.jpg
Old Jul 22, 2002 | 01:26 PM
clee130's Avatar
Isn't it going to get all dinged up from rocks and such if it's down that low?
Old Jul 22, 2002 | 01:32 PM
deezo's Avatar
Well, I'm not chasing the General Lee. J/P
That thing is built pretty sturdy and solid. I don't thing it will be an issue.
Old Jul 22, 2002 | 01:50 PM
NYCe MaXiMa's Avatar
people will start thinking you got an intercooler down there
nice idea though..
i've been planning to put one in forever now
Old Jul 22, 2002 | 01:55 PM
deezo's Avatar
nice idea though..
Well at least I thought of it from a working standpoint and not to make people thing I really had a mini-intercooler connected to my imaginary turbo setup.
Old Jul 22, 2002 | 02:15 PM
max_speed97's Avatar
which one did u get??
Old Jul 22, 2002 | 02:20 PM
deezo's Avatar
B&M Supercooler #13070264 $49.99
Old Jul 22, 2002 | 02:30 PM
XXXL Cracker's Avatar
Deezo, did you need special fittings?
I ordered the B & M Supercooler, Polished and I need to use NPT fittings to connect it(did not know this prior to ordering). The cooler has two female 1/2 threaded inlets so I need to purchase a 1/2 inch NPT with a barb on the end.
Did you have to do anything special to install or was it just additional transmission hose and clamps?
If you needed add'l hose, how much and what size did you need?
Thanks MAN...
DL
Old Jul 22, 2002 | 02:34 PM
Bags's Avatar
VG Ridah's Biatch Hoe
looks good ..maybe I should finally get off my butt and do this as well
Old Jul 22, 2002 | 02:35 PM
is the b&m better than the hayden 404? if so why? also does anyone know how much the hayden goes for.
Old Jul 22, 2002 | 02:51 PM
deezo's Avatar
Re: Deezo, did you need special fittings?
Thanks MAN...
DL
Give me your email and address through PM and I will send you the fittings you need. I ordered the same one you have but I sent it back to get this one. I really have no use for the fittings. I used plastic tie straps to lock it in place and used the hose clamps that cmae with the kit. I bought extra hose (about 4') and I'm glad I did because the hose that comes with the kit is kind of stiff and you wouldn't be able to position the hose correctly without getting kinks in it, especially if you put it where I put mine. I figured I'd give the fluid less distance to travel also.
Don't get 1/2 inch hose because its too big. When I send you the fittings you'll be able to get the right hose size.
Bags: Thanks. You'd better do it because you're hard on your auto too.
max_speed97: I personally think the B&M is better because it has a built in bypass for the winter months to keep the tranny fluid at the right operating temperature.
Old Jul 22, 2002 | 03:03 PM
Bags's Avatar
Re: Re: Deezo, did you need special fittings?
hehe.. BTW.. which tranny fluid are you using? I am using amsoil and I dig it
Old Jul 22, 2002 | 03:09 PM
deezo's Avatar
Re: Re: Re: Deezo, did you need special fittings?
I'm not sure. I get whatever Valvoline uses.
Old Jul 22, 2002 | 06:39 PM
redmaxpa007's Avatar
i SeE what you did therE
bout time you installed the cooler..
now i have to do that too
Old Jul 22, 2002 | 08:19 PM
BBaker025's Avatar
Do u like it, I was thinking about getting a hayden, but urs looks good.
Old Jul 23, 2002 | 02:49 AM
deezo's Avatar
I like the way it looks and I can't feel any difference in the way it shift. I do feel better about having it though.
Old Jul 23, 2002 | 06:02 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Automatic Transmission Cooler Install
Plate & Fin Type (Best):
B&M (Have internal bypass for cold climates)
-Supercooler #70255
16,000 GVW 11 x 5.75 x 0.75" $44
-Supercooler Type #70264
19,000 GVW 11 x 7.5 x 0.75" $40
Hayden:
-Rapid-Cool #676
11 x 5.875 x 0.75" $46
-Rapid-Cool #677
11 x 7.5 x 0.75" $49
Tube & Fin Type (Good):
Hayden:
-Ultra-Cool #403
12.75 x 7.5 x 0.75" $40
May need 4 feet of 3/8" transmission fluid hose:
Gates Transmission Fluid (aka Power Steering) Hose (available at O'Reillys)
$2 to $3/foot
O'Reilly's, AutoZone, and Pep Boys carry Hayden coolers
NOTE: All coolers above will do just fine. However, the bigger-dimensioned models can be more susceptible to poorer tranny shifts for those that have harsh winter climates. It would be wise to choose according to your climate.
Quoted Message:
Courtesy of Matt93SEE
The 16,000 will still be more than enough for our cars no matter whether you live in Alaska or the Sahara. They're rated at 16,000lb because they're designed to cool the fluid enough for a 16,000lb vehicle. NOT a Maxima with a 4500lb absolute max capacity.. (3200lb car + 1300 people & luggage)
IMO, anything over 12,000 is overkill, especially in places where it drops below 40 for any point int he winter. my car got steadily more and more sluggish in the winter and only began shifting correctly when the temp got back above 60. It wasn't my driving that caused my tranny to be about 2 weeks from failure, it was the damn oversized tranny cooler.
For those that add ANY tranny cooler, I highly recommend covering at least half of it with plastic or cardboard during the winter (you see it done on trucks and busses and stuff like that for the exact same reason).
What ATF Fluid should I use?:
Synthetic should be used as a fluid replacement for its longevity and superior flash point properties. Available brands include the following:
Mobile 1 ATF (Readily available at all Auto Zone stores)
Amsoil ATF (Available at specialty dealers or at www.amsoil.com)
Additional NOTE:
Quoted Message:
Courtesy of brubenstein:
It's really important to switch over to synthetic ATF if you use a trans cooler in cold climates. It won't get as thick as conventional ATF, so the transmission will work properly even with cold fluid. It still won't shift into OD until the fluid temp reaches 122F. Another reasonable thing to do is put the cooler in the feed line from the transmission to the radiator, instead of the return line. This allows the heat exchanger in the radiator to warm up the fluid. You could even swap the lines at the transmission in spring and fall if you want.
I would not use synthetic ATF that is marked for "racing". Its viscosity is a little higher, and will only increase cold weather problems. With the B&M 70255 cooler and Mobil 1 ATF, my transmission acted fine into the 30's.
How do I install a transmission cooler?
Credit goes to member GregP for his excellent how-to write-up:
http://www.greghome.com/Greg's%20Garage/1999%20Nissan%20Maxima%20SE/Xmission%20Cooler.htm
More information about the specific coolers available:
B&M Supercoolers:
http://bmracing.com/noflash/products...perCooler.html
Hayden Coolers:
http://www.haydenauto.com/transmis.html
http://www.haydenauto.com/hc2000/e_c...f/contents.pdf
Good reference post:
http://forums.maxima.org/showthread....ler#post240191
Old Jul 23, 2002 | 06:06 AM
bill99gxe's Avatar
Only thing I disagree with deez about is you really don't need anything greater than the B&M 70255, ESPECIALLY with synthetic ATF.
B&M Supercooler is a cut above the Hayden Rapid-Cool and both are LIGHT YEARS ahead of the tube and fin Hayden Ultra-Cool 403 or 404 models. What's funny is all are around $40 to $50.....
Buying 4 to 6 feet of good quality (Gates) transmission fluid (aka power steering) hose is essential as well. On the cooler I have installed, I didn't bother with the hose in the kit.
Old Jul 23, 2002 | 06:36 AM
deezo's Avatar
You're right about it being more than enough but it should be fine. Jime and a few others recommended 70264. Jime actually has this cooler as his only means of cooling his fluid. I know as of now (Summer), it shifts no different. I am curious to see how well the bypass works when its about 20 degrees out.
Old Jul 23, 2002 | 06:39 AM
bill99gxe's Avatar
You're right about it being more than enough but it should be fine. I know as of now (Summer), it shifts no different. I am curious to see how well the bypass works when its about 20 degrees out.
Yeah, me too. Drop us a line when it gets that cold. I'm curious to see how well the B&M performs. brubenstein is the only one I know of who has used a B&M cooler and synthetic ATF in cold conditions with no probs.
Old Jul 23, 2002 | 06:43 AM
deezo's Avatar
Will do but I'll tell you, this cooler gets HOT!!!! Don't ask me how I know.
deezo
Old Jul 23, 2002 | 06:56 AM
thanks bill!!
Old Jul 23, 2002 | 06:59 AM
bill99gxe's Avatar
Originally posted by redmaxpa007
thanks bill!!
What for? I don't contribute anything to this place. I am only here to repress.
Old Jul 23, 2002 | 07:02 AM
deezo's Avatar
thanks bill!!
Are you going to put it on for show or are you going to hook it up.
Old Jul 23, 2002 | 07:09 AM
hey!!!
deezo
i finally got in touch with don amd my vb should be here in a couple weeks.
so it will be functional..
and all my mods are functional...grrr
Old Jul 23, 2002 | 07:15 AM
bill99gxe's Avatar
deezo
Great, now deezo has a hand thermometer........I'm jealous, as I wasn't given one.
Old Jul 23, 2002 | 08:35 AM
Eric L.'s Avatar
I have the B&M 70255. Great cooler, solid construction. B&M advertises that this cooler is nearly indestructible. I believe them...there are no thin aluminum fins to bend, and based on how hot it gets it seems to work quite well.
I have not had any problems in cold weather with this cooler, but then I use Redline D4 ATF.
Old Jul 23, 2002 | 08:39 AM
bill99gxe's Avatar
Sorry Eric, I thought you had a Hayden plate and fin. And we just had this conversation about a week or so ago.
Old Jul 23, 2002 | 09:38 AM
deezo's Avatar
I have the B&M 70255. Great cooler, solid construction. B&M advertises that this cooler is nearly indestructible. I believe them...there are no thin aluminum fins to bend....
Yup, these coolers are rock solid.
MaxLife17
Jun 27, 2019 01:37 PM
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
Lowered_a33
Sep 1, 2015 07:49 PM
