Just installed Nitrous (Fuel pressure High)
Old Jul 28, 2002 | 03:19 AM
Iron Lung's Avatar
Well I have a few bugs to work out but I got a pretty good preview of the gains. I tried a 50 shot at first and it felt decent but the fuel pressure was past 100psi. Thats with the .042 bypass. So I put the .036 nitrous jet in there and tried it again and no suprise the pressure remained the same at 100psi. I'm gonna have to try the local shops to see if I can get some by-pass jets. Hopefully by Thursday(Track Day).
Can anyone recommend what jet to start at for bringing the pressure down?
Old Jul 28, 2002 | 10:04 AM
Ramius83
Until you get the proper jet sizes, I wouldn't use the nitrous. At 100 psi on stock injectors, you can lock them up. That would be bad, ask Brian V about that......
Old Jul 28, 2002 | 11:30 AM
mtrai760's Avatar
'Trynna' is not a word
Wow, that is really high. You can also damage your engine by introducing that much fuel and not burning it... Did you install an aftermarket fuel pump? You may have to go to a .070 or higher to get your pressure down... ;(
Old Jul 28, 2002 | 11:39 AM
My 4DSC
Re: Just installed Nitrous (Fuel pressure High)
changing the nitrous jet will not affect the fuel pressure at all...
just put a bigger bypass jet in, bring the FP down to 85psi and run a 100 shot.
PS: get a bunch of jets, try .055/65/75/85 to start or take smaller steps if you got the money...
Old Jul 28, 2002 | 11:59 AM
Iron Lung's Avatar
Re: Re: Just installed Nitrous (Fuel pressure High)
Ok I took out the Fuel bypass just to see what the pressure would be(I unhooked the ground on the second solenoid) and it was at 78psi. Is there anyway to get this down from here or I am just stuck with running a higher shot.
I have the walbro high pressure pump
Old Jul 28, 2002 | 12:01 PM
mtrai760's Avatar
Re: Re: Re: Just installed Nitrous (Fuel pressure High)
Do you have a new fuel pump?
Ok I took out the Fuel bypass just to see what the pressure would be(I unhooked the ground on the second solenoid) and it was at 78psi. Is there anyway to get this down from here or I am just stuck with running a higher shot than I wanted.
Old Jul 28, 2002 | 12:12 PM
Iron Lung's Avatar
Re: Re: Re: Re: Just installed Nitrous (Fuel pressure High)
Yeah I have the walbro High pressure. Should I have not gotten the high pressure pump?
BriGuyMax's Avatar
the only way left is to get a adjustable FPR and turn it down manually. I tried all the way up to a .082 bypass jet and my pressure still wouldn't come below 85psi with the walbro pump....
Old Jul 28, 2002 | 12:16 PM
Iron Lung's Avatar
I am a little confused as to how the FPR works for adjusting fuel pressure for both N/A and nitrous. Oh and My pressure N/A is 35psi and 43psi.
Old Jul 28, 2002 | 01:18 PM
BriGuyMax's Avatar
if you turn down your baseline idle fuel pressure....the full throttle AND "on nitrous" fuel pressures will come down.
For example turn the idle down to 32-33 and your "on nitrous" pressure could come down 5-8 psi
Old Jul 28, 2002 | 01:19 PM
Iron Lung's Avatar
OK I see now. But if i run a lower N/A fuel pressure will that harm the motor? And since I am running at 78psi what if I just use an 80 shot jet. That should be about the right pressure, right?
Old Jul 28, 2002 | 08:54 PM
Ramius83
Well, when running NA, your ECU should compensate a little for the "leanness" in the engine. However, did you see a fuel pressure jump when you installed the Walbro when NA? I noticed a 10 psi jump. So, if you bring it down with the adjustable FPR 10 psi, that should be a start on bringing it down.....
Old Jul 28, 2002 | 10:09 PM
Iron Lung's Avatar
The NA pressure was exactly the same on the walbro as the stock pump. Oh and I just tried out the 80 shot and I pulled the plugs and they looked fine, but the nitrous surges sometimes. I did three runs in 2nd and only once was a continuous surge.
Cotozic
Jun 28, 2017 08:01 PM
305head
Aug 26, 2015 09:03 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
