Pedal Install Question???
I just bought these OBX racing pedals...I installed the footrest and the brake perfectly fine. Now I am having trouble w/ the gas pedal. Instead of using the clamps on the back, should I use the screws that they give and drill the gas pedal cover into the exhisting pedal. There is two holes in the gas pedal cover that would allow you to drill the screws through. So would drilling the cover on be a smart idead or no?!?!?
![Confused](https://maxima.org/forums/images/smilies/confused.gif)
It shouldnt be too hard but if you take off the rubber pad off the gas pedal, you can see that there isnt a whole lot of metal since theres a bar that goes down the middle on the back side. Sparco pedals require you to drill them on so drilling isnt out of the question
MAXSE5SPD
08-23-2015 12:06 PM
