Y-pipe install from hell
Old Aug 18, 2002 | 09:38 AM
ArcticMax's Avatar
Yesterday me, my brother and my friend tried to install the Y-pipe.
I was able to remove all the nut except for one on the rear flange.
The 2 nuts on the cat came off easily with the help of a breaker bar.
Anyway, the last nut remaining on the rear flange got stripped. I used a 12" extension and a Universal Joint, but the bend was still severe.. I ended up stripping the nut.
So I put all the nuts back on and aborted the project.
If I take it to a shop, will they be able to take the nut off? I heard they can "torch" it off, but what do you all mean by that?
Also, those of you who have installed the Y-pipe yourself, did you have to use an Universal Joint, or just the 12" extension?
I think that if I had NOT used the U-joint, the nut might have not stripped. Even without the U-joint, the angle with just the extension is not too bad. But the u-joint prevents the force from properly turning the nut. Instead, the force is distrubuted in a linear direction, rather than the "rotational" direction that is needed to turn the nut. That's what I think.
What should I do?
I need some help guys...
Old Aug 18, 2002 | 10:22 AM
hokiemax's Avatar
take it to a shop. Tell them all you want done is to have that problematic nut taken off. Bring it home. Unscrew the other nuts like you did last night. Cost at a shop = maybe $20
Old Aug 18, 2002 | 11:34 AM
Soon2BMaxed's Avatar
thats exactly what i did. what they do is heat up the nut with a torch and break loose with a airgun. but if you stripped the stud then you will have to replace it and that might cost a little more. good luck!
Trevor
Old Aug 19, 2002 | 06:02 AM
pblaze's Avatar
Re: Y-pipe install from hell
Sounds like my weekend, except I got the job done. The manifold nuts all broke loose with no problem. The ones on the cat added about 3 hours to the project. I rounded the first one off with a 6 point socket (WD-40, no torch). For a while I thought about retightening everything and taking it to a shop. I held a propane torch on the other nut for about 5 minutes, and it broke free with no problem. I attacked the F'd up nut with every implement of destruction in my limited arsenal, and it finally came off. I wound up cutting away as much of it as I could with a cut off wheel on a Dremmel, then splitting it with a chisel. The install is a snap. So far, leaks and no buzzing.
MaxLife17
Jun 27, 2019 01:37 PM
2kmaximel
Sep 16, 2015 03:19 PM
Violator
Sep 9, 2015 10:14 AM
