Is there an aftermarket front anti-sway bar for the 4th Gen Maxima?
Old Sep 3, 2002 | 09:33 AM
Blade_99SE's Avatar
If so, who and where can I get one? I believe this would be a cheap way to cut down on the body roll.
Blade
Old Sep 3, 2002 | 09:36 AM
clee130's Avatar
Don't believe so.
There are the Sub-Frame Connectors from WarpSpeed though.
Do a search for SFC.
Old Sep 3, 2002 | 09:49 AM
Blade_99SE's Avatar
Originally posted by clee130
Don't believe so.
I'd love to get subframe connectors but in the SCCA Solo II world that would bump me from STS to a Preparded class. That's not the best place to be.
Old Sep 3, 2002 | 10:18 AM
mzmtg's Avatar
Minister of Silly Walks
While a stiffer front anti-roll bar would cut body roll, it would also increase understeer. This would not be a good trade off considering we have too much understeer to begin with.
Old Sep 3, 2002 | 10:39 AM
sinewave's Avatar
I agree. What I would love to find are adjustable end links so that I could loosen the stock FSB.
Old Sep 3, 2002 | 10:49 AM
mzmtg's Avatar
How would adjustable links loosen the bar? Wouldnt they just move both ends up and down together?
I dont see how this would change the stiffness of the bar/system...
Old Sep 3, 2002 | 11:02 AM
Chebosto's Avatar
RIceD OuT moDErAtor
did you get the energy suspensions front sway bar bushings? there's like two kits out. one kit is just for the front sway bar. and the other kit is a full set for all the bushings in the front suspension...
courtesy nissan has em.
Old Sep 3, 2002 | 11:13 AM
sinewave's Avatar
I have seen adjustable end links (for other applications) that have a spring in line with bushings. You can adjust the spring pre-load, which effects how soon the body sway is transferred to the sway bar.
Old Sep 10, 2002 | 05:35 AM
BEJAY1's Avatar
Conecarver
Courtesy nissan has em.
An ES full set for the Maxima? I'll call right now. I'm sick of trying to piece it all together?
Lakersallday24
Nov 7, 2024 07:31 PM
CRizz
41
Jun 7, 2021 05:42 AM
morteljc
Oct 19, 2015 10:47 AM
PhalC1
Aug 5, 2015 02:36 PM
