Loose steering
Old Sep 10, 2002 | 02:36 PM
ADAM2KMAX's Avatar
Loose steering
Removed the Eibachs now it doesn't feel right. I really don't remember what stock feels like, but I sure hope its not like this from the factory! Is there play in the steering or should it be tight? Thanks.
Old Sep 10, 2002 | 04:28 PM
Yossarian's Avatar
Re: Loose steering
Try some Energy Suspension polyurethane end-link bushings on your front sway bar. They don't make an application for the Maxima, you have to get the universal ones. Search for a part number.
Old Sep 10, 2002 | 04:58 PM
costcowholesale's Avatar
Re: Re: Loose steering
does it make steering stiffer??
Old Sep 11, 2002 | 06:57 PM
Yossarian's Avatar
Re: Re: Re: Loose steering
It did for me. But I put in both end-link bushings and mid-bar bushings. I think it's the end-links that did the stiffening though, the old ones were disfigured and compressed real bad.
Old Sep 11, 2002 | 07:02 PM
Frank Fontaine's Avatar
Re: Loose steering
Stock feels terrible. Drive your g/f's Jetta, or rent an Olds Alero or Pontiac Sunfire or Grand Am and you wont believe how crisp and tight the steering can be when compared to the Maxima. It's the Nissan way because the 2k2 Altima 3.5 stick is exactly the same bad road feel experience. That's what Nissan engineers want I guess. Very important to make sure 350Z doesn't have it, or fuggetiboudit.
Old Sep 11, 2002 | 07:04 PM
Re: Re: Re: Re: Loose steering
how $ did that setup cost?
Old Sep 11, 2002 | 07:05 PM
ADAM2KMAX's Avatar
The Jetta is awesome. Crisp and tight as can be. Wish the Max was like that. Bushings are the best at this point. Need to keep it somewhat stock, leased. Thanks for input.
Old Sep 11, 2002 | 07:18 PM
Yossarian's Avatar
Re: Re: Re: Re: Re: Loose steering
Check Suspension.com. For the Maxima you'll find FSB bushings and lower control arm bushings. End-links, you'll need to get a universal application. Search the .org for the exact part number on that one.
Old Sep 12, 2002 | 06:01 AM
95Max's Avatar
Check your alignment. Toe out loose feel on center but better in curves, and the reverse...toe in tighter on center plow feeling in curves. As you can see to much of either is bad.
D Mason
Jun 21, 2016 04:43 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
