Pacesetter STS review.
Old Sep 19, 2002 | 11:59 AM
2KxSEx's Avatar
Yo,
I installed my STS this morning at 2am. Couldn't wait long . I didn't take off my cat to do it, I just unbolted the rubber handers that hold the front piping in place and moved it around. I moved the heatshield towards the y-pipe to clear the shift assembly. I set the ball at about 60% max and it's a big difference from stock. Went I went back to put the heatshield on I just stuck a thick nut between the undercarrage and the heatshield so the shifter could clear it. At about 60% max setting the shifter just barely clears the shield with the nuts I used. I'm prolly gonna go back and put thicker nuts between the shield and the car.
The test drive was nice. The shifter just clicks into gears now. The car is a lot smoother when I let out the clutch after each shift I guess because there's less time for the rpms to fall between shifts. I used a **** from the new SpecV sentra which has a very comfortable shape to it. The sts made the whole shifter sit lower too, which I like very much.
All in all, it is definitely worth the $60 I paid to southwestautoworks for it.
Peace.
Old Sep 19, 2002 | 12:02 PM
NYCe MaXiMa's Avatar
Re: Pacesetter STS review.
How about the notchy-ness and roughness of pushing the shifter?
Does that bother you?
I played with the shifter of a guy with an STS and although the shifts are shorter and more precise, the thing is hard to move..
Originally posted by 2KxSEx
Yo,
Peace.
Old Sep 19, 2002 | 12:08 PM
2KxSEx's Avatar
Today in the morning it was a little ruff, but as I drove around it became almost as smooth as stock. I greased everything I could on that thing
Peace.
Old Sep 19, 2002 | 01:07 PM
Blaxxxima's Avatar
!OG SNES OG!
Thanks for the write up.
I like the idea of using bigger nuts as a spacer for the heatshield, as opposed to banging the shi+ out of it.
That was a good breakdown of your process, and every little suggestion / idea helps
Mike
Old Sep 19, 2002 | 02:25 PM
2KxSEx's Avatar
Glad to help pal!
Peace.
Old Sep 19, 2002 | 02:32 PM
Chebosto's Avatar
RIceD OuT moDErAtor
if its really notchy. try using high temp silicon grease as lubricant for the ball joint. that helped alot!
also. dont forget to stretch the little spring underneath the car to return the shifter to the "neutral" position.
Old Sep 19, 2002 | 03:20 PM
mitch33x's Avatar
Good idea, I'll def do that when I install mine. Thanks
Old Sep 19, 2002 | 03:25 PM
2KxSEx's Avatar
I guess you only need to stretch the spring if you set the ball at a lower setting(70-100% max). My spring is just fine and the shifter moves freely.
Peace.
Old Sep 19, 2002 | 09:58 PM
Vinipux's Avatar
Re: Thanks for the write up.
Mike
dude, but that's half the fun, I loved banging the shi+ out of the heatshield and I was even happier when it was still rubbing... so I could take it out again and beat the shi+ out of it again
Old Sep 19, 2002 | 11:08 PM
irvine78's Avatar
Yo,
Peace.
haha! so you have a 6speed shift **** with a 5 speed tranny!!
Old Sep 20, 2002 | 04:45 AM
T-bone's Avatar
Yo,
Peace.
Thanks for the info. I have mine in the box still; I'm afraid to open it before I have time to do the install. How long did it take? I plan on using the stock shift ***; is this feasible?
Old Sep 20, 2002 | 06:19 AM
asu174's Avatar
Clay Aiken has fancy genitals
In neutral, my STS is fine springing back to the middle when I move it to the left, But to the right, it sticks. IceY2K1 told me that this is normal. Are you guys experiencing this too?
Oh, and my STS is at the lowest possible setting.
Old Sep 20, 2002 | 08:51 AM
2KxSEx's Avatar
Yeah, I have a 6spd **** with a 5spd tranny The install took me about 2 hours without removing the cat. If I was to remove the cat, it would have taken me another 2 hours because the bolts were rusted and stuck. Plus, I didn't like the idea of reusing the old gasket and I didn't have a new one on hand. You can use the stock shift **** on the sts, but be careful when you go to take the stock one off the stock shifter. My stock **** unscrewed right off for. About 2 weeks prior to receiving my pacesetter, I played around with the stock **** and I guess loosend the glue inside. And the day I went to install the STS it unscrewed right off. So you might want to play with the **** in advance.
asu174,
My STS does not stick anywhere, but as you have read I have mine set at about 60% of max. Sticking might be more common with the max setting of the STS.
Peace and to help everybody.
Old Sep 20, 2002 | 09:28 AM
Ghost face Max's Avatar
Yeah I really like my short shifter also, but I did the same I just greased everything well and shifting is smooth as pie. But the only thing I do have to do is dent the heat shield a little becuase it's hitting it a little bit.
Wolvee
Aug 11, 2015 12:24 PM
97max5spd
Aug 2, 2001 09:15 AM
TarHeelMax
Mar 27, 2001 08:28 PM
ebb
Dec 4, 2000 11:32 PM
