supercharger GURU'S
Old Sep 24, 2002 | 02:41 PM
97blackv1's Avatar
supercharger GURU'S
o.k. guys i search here quite a bit.
immediately after the SC install "CEL"
code 0304
code 0210
changed sparkplugs (reset ecu)"CEL"
did the fmu mod (reset ecu)"CEL"
put on y-pipe (reset ecu)"CEL"
catback exhaust(reset ecu)"CEL"
replaced back 2 02 sensors(reset ecu)"CEL"
same codes over and over again
lean left bank and knock sensor!
any other suggestions before i spend more$$$$
so new injectors or KS Or____________fill in here
thanks for letting me vent!
Old Sep 24, 2002 | 06:04 PM
SuDZ's Avatar
Sometimes the knock sensor will trip other error codes. I would recommend fixing that first then reset the light again and see if anything comes back.
SuDZ
Old Sep 24, 2002 | 06:17 PM
97blackv1's Avatar
thanks sudz
i guess i'll have to give it a shot.
i just wish i could pinpoint it.
Old Sep 24, 2002 | 06:20 PM
ptatohed's Avatar
Licensed to Spell
:o)
How long have you had your SC in 97? I got two codes just like you about 4 months after my install. It was knock sensor and evap canaster (don't recall the numbers right now). I reset the computer, they would stay off for maybe 50 miles and come back on. Reset them again, come back on. Again... After about 5 resets they never came back on again. And that was 4 months ago. I don't know if my knock sensor is bad or if I just had a bad tank of gas or what. I'm not even sure if I am doing the right thing by ignoring it. I did call a dealer and he said if the problem was still there the CEL would keep coming on. Anyway, not sure that I helped, just thought I'd share.
Old Sep 25, 2002 | 02:38 AM
97blackv1's Avatar
it's been about 3 months or so,
same thing here,i get about 30-50 in miles in between cel's.
when she's not having any errors,she runs like a bear though.
3.33" pulley-the most boost i have seen is around 6-7 # but mostly 5-6#.(on autometers)
by the way ptatohed nice write up on the install
Old Sep 25, 2002 | 08:13 AM
RB26DETT's Avatar
stop using cheap gas and upgrade your fuel pump.
Old Sep 25, 2002 | 05:36 PM
97blackv1's Avatar
RRRRRRiiiiiiigggggghhhhhhhhhtttttttttttt!
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
Cumalot
Nov 28, 2000 09:38 AM
Mabfnar
Oct 24, 2000 11:17 PM
