Need advise on B&M Oil Cooler
Old Oct 2, 2002 | 09:25 AM
  #41
Sprint's Avatar
Originally posted by Y2KevSE
No clue.
link up with Mr. do some tests .. do a write up.. and GET A CLUE
and you wonder why they call you keving
  #42
Y2KevSE's Avatar
Rice Boy in Denial =)
Originally posted by SprintMax
is that good or bad for my fitment issues right now? or is the location you suggested good enough?
It fits without getting in the way of the IC... to confirm, let me take a look at Jane's car tonight because she has hers there.
please stay out of my sex life..
Old Oct 2, 2002 | 09:27 AM
  #43
Sprint's Avatar
cool ... i will be waiting for your response
  #44
Y2KevSE's Avatar
link up with Mr.:confused do some tests .. do a write up.. and GET A CLUE
Ask MardiMatt... he has it also.
and you wonder why they call you keving :rolleyes
Old Oct 2, 2002 | 09:33 AM
  #45
redmaxpa007's Avatar
i SeE what you did therE
kevinG and darren
Old Oct 2, 2002 | 09:38 AM
  #46
Sprint's Avatar
Ask MardiMatt... he has it also. :
he is busy getting ready to setup another J&S deal and run off with the money for this batch.. the first batch was a trust batch
Old Oct 2, 2002 | 10:15 AM
  #47
Y2KevSE's Avatar
That should be enough for his new motor.
<img]http://64.252.156.63/images/hitit.gif [/img>
Come up north and we'll hit it!
Want to join us, Pinky?
Old Oct 2, 2002 | 10:18 AM
  #48
soopermax02's Avatar
For Tranny coolers:
Hayden 404 (same construction as permacool)
.75x7.5x15 inches up to 20k Gross vehicle weight
B&M 268
.75x7.5x11 inches up to 19k Gross vehicle weight
So B&M is 4 inches shorter, but only loses 5% of it's rated capacity.
Sounds a lot more efficient to me. To boot the B&M is nearly indestructable, there aren't any fins to get damaged.
Old Oct 2, 2002 | 10:22 AM
  #49
Sprint's Avatar
Originally posted by soopermax02
For Tranny coolers:
B&M 268
i think i will be going with teh B&M .. thanks for the info soopermax
and delio's too
I won't share her
no i am selfish
Old Oct 2, 2002 | 10:23 AM
  #50
as long as i do not have to do this
Old Oct 2, 2002 | 10:49 AM
  #51
Turbo95Max's Avatar
Turtle turtle... Moderator
uhhh hehe, ok besides all the homo talk which oil cooler have you decided is better?
i been wanted an oil cooler forever but im trying to locate a thermostatic sandwich adapter. any ideas? thanks
(and no i dont want to join or anything so dont start! haha)
Old Oct 2, 2002 | 10:58 AM
  #52
Cumalot's Avatar
Sprint and Kev, please get a room.
Old Oct 2, 2002 | 11:31 AM
  #53
Y2KevSE's Avatar
Brett has info for a thermostat, but I dont' think it's integrated into the adapter.
Since Sprite will be up here, you can join too!
Old Oct 2, 2002 | 12:23 PM
  #54
Chunger's Avatar
My other car is a Hybrid
Try here .
Old Oct 2, 2002 | 12:29 PM
  #55
Sprint's Avatar
Originally posted by Chunger
Try here .
thank you
Old Oct 2, 2002 | 01:16 PM
  #56
Y2KevSE's Avatar
Try here .
Nice!
Old Oct 2, 2002 | 04:41 PM
  #57
Confused's Avatar
Permanent Maxima.org Resident
Wow.... more info than anyone needs to know except Sprintmax & Y2kevse
but... size is going to matter for the adapter.. and chungers thermostat combo is $80 as opposed to $35-$40 for a permacool/b&m inline one. The b&m has a thermostat built in by design... to what temp I dont know. If you are going ss lines then fittings are gonna eat some of the difference.
Now that I see the setup I might just return it and get:
the b&m cooler by itself in black
earls or permacool sandwich adapter (about 1" as opposed to b&m's 1.5")
earls ruff stuff hose with fittings
earls makes temp a cure oil cooler but have no idea which is better..
Old Oct 2, 2002 | 05:40 PM
  #58
Chunger's Avatar
My dilemna is:
I bought -8AN lines and adaptors and wondering if I should buy those for -10AN...
Old Oct 2, 2002 | 05:43 PM
  #59
Sprint's Avatar
please let me know which one Mr. i want to get one soon
Old Oct 2, 2002 | 07:58 PM
  #60
Confused's Avatar
-8 (1/2) should be fine. most of the kits come with 1/2.
My dilemna is:
Old Oct 2, 2002 | 10:29 PM
  #61
Y2KevSE's Avatar
PLENTY of space left..... probably not relevant now since you're going with the B&M cooler.
Old Oct 2, 2002 | 10:31 PM
  #62
Sprint's Avatar
thanks baby
  #63
Chunger's Avatar
Thanks for the info! I guess the 0.44" will have to do.
Old Oct 3, 2002 | 12:47 AM
  #64
Turbo95Max's Avatar
so the B&M comes with a thermostat arleady?> sure bout that? if so id be interested in picking that up along with 8AN fittings.
Old Oct 3, 2002 | 05:12 AM
  #65
this is straight from B & M Site
B&M's SuperCooler low pressure drop coolers reduce the risk of lube system failure. A controlled amount of oil is allowed to bypass the stacked plate core, passing through a self-regulating orifice which monitors resistance to flow. Controlled by viscosity, the thicker oil is returned directly to lube through two open bypass openings in the stacked plate core. As operating temperatures increase, more of the oil flow is directed through the core. Resulting in a highly efficient cooling technology that combines improved protection against lube system failure with the required levels of optimal heat transfer
www.bmracing.com
Old Oct 3, 2002 | 05:23 AM
  #66
Sprint's Avatar
www.bmracing.com
wtf.. get out of here Auto boy.. we are talking about Oil.. not ATF
Old Oct 3, 2002 | 05:34 AM
  #67
they use the same coolers for oil and ATF..
Old Oct 3, 2002 | 05:35 AM
  #68
Sprint's Avatar
well then change your speach to reflect Oil.. all of us here are 5spd owners.. we don't care about you lazy shifters
Old Oct 3, 2002 | 05:42 AM
  #69
Confused's Avatar
what he said you can always buy the inline thermostatatic control valve (180 deg)
www.bmracing.com
Old Oct 3, 2002 | 05:53 AM
  #70
bill99gxe's Avatar
Evil Administrator - "The Problem"
Looks like oil to me.
Old Oct 3, 2002 | 05:55 AM
  #71
Sprint's Avatar
where you been billy boy...
Old Oct 3, 2002 | 06:01 AM
  #72
bill99gxe's Avatar
Re-seeding/planting/sodding the yard the past couple of weeks.....I feel like a cheap Mexican, and I'm being paid like one.
Old Oct 3, 2002 | 07:12 AM
  #73
agreed..
Old Oct 3, 2002 | 07:36 AM
  #74
Sprint's Avatar
Re-seeding/planting/sodding the yard the past couple of weeks.....I feel like a cheap Mexican, and I'm being paid like one. [/B]
you married.. why do you think you are getting paid
Old Oct 3, 2002 | 07:01 PM
  #75
bill99gxe's Avatar
I'm getting paid.
Old Oct 3, 2002 | 09:52 PM
  #76
Y2KevSE's Avatar
I'm getting laid. :-o :naughty :-o
tarun900
19
Dec 20, 2021 06:57 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
Noela
Sep 26, 2015 08:22 AM
