an idea to fix the CAI loss of top end...
Old Oct 3, 2002 | 02:36 PM
Soon2BMaxed's Avatar
ok everyone's theory on why top end sucks with a CAI seems to be that the tubing is just too long so i got an idea. after looking at my friends PR cai in his spec-v sentra i noticed that his filter sits RIGHT underneath the hole we had to cut. on my maxima the piping sat a few inches below the hole (almost low enough for the filter to touch my splash guard) so what if i was to cut a few inches off the end of the pipe? has anyone tried this? i could make it quite a bit shorter so it sat just under the hole like my friend's does. whats everyone's thoughts on this? i might try it later today.
Trevor
Old Oct 3, 2002 | 03:16 PM
BBaker025's Avatar
Try it!
Old Oct 3, 2002 | 03:48 PM
Mishmosh's Avatar
Re: an idea to fix the CAI loss of top end...
On my PRCAI, there is probably no more than 2 inches of pipe into the fender well... Not worth ruining your piping. Just try midpipe hybrid to see if you like that better.
Old Oct 3, 2002 | 03:58 PM
Chebosto's Avatar
RIceD OuT moDErAtor
its not really how long the tubing is, is the way the tubing is shaped.
think of air like water flow. it's curving up the pipe to get to the TB..
obviously if it was a straighter path, air could accelerate faster than curving all over the damn place.
having the fiter up higher the hole wont help.
its about eliminating that particular bend from PR's cai lower piece...
no way really around it, unless your air from the TB goes straight down into that hole where 5speed have all that space to put a longer straighter piping and just have a bend at the TB, but eeven then, you would want your air to be as straight as possible BEFORE the TB so that the air doesnt have to bend/loss velocity.
Old Oct 3, 2002 | 04:00 PM
gtr_rider's Avatar
192.168.1.1
get a supercharger..
Old Oct 3, 2002 | 04:03 PM
Street Reeper's Avatar
Handsome
Re: Re: an idea to fix the CAI loss of top end...
Triming a little off your pipe might help a little. I think that if you can find a way to straighten the CAI a little more, rather than the 90 degree bend at the fender, that this would pay off even more.
As far as the hybrid set up, this is just a short ram intake. These intakes where replaced by pop chargers because if your getting hot air from the engine bay you might as well not have any restricitive piping, they were also replaced by CAI to get cooler denser air. These hybrid intakes seem to only be a hybrid of the negative properties of pop chargers and CAI, which are heat from the engine, and extra piping. Also the midpipe used for these hybrid intakes was designed to be a part of the CAI, it has not been R&D for use by itself. A true hybrid would be a pop charger fed with outside air from a fabricated feed pipe. Keep working with the CAI.
Old Oct 3, 2002 | 05:34 PM
Re: Re: Re: an idea to fix the CAI loss of top end...
bah! i agree with cheston. and just looked at my pipe again and realized that there was less piping there than i thought so cutting it wouldn't have done anything for sure anyways. oh well, my hybrid works fine, i was just bored and looking for something to do. this is the first night this week that i dont have a paper to write.
Trevor
p.s. i did finally make a template for a heatshield though.
Old Oct 3, 2002 | 06:40 PM
Handsome
Re: Re: Re: Re: an idea to fix the CAI loss of top end...
Trevor
I agree as well as stated in my post. However instead of a bend at the throttle body (like most short ram intakes) I was thinking about a very gradual bend that extended from the throttle body to the fender well. There is a company in Dallas that makes carbon fiber intakes, after I get the diminsions I hope to have one fabricated. But i would really like a real hybrid intake (you know how I feel about the current ones) with the popcharger and fabricated feed pipe, but the dimensions may be just too large for the feed pipe to to not be restricitve, and provide only cool air.
However, if their are any engineers, how big would the pipe have to be to not be restrictive for the stock throttle body, I would think that a throttle body can only suck so much air, so i would want this air to be as dense as possible, as in a CAI with piping large enough to comfortably feed the dimesions of the throttle body. Any thoughts?
Old Oct 4, 2002 | 12:18 AM
Nismo's Avatar
Re: Re: Re: Re: Re: an idea to fix the CAI loss of top end...
not shure if this applys to intakes as it does exhausts but would having a larger diameter pipe decrease air velocity? If theres a way to tune the piping to a certain size to maximize the velocity and also reduce air turbulance.
Old Oct 4, 2002 | 07:48 AM
Nismo87SE's Avatar
Try running a 4in pipe instead of 3in, that should increase topend power but lower low-midrange gain.
Old Oct 4, 2002 | 09:10 AM
Handsome
What about this
What about a resevoir in the pipe. Comptech or Mugen makes an intake for the s2000 with this design. It was a 3 inch pipe with a resevoir (bubble) close to the part that conects to the throttle body. This I would think would act as a velocity stack, but i wonder what it's characteristics would be like on the dyno, any thoughts?
Old Oct 4, 2002 | 09:58 AM
poorcollegeboy's Avatar
Trevor
if you cut the tube, you'll lose a little of the low end...
intake performances throughout the rpm band depends on the tube length. yes, the temperature is a factor (somehting like for every 10 degrees cooler is 1% gain in hp), but tube length is the ultamite factor. cai suffer in the high end b/c of the air whipping around the corners of the tubing -> turbulence. pop chargers suffers in the low end b/c there isn't enough tubing for the air to be readily (unrestrictively) "stored" and also to gain velocity into the manifold. that's why frankencar has the best design (for now..... no, there is nothing up my sleeve). long straight tube.... that's all it is. nothing special (sorry steve).
no i did not pull this out of my *ss. there is fluid mechanics analysis behind this... but if you want to try something out in your homes... just take a long hose around the house blow into it...now blow into the same tube with the same bend with something like a leaf blower.... you WILL feel the decrease in air flow coming out the other end. peace.
Old Oct 4, 2002 | 11:00 AM
T-bone's Avatar
has anyone figured out a way to get a thermometer in where the intake meets the throttle body to see check air temps of the various intakes (at different speeds)?
Old Oct 4, 2002 | 11:06 AM
Nismo's Avatar
I think radio shack has this digital one that has a wire connecting to a probe that you can stick in places.
Old Oct 4, 2002 | 01:11 PM
Mizeree_X's Avatar
Getting back to his roots
Being an engineer, I was thinking about a plan similar to the VI manifolds -- have a CAI with a hole cut in the side of the pipe. Put a Pop charger there. Have a piece of metal on a track slide the hole open and closed, rigged to an RPM dependent switch. Mad $$, but would probly look cool, anyway
Old Oct 4, 2002 | 04:32 PM
Shannon and Ian's Avatar
We have a few threads about this on the SR20DEforum too!
http://www.sr20deforum.com/showthrea...threadid=26568
Old Oct 4, 2002 | 05:45 PM
Nismo's Avatar
I had the same idea once only It was a manual version with a pull rod that controls the cut out valve welded on the top of the pipe.
Vequity
Sep 10, 2015 05:26 AM
2012Maximus
Sep 10, 2015 12:50 AM
spidgeon
Sep 9, 2015 03:36 PM
slowlifer
Sep 8, 2015 05:53 AM
