Autometer tranny temp gage still doesn't work
Old Oct 12, 2002 | 11:08 AM
maxmizd27's Avatar
From the day that they got installed the needle doesn't move on this one gage. The voltmeter is fine and the coolant temp would be fine, but the stock sender isn't calibrated the same as the Autometer stuff is. I'll have to get the Autometer sender drilled and tapped in so that one reads correctly. The needle doesn't spike when you turn the car to "on" like the other two. These are electrical gages. I just got done swapping the sending units hoping that was the defective part. No such luck. Got it up to running temp and the needle still doesn't move.I guess I'm going to have to have Autometer send me another gage. I really didn't want to rip the console apart.
Old Oct 12, 2002 | 01:25 PM
redmaxpa007's Avatar
i SeE what you did therE
doh..!!!
i still need to hook mine up.. and i am mounting it in a different location.. got something new in the mail today..
Old Oct 13, 2002 | 10:51 PM
1MAX2NV's Avatar
Did you use the manifold to tap into the line of the ATF cooler? Or did you drill and weld a bong into the pan? If you are using the temp manifold, you need to ground the manifold.
http://photos.imageevent.com/1max2nv...e/DCP01060.JPG
Old Oct 14, 2002 | 08:20 AM
maxmizd27's Avatar
I have it in a T fitting into the flexible line, but the fitting itself isn't grounded. It's similar to their manifold, but not as large. The gage itself is grounded, but not where the sender is. I thought it was a problem with the gage body since the needle doesn't spike with the key at the "on" position like the other two do. Hmm...
Old Oct 14, 2002 | 08:24 AM
DanNY's Avatar
Ad·min·is·tra·tor
well check your connections on the gauge..they should all jump when you go from on->start. if they don't then it's prob a loose connection on the ign line...(power when car is on).
then on the sensor you should have the manifold/outter part of the sensor grounded. then have the sending wire on the TOP of the temp probe.
Old Oct 14, 2002 | 08:28 AM
maxmizd27's Avatar
It doesn't jump. The other two do. They are fine. I also have a coolant temp and a voltmeter. I wonder if I can solder a wire to the body of that T fitting to ground it? There is no place to put in a screw like the Autometer manifold.
Old Oct 14, 2002 | 08:30 AM
DanNY's Avatar
Ad·min·is·tra·tor
well even if it wasn't grounded you should still see it jump. solder, weld or clamp...just as long as u get a grounding point on it.
Old Oct 14, 2002 | 08:35 AM
1MAX2NV's Avatar
I assume those t-fittings are brass if so you can't solder wire onto brass. You have to weld it on or use JB weld.
Old Oct 14, 2002 | 08:52 AM
maxmizd27's Avatar
That's why I thought it was the gage itself once I tried another sender. I didn't know the sender had to be grounded too.
Tony, the fitting is brass. You can't solder onto brass?
Old Oct 14, 2002 | 02:05 PM
1MAX2NV's Avatar
I tried and failed. The brass absorbed all the heat from the soldering iron. I really think the only way is to weld it on or just ghetto rig it via JB weld.
Old Oct 14, 2002 | 04:20 PM
DanNY's Avatar
Ad·min·is·tra·tor
i would try using a metal clamp (hose clamp) and clamp the wire on the piece.
Old Oct 14, 2002 | 05:50 PM
try this and see if it works..
sounds like the easist way
Old Oct 15, 2002 | 10:28 AM
maxmizd27's Avatar
I'll have to get in the dash and see how they have the gages grounded. A guy I work with said that the gages don't like to have their grounding wires connected in series (one gage to the next to the next). He said his only worked when he ran a seperate ground wire from each gage, spliced them together and then grounded that wire. It was the middle of three gages that didn't work for him either.
Old Oct 15, 2002 | 11:08 AM
1MAX2NV's Avatar
Brian,
I think the problem is the ground to the probe and NOT the ground to the gauge itself.
Old Oct 15, 2002 | 11:22 AM
maxmizd27's Avatar
Brian,
I think I'm going to try that too (JB Weld method). Then once I get this one working we can worry about getting the sender drilled and tapped in to get the coolant temp working right.
Whos idea was this?
Old Oct 15, 2002 | 11:32 AM
Whos idea was this?
yours.. !!!!
dr3am
25
Oct 22, 2015 08:53 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
cstrasz
Aug 27, 2015 08:07 AM
Flores94
Aug 13, 2015 01:17 PM
kenc15
Aug 5, 2015 08:29 AM
