Injector / Upper Intake Plenum on 92 VE
Old Oct 15, 2002 | 03:43 PM
nummaonenutsaq's Avatar
Ok.. so my #5 injector is malfuntioning, either as a result of its own issues, or the harness/wiring to the injector. How long would it take to do all the labor to remove the upper plenum and if/when I do get it off, how do I determine if its the injector, the harness, or the wire that is not functioning? what a pain in the ****..
-A
Old Oct 15, 2002 | 05:20 PM
dmontzsta's Avatar
Ford Only.
BUMP
Old Oct 15, 2002 | 05:46 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: Injector / Upper Intake Plenum on 92 VE
the VQ guys who have done the MEVI swap should know the answer to this, the removal process of the VE and VQ IMs is basically he same!
-A
Old Oct 16, 2002 | 09:28 AM
dmontzsta's Avatar
Ford Only.
bump again...anyone?
Old Oct 16, 2002 | 09:40 AM
SuDZ's Avatar
Wel;l to take off the manifold is going to be a few hours to start with if it is like the VQ which is what DA-MAX says. As far as the testing get a VOM and a manual from Hayes or what not. Usually they will tell you voltages to check ect, or even the impedance of the wire. Based on these it makes it easy to find the culprit.
SuDZ
Old Oct 17, 2002 | 10:34 PM
Jeff92se's Avatar
I'm needing a caw
If I do it? Maybe an hour or less. If you do it, 2 hours + maybe?
Old Oct 17, 2002 | 10:58 PM
dmontzsta's Avatar
Ford Only.
where have you been? well you are right, we did it in about 1 1/2 - 2 hours it is off now.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
JonBlz
Oct 5, 2015 06:02 PM
MichMaxFan
Sep 30, 2015 09:18 AM
