NOS WOT Switch install question
Old Oct 16, 2002 | 02:53 PM
ejj's Avatar
ejj
Where in the world have you guys installed your WOT switch? I gave it a quick look today when I had the throttle-body off the intake manifold, and I didn't see an easy way to mount it.
A picture would be great!
Old Oct 16, 2002 | 03:44 PM
1MAX2NV's Avatar
It was dark in the garage so this is the best I can do.
http://photos.imageevent.com/1max2nv...e/Dcp01379.jpg
http://photos.imageevent.com/1max2nv...e/Dcp01380.jpg
http://photos.imageevent.com/1max2nv...e/Dcp01381.jpg
Old Oct 16, 2002 | 03:51 PM
Sprint's Avatar
Old Oct 16, 2002 | 05:47 PM
ejj's Avatar
ejj
Is that a custom bracket?
Old Oct 16, 2002 | 11:53 PM
BriGuyMax's Avatar
that braket comes with the kit.
I'm wondering how I'm going to re-install my WOT switch since that bolt hole that sprint's pic has the bracket mounted to doesn't exist on my MEVI.
Old Oct 17, 2002 | 07:31 AM
JAIMECBR900's Avatar
Originally posted by SprintMax
If you have the stock intake, mount it just like sprint did. Take the bolt out, slide the bracket from the kit in, adjust as necessary. I had to bend mine a little bit (kinda like a slight bend in the middle which forms a "lazy Z") to make it fit correctly. You will also probably have to cut off a little excess which will stick out of the back of the bracket. Not that hard at all, just bend it a little and check it until you get it right. Remember, it has to make contact at WOT and not before. If it touches before, you will basically make a "stopper" for the linkage and your car won't get to WOT at all.
Old Oct 17, 2002 | 07:35 AM
Sprint's Avatar
you mean stock intake manifold right? not HAI or CAI systems?
I did that by accident i was wonder how after installing my Nitrous my cousin's 97 SE could pull me at high speeds.. till i was showing dmbmaxima my engine bay and he was like.. wait a second.. yoru WOT switch is out too far
Old Oct 17, 2002 | 07:51 AM
Yes, just saying that is the best place on a stock TB/manifold.
I feel your pain, that's why I mentioned it. You are not the only one that did that I'm sure. When I installed my first system (dry), I had to do a little head scratching until I figured out to bend the bracket that came with the kit.
BTW, it's hard to see but on my sig pic you can see where my switch is mounted in the same place as Sprint's.
kmitchel
Oct 28, 2015 09:46 AM
Finkle
Sep 27, 2015 09:53 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
t6378tp
Aug 24, 2015 07:03 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
