Educational Course Needed - Rev Matching
Old Oct 22, 2002 | 10:13 AM
Big_Ham's Avatar
MaximaFreak
So, I guess I have the general idea, seems like a simple concept, but how to really get good at this? Is it all just practice? I had a killer rev-matched downshift into 2nd gear last night at about 35 MPH (by accident) and floored it, and the car just gets up and goes. I have done this on occasion - mostly by accident - and it really is better for accelleration/decelleration as well as obviously being better for the car/clutch. Anyone care to teach someone who cares to listen?
Old Oct 22, 2002 | 10:31 AM
JerseyMaxima's Avatar
Re: Educational Course Needed - Rev Matching
It is all practice. Using your example, basically, In third gear going 35 mph, clutch in, simultaneously shift into second while tapping the gas to rev match, let clutch out. RPM should be about 3000-3500?
It took me about a week to get it, then after a while it becomes second nature. Hope this helps. Good luck
Old Oct 22, 2002 | 10:41 AM
matt calder's Avatar
once you get the rev matching down then you should try heel-toe shifting. That is when you are slowing down and you have part of your foot on the brake and another part on the gas. Pressing the gas as you brake. Once you get good at it, you will barely feel the car change gears because it will be so smooth and seamless.
Cheston(Chebosto) has a good article of how to do it on his website.
here~~>
Old Oct 22, 2002 | 10:53 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
here~~>
Chebosto drives like my granny.
Old Oct 22, 2002 | 10:57 AM
The chiggers are holding him back, I tell you.
Old Oct 22, 2002 | 11:10 AM
StygianMax's Avatar
There are a bunch of good videos you can check out: BMW M5 Virtual Driving School
WARNING: You'll want a fast network connection to download these!!
Old Oct 22, 2002 | 11:18 AM
Big_Ham's Avatar
MaximaFreak
NOW we're talking. Thanks much, I'm downloading them as we speak.
Old Oct 22, 2002 | 11:46 AM
StygianMax's Avatar
Enjoy! I downloaded them at work & stored them in my laptop. The video/audio quality is very good. It was through the downshifting video that I learned to better rev match. To think I was "abusing" my synchro prior to that! I wish I would have learned the proper way to downshift looong ago.
Old Oct 22, 2002 | 12:24 PM
2k2-blk-6spd's Avatar
Thanks TONS! Those videos are just what I knew the internet could produce. Thanks again and watch out for a black 6spd in Texas
Old Oct 22, 2002 | 04:53 PM
brodaiga's Avatar
I often downshift without rev matching, let's say I', going 40 in third, momentary foot of gas, switch to second, blip throttle and go, anything wrong with this, I have an good aftermarket clutch? If racing, this seems to work a lot faster. This is not powershifting because power****ing is shifting without ever letting go of the gas, have been driving 5 speed for about 5 months,now, I can rev match, but find it cumbersome compared to what I do, anything wrong with it?
Old Oct 22, 2002 | 05:06 PM
StygianMax's Avatar
I used to blip my throttle when downshifting sometimes. After I read a post & watched the Bimmer M5 video about rev matching, I'm starting to think "blipping the throttle" & "rev matching" are closely related, if not outright one & the same. The end result seems to be the same thing.
Are we referring to the same process by two different names?
Old Oct 23, 2002 | 05:11 AM
Black VQ's Avatar
Close...
It's like the means to an end. You blip the throttle so that you can match your revs.
The double-clutching technique uses rev matching, as well as the previously mentioned heel-toe shift. To double-clutch, you lift of the throttle, put the clutch in, shift to neutral, release the clutch, blip the throttle, put the clutch back in and then shift to the desired gear.
You just have to make sure you blip correctly, or you'll mess up.
I hope I got the double-clutching part right, since I don't know from experience. I'm an automagic driver.
Matt93SE
May 24, 2019 02:58 PM
smplyamzng
Dec 13, 2015 01:19 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
t6378tp
Aug 24, 2015 07:03 AM
TonyJr
Aug 20, 2015 12:14 AM
