Final Tuning of rebuilt motor
Old Nov 2, 2002 | 06:53 PM
i30krab's Avatar
I picked up the I30krab yesterday from Jim Wolf Technology. They had the car for a week and were doing the final tuning. the car is running great! The 65 shot of N2O fills in the initial lag while the SC is spooling up. The N2O cuts in around 2500 rpm and shuts off at 5500. The car hasn't been dynoed yet but Jim said it's putting out in the 400hp range at the flywheel. He compared my car to a tuned and modified 300XTT. Without the N2O the car's low end is good but not great but at 3500 RPM it hauls like a V8.
I'm using the 375 injectors that were blueprinted and balanced at RC Engineering and with or without N2O they are maxing out on the top end. I'm not going with bigger injectors, that's it!! On a turbo these injectors max out at around 420 HP and I think that's where I'm at.
The car winds up to 7000 with no effort because the rev limiter was raised to 7200. Don't forget, I have the new JWT cams and the heavier valve springs. The best thing about the cams is the longer duration and height on the exhaust side allowing the spent gasses to exit much faster. When we rebuilt the motor, we removed the restrictions in the exhaust manifolds and gasket matched and ported and polished the exhaust and intake manifolds allowing the motor to take advantage of the new cams!.
Jim and Clark had to raise the idle to 900 because of the loping from the cams. The computer is constantly trying to fine tune the idle but never quite gets there causing the motor to lope and turning up the idle practically eliminated this annoying sensation.
I'm very happy with the car but that's it with the speed mods bacause I'm waiting for the new Infiniti 35 convertible and if they don't make one I'll settle for a 300Z convertible!
By the way, on the way home from San Diego to Vegas yesterday a riced up late model civic with body armor and wheels etc. pulls up at around 70 mph and looks over and starts to punch it. I smiled and floored the car and left him like he was standing still. It was amusing to say the least.
Old Nov 2, 2002 | 07:07 PM
mb1's Avatar
mb1
I'm speechless.
Old Nov 2, 2002 | 07:12 PM
Blu's Avatar
Blu
the tits
do you plan on taking this car to the track?? Or is it just a project car to see what kind of power its capable of.
Old Nov 2, 2002 | 07:30 PM
i30krab's Avatar
When the car is broken in and I can use synthetic oil I'll take it to the track and to the dyno.
Old Nov 2, 2002 | 07:32 PM
Blu's Avatar
Blu
the tits
Old Nov 2, 2002 | 08:54 PM
emax02's Avatar
Sounds good Ron
Old Nov 2, 2002 | 08:58 PM
soopermax02's Avatar
I envy you.
Old Nov 2, 2002 | 09:46 PM
UTIMaxima's Avatar
You should set up a homepage so we can all check out your car, see what you have done with it.
Old Nov 2, 2002 | 11:10 PM
Burton069's Avatar
Sounds cool! And who said I30s are slow
Old Nov 3, 2002 | 07:33 AM
Lime's Avatar
wowowowowow! Awesome stuff! I wanna see the car! get some vids for us when you take it to the track? :}
Old Nov 3, 2002 | 08:33 AM
gtr_rider's Avatar
192.168.1.1
I have pics
Old Nov 3, 2002 | 09:19 AM
Scruit's Avatar
U wanna try me young boy?
Do you think you'd benefit from a MEVI? The power gains versus stock manifold at over 5500rpm are significant, and you car obviously makes a psychotic amount of power at 5000-7000rpm.
Damn - 400hp in a car the weight of a max/I30 - I don't think you have reason to fear pretty much any stock vehicle out there...
Where's the "We're not worthy" smiley?
Old Nov 3, 2002 | 09:49 AM
gtr_rider's Avatar
192.168.1.1
You dont have an MEVI!?
Old Nov 3, 2002 | 04:34 PM
dwapenyi's Avatar
You know it! Hotter cams, 7200 rpm redline. Your car is just begging for the MEVI. Turbo97SE gained 35 hp at redline with his Maxima. You could gain maybe like 40 up top.
DW
Old Nov 3, 2002 | 04:53 PM
i30krab's Avatar
MEVI
If I go with a VI I will have to go with bigger injectors because the 370s are maxed out now. Is there something I,m not seeing?
Old Nov 3, 2002 | 06:28 PM
xHypex's Avatar
Re: MEVI
Based on the fact that your injectors are maxed already I don't think a VI would do good things for your car. The VI definitely flows more air once it kicks in, so if you're having problems at high rpms now more air won't help the situation.
Althought you could always just buy some Nismo 555cc injectors and go for more power
-hype
Old Nov 3, 2002 | 08:47 PM
scmaxima2k's Avatar
damn...i definately wanna see some pics..
Old Nov 4, 2002 | 03:39 AM
dwapenyi's Avatar
OK, so your feul injectors are the limitation. But, after all that work, it's like you climbed 3/4s of Mt. Everest and the last part is relatiuvely easy. Upgrade your injectors and drop on a VI. I guess it's safe to say that you have the most powerful 4th, or even Maxima of any generation, period. Even without the VI. But you know there's a wee bit more in there
DW
Old Nov 4, 2002 | 06:32 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Finally done, eh? I thought you were done when we met at Stillen Nissan day.
Old Nov 4, 2002 | 06:33 AM
MardiGrasMax's Avatar
Ron, you can ramp up your fuel pressure and get more out of it.
I was getting 377whp (actual not SAE) (377whp*115%=433bhp/est)out of the stock fuel injectors at 85psi fuel pressure sunig a Vortech FMU with an 8:1 disk.
I would assume that your fuel pressure is ~55psi at WOT and full boost at redline with a 1:1 regulator. Using the 370cc injectors and going higher than 55psi you can go well into the 500bhp range if you tune it right using a rising rate regulator with a ratio higher then 1:1.
Anywhoo, glad to hear its running and I am looking forward to dyno numbers and track times. All that work and down time, its time for you to enjoy your baby for a little while
Old Nov 4, 2002 | 08:28 AM
Synki's Avatar
You have lost your marbles.
Best of luck with the new setup.
Old Nov 4, 2002 | 08:43 AM
SuDZ's Avatar
Man this thing must be fun to drive.
SuDZ
Old Nov 4, 2002 | 10:20 AM
JerzMax's Avatar
Re: MEVI
If you don't mind me asking, how much did it cost you to built up the motor?
Old Nov 4, 2002 | 10:22 AM
gLok's Avatar
If it was me, i'd 86 that blower and toss one of the turbo kits on it with a slightly bigger turbo
Old Nov 4, 2002 | 01:45 PM
nismo2020's Avatar
Needs non-Maxima Friends
i30krab is your car an auto or 5spd?
Old Nov 4, 2002 | 02:06 PM
Synki's Avatar
Auto, but I wouldn't really know what to call it anymore. He can shift his car through buttons. hehe.
Old Nov 4, 2002 | 05:23 PM
i30krab's Avatar
Hi MardiGras,
The way my car is presently tuned everything is controlled by the ecu.
I really don't race much so I'm happy with my present system ie no extra controllers for air, fuel, or timing. This way I don't drive my self crazy trying to fine tune the car with ***** and buttons. I am a perfectionest and I know I would be constantly fiddling. The only other way I could get more fuel would be with 550 injectors and presently this isn't an option, I am tired of throwing money at the car. I'm waiting for nissan to make a convertible G35 coupe.
Old Nov 4, 2002 | 05:31 PM
pezking4's Avatar
Hi MardiGras,
My gosh.. how do you keep traction??
Old Nov 4, 2002 | 05:53 PM
turbo97SE's Avatar
Hi MardiGras,
Hehe! I am like you, I don't race a whole bunch. It's just a lot of fun to punch as much HP out of the VQ engine as possible, although, I think the engine sleeves probably won't hold up too well at 500+ HP....but it's gonna be fun finding out!
Old Nov 4, 2002 | 06:14 PM
nismo2020's Avatar
meaning your just going to keep adding boost till it blows?
Old Nov 5, 2002 | 02:26 AM
thnikkamax's Avatar
Ludicrous Speed
Well, I think he's still on stock internals without engine build.
What are your new wheel HP numbers, Nigel?
Old Nov 5, 2002 | 06:34 AM
turbo97SE's Avatar
I think I want to build the motor first, but I am having a heck of a time trying to decide which pistons to get. Once I get the block built on my other engine, I'll start turning up the boost and fuel on this one and see what goes first. I'd like to see the breaking point of our VQ.
Old Nov 5, 2002 | 09:00 AM
96BLUMAX's Avatar
Sounds great. Now both you guys have fast a$$ maximas/i30s. Can't wait to see some times.
Old Nov 5, 2002 | 12:10 PM
funnylittlman's Avatar
Take me for a spin!
I bet I would $hit my pants......uh wait a minute
Old Nov 5, 2002 | 03:48 PM
SuDZ's Avatar
Or what breaks first.
SuDZ
Old Nov 5, 2002 | 04:47 PM
mzmtg's Avatar
Minister of Silly Walks
You've got it backwards...
To calculate for a 15% driveline loss, you'd do this:
377 / .85 = 443
Old Nov 6, 2002 | 05:59 AM
Thanks!
Old Sep 26, 2012 | 02:24 AM
youngsoldier's Avatar
Hey guys i have a rebuilt '04 motor in my '95 maxima. Just wondering what kind of immediate maintenance I should be looking at? Also i have new headers. I heard as you drive, the new headers will back off and will need to be tightened. Is this true?
sorry to reply off topic but i couldn't find any threads on the subject..
Old Sep 26, 2012 | 06:40 AM
dwapenyi's Avatar
You must be Michael J Fox because you just brought this thread back to the future.
DW
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
jsmith24
Feb 1, 2016 12:35 AM
homeofbacon
Sep 23, 2015 07:17 PM
RWCreative
Sep 21, 2015 11:01 AM
pears
Sep 18, 2015 05:25 AM
