Engine Noise. Need Help!
Old Nov 14, 2002 | 04:57 PM
doman100's Avatar
First, I would likes to thank you all members on this board which encouraged me to do all maint. works on my Maxima (which I never done before). I have 1997 Maxima SE- standard (168000 miles). The engine making noise (hard to explains- like oo's sounds, sound like when ready to shift from current gear to next gear when rpm high) from 1st to 5th gear on passenger front engine side. The noise only gone when- press clutch, in neutral, and over 55 mile/h on highway cruising. Car Shifting Gear is OK (not to smooth, but ok). A car still run strong uphill and fast. I just cleaned TB, replaced Spark Plug, Air filter, o2 sensor, oil, gear fluid. Please help- is a sign of transmission or timing chain or clutch going bad? If those problems, adive how to fix it. Thank you very much.
thanks,
Sam
Old Nov 14, 2002 | 09:16 PM
Nismo's Avatar
dont quiet understand the "oo" sound. are you saying you hear a whine noise when the clutch is out? could it be that your alternator is going bad? (97 alt recall)
Old Nov 15, 2002 | 03:41 PM
doman100's Avatar
Thanks Nismo for reply. Engine noise like loud Hmmm's Hmmm's sound when clutch out & acceleration in any gear (from 1st to 5th). Noise go away when press clutch, run in neutral, and cruise over 55 miles/h on highway. What is the sign of alternator going bad? Thank you.
-Sam
Old Nov 15, 2002 | 03:46 PM
Conrad283's Avatar
I need a truck
your car won't start
Old Nov 15, 2002 | 05:49 PM
Nismo's Avatar
-Sam
I think its something to do with the transmission because you say it goes away when the clutch is pressed.
02PearlSE
Feb 1, 2016 12:37 AM
rbarnes
Dec 31, 2015 06:29 PM
Socalstillen
Sep 20, 2015 11:46 PM
pears
Sep 18, 2015 05:25 AM
lrb6805
Sep 17, 2015 04:49 PM
