I found another leak
As I was inspecting my motor for leaks, I found another one in addition to the rear main seal. This one is where the upper aluminum oil pan meets the block, but on the opposite side of the rear main seal. This is where the accessory crank pulley is. Its not dripping but I dont like it when I see oil all over the side of the engine. The good news, if there is any good news is that I must drop and reseal the upper oil pan when doing the rear main seal anyway. Of course this could be bad cause it may start leaking even more. Anybody else have the oil leak from the crank pulley area?
my drive axel seal leaks SOMETIMES, perhaps a drop or two randomy... other than that i just discovered my oil sensor switch (sp) is leaking a drop or two every now and then.
my maxima is startin to suck
wanna battle? heeh
my axle seal leaks, timing cover leaks, upper oil pan to block leaks, lower pan to upper pan leaks, oil return line leaks, and 1-2 more leaks i have yet to locate.
Yeah leaks here and there. Sometimes the leaks smells like beer, sometimes the leak is stained on my car, oh wait, it was the college girls in downton Providence taking a whizz next to my car pizz drunk. Me and my friends just kept starting at her and her bum, she was cute so we did'nt mind, wish I had my digital camera for my Kodak Moment!
If I did capture that moment, it would have been one of those internet pics thingy-majingy:
Club Fee: $5
Liquor: $40
Squatting and leaking next to my Maxima: Priceless!!!
Yeah, I am going to inspect the drive shaft seal for leaks and replace if need be next weekend.
- ßaller
Club Fee: $5
Liquor: $40
- ßaller
I also have some bad leaks:
-Both CV axle seals are leaking (just replaced 1k ago)
-Main Rear Seal has slight leak
-Control (shifter) rod seal leak
-slight lower oil pan leak
But, I am replacing all these seals except the control rod seal tomorrow.....
arty:
arty:
http://mywebpages.comcast.net/ewong61/max/DSCF0036.JPG
Looks like this is the front crank seal leaking. I guess since I gotta pull the drive pulley and change the seal, might as well put in a UDP??????
Originally posted by ThurzNite
My reverse light switch leaks. Anybody else? Stupid cuz this was replaced in 1999. argh!
Jae
Jae
Wow this post is still around and so's the pic wow. Anyway that was the front crank leakin I replaced the seal so far so good. Its a fairly easy and cheap job to do. Air impact helps to pull off the pulley bolt.
Mar 12, 2020 12:06 AM
JoshG
51
Sep 21, 2015 10:41 PM
Hdnseek
Sep 9, 2015 05:55 AM
