300Z rear caliper is the same for 4th gen Maxima?
Old Nov 25, 2002 | 10:35 AM
ßaller's Avatar
I needed a replacement right rear caliper, called autozone, they said $200 for Beck Arnley, I said no, he checked on Z rear calipers, said it was a different brand but for $55, with an $85 core charge. Will the Z rear caliper work? I am not sure which year Z he checked on. He said its the same, I do not know how he knows. Any help appreciated.
- ßaller
Old Nov 25, 2002 | 10:38 AM
irvine78's Avatar
Re: 300Z rear caliper is the same for 4th gen Maxima?
- ?ller
nope. it won't. 300ZX has completely different calipers in the rear than 4th gen Maximas.
Old Nov 25, 2002 | 12:34 PM
Turbo95Max's Avatar
Turtle turtle... Moderator
Juss remember MOST RWD cars will have a different caliper then a FWD car. and no, the 300ZX caliper Z31 or Z32 is different.
Old Nov 25, 2002 | 01:03 PM
Matt93SE's Avatar
STFU n00b!
Z31 rear rotors are the same thickness, but about 1/2" larger than 4th gen rotors. the calipers might work, but no guarantees on the mounting or parking brake parts of it.
Old Nov 25, 2002 | 01:29 PM
redmaxpa007's Avatar
i SeE what you did therE
i heard the parking brake was an issue
i will find out this spring if they will work.. i have a set and plan on trying to install them..
Old Nov 25, 2002 | 01:58 PM
Nealoc187's Avatar
SLOW
The 4th gen and altima (not sure on the year though) use the same brake pads on the rear so I'm assuming they are the same caliper.
Old Nov 25, 2002 | 03:21 PM
ßaller's Avatar
Thanks for the info. I checked at local junkyards, they watned $65, I was like damn, rather spend a little more and order from PartsAmerica.com for newly/remanufactured ones, than risk the used ones going bad.
- ßaller
Old Nov 25, 2002 | 09:48 PM
Matt93SE's Avatar
STFU n00b!
3rd and 4th gen max and altima all use the same rear pads, but the parking brake cable attaches in a different way to each.. same pad, but completely different calipers..
FYI, 3rd and 4th gen front calipers ARE the same. not sure about the Altima, but the ones on my wife's 97 alty look identical to the stock ones on my 3rd gen. whenever I have the need to work on her brakes, I'll look and find out.
Old Nov 26, 2002 | 01:14 AM
Turbo95Max's Avatar
parking brake assembly is different on most RWD cars. most of them use brake shoes. THere are certain advantages of using that type.
Lakersallday24
Nov 7, 2024 07:31 PM
CRizz
41
Jun 7, 2021 05:42 AM
morteljc
Oct 19, 2015 10:47 AM
Huttig2009
Sep 25, 2015 03:31 PM
