where is the ignition switch located?
Old Jan 20, 2003 | 01:46 PM
Soon2BMaxed's Avatar
well my car is having electrical problems again and my mechanic thinks it may be the ignition switch instead of a short in the wiring.
how much do these run?
how hard is the install?
thanks!
Trevor
Old Jan 20, 2003 | 02:30 PM
1MAX2NV's Avatar
It's where you stick your ignition key in.
Old Jan 20, 2003 | 03:01 PM
Originally posted by 1MAX2NV
It's where you stick your igition key in.
i'm so dumb.... is it hard to replace? should i do it myself?
Old Jan 20, 2003 | 10:32 PM
1MAX2NV's Avatar
Man..that sucks if your ignition switch is busted. You would have to carry two keys now. One for the door/trunk. One just for the ignition key cylinder. What was the faulty part before when you overloaded the ignition circuit? I never replaced one before. You probably need to know how to solder the wires directly on the switch.
Old Jan 21, 2003 | 07:24 AM
kramerica72's Avatar
It may not be the lock cylinder. The switch is a separate part inside the column on the end of the lock cylinder, so he may be able to use the same key.
Old Jan 21, 2003 | 01:03 PM
correct.
well, i got my car back today. they couldn't find a short in the wiring but they did see that some of the wires in my ignition switch were really loose so they fixed that. it cam down to 4 1/2 hours of labor but they took an hour off because i gave them some free pizza from papa john's (where i work ) so.....
3 1/2 hours labor+parts+towing fee+tax= $371.35
my nitrous kit is getting farther and farther away...
Old Jan 21, 2003 | 01:33 PM
][ 35's Avatar
i had a problem like that but like above post...they just had to replace some wire and things and i kept my orginal key....
Old Jan 21, 2003 | 01:34 PM
Dave B's Avatar
Not DAVEB the parts guy
OMG
I'm going to call you Eric D Wong from here on out.
Dave
Old Jan 21, 2003 | 02:45 PM
ericdwong's Avatar
Originally posted by Dave B
OMG
Dave
Huh?
Old Jan 21, 2003 | 02:48 PM
Jeff92se's Avatar
I'm needing a caw
Originally posted by ericdwong
Huh?
Old Jan 21, 2003 | 03:09 PM
OMG
Dave
shilov
Feb 19, 2024 09:40 PM
mikeg75
Nov 30, 2015 05:12 PM
rnb754
Sep 14, 2015 11:39 PM
