Who knows how to change the studs on the rotor?
Old Jan 29, 2003 | 10:45 PM
HTownMaxSE's Avatar
My studs are stripped and i need to change them out. Anyone with experience on this know how to change out the stud.
Old Jan 29, 2003 | 10:48 PM
iansw's Avatar
Re: Who knows how to change the studs on the rotor?
a towel and a hammer...use the towel to cover up the main part of the wheel, then whack the end of the stud with a hammer...
sounds crazy, I know, but that's how it's done.
IanS
Old Jan 29, 2003 | 10:59 PM
HTownMaxSE's Avatar
now how do i put the stud back in the rotor.
Old Jan 29, 2003 | 11:01 PM
iansw's Avatar
Get a new stud, stick it in there, and put everything back together.
Putting your wheel on and tightening the lugs will set it in place permanently.
Old Jan 29, 2003 | 11:17 PM
iansw's Avatar
Oh yeah - take the rotor off before you go hammering away.....
It's not attached - just pull...use a screwdriver to pry if it's a little rusted on.
IanS
Old Jan 30, 2003 | 12:09 AM
Nismo's Avatar
put your wheel back on and torque the stud with the lug nut to 100 ft lbs, then loosed the lug and re torque the nut back to spec.
Old Jan 30, 2003 | 10:17 AM
xHypex's Avatar
Like Ian said it's pretty easy.
Here's how I did it:
Remove the wheel, caliper, and pads.
Remove caliper bracket and rotor.
Hammer out the stud with a rubber mallet.
Put the new stud in.
Put a stack (4-5) of washers over the stud and tighten a lug nut to pull the stud into place.
Remove washers, reinstall parts, and put on the wheel.
-hype
Old Jan 30, 2003 | 10:20 AM
Dreizehn's Avatar
-hype
This is also how I've done it.
Old Jan 30, 2003 | 12:58 PM
HTownMaxSE's Avatar
thanks for you help
Old Jan 30, 2003 | 01:02 PM
iansw's Avatar
Doh, forgot about the washers - I did that as well.
Old Jan 30, 2003 | 01:46 PM
HitManSE's Avatar
I would just pop in a pair of ear plugs and bust out with my air hammer (thats why i use the ear plugs, if uve heard that thing u know what im talkin about!) and pop em out in a few seconds u can instll them the same way just gotta be careful with the hammer damn thing can really jarred out of ur hands if ur not holding on hard enough.
Old Jan 30, 2003 | 04:22 PM
HTownMaxSE's Avatar
Damn Damn Damn. I almost got it done till the last stud. It took me 1 hour to do the left side. Then I got it down and it took me 10 min for the right side then I was putting the last stud in place, then all of a sudden the damn bolt got stuck on the stud and i couldn't take it off. So i had to cut it off and now my car sitting helpless on a stand for another lonely night. Damn my moms thunderbird, girls look at me funny in that car.
Old Jan 30, 2003 | 04:30 PM
Dreizehn's Avatar
It's not the car...
sorry, it was just too easy not to say it...
Old Feb 25, 2003 | 07:41 PM
sanjosemaxima's Avatar
Sleeps with his maxima!
hey does anyone know where you can get new studs?
Old Feb 25, 2003 | 07:46 PM
iansw's Avatar
Most dealers have plenty in stock....people break them often, apparently.
Old Feb 25, 2003 | 07:48 PM
thanks man
dcam0326
Sep 26, 2015 05:20 AM
RWCreative
Sep 21, 2015 11:01 AM
Lowered_a33
Sep 10, 2015 09:41 PM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
